Hey, i recently changed most components of my PC. This problem started after i installed v6.75.6100. It used to show information about the fans, core temperatures, etc., but now it just doesn't show anything, i've attached a screenshot so you can see. Also i noticed the UI has changed a little and the quality of the icons is low.
  • 3 weeks later...
I think some files that are part of the AIDA64 distribution package is not present in the same folder as AIDA64.EXE (main binary).  Try to reinstall the latest version, and restart Windows to apply the changes.
