fixed: GeForce RTX 4090 temperature bug and 12900K core workload bug
hi :)
The temp sensor from the 4090 GPU Diode is wrong
i checked the Temp with Afterburner und Hwinfo and they have the same Temp but only in Aida the Temp is way more higher (Screen below) and the Core Workload is absolute wrong from the 12900k in the screen you see 20% but Aida says 3-4%
Win11 22H2
4090 Temps
  • Benni231990 changed the title to 4090 Temp Bug and 12900k Core workload bug
On 11/9/2022 at 2:21 PM, Benni231990 said:
hi :)
Win11 22H2
4090 Temps
Is there always the same 4 degrees difference between the GPU diode temperature reported by AIDA64 and HWiNFO?
We're working on the CPU utilization measurement issue under Win11.
I have the same issue with the RTX 4090 GPU diode temp. The temps in AIDA are 2 higher than other monitoring programs (Afterburner, HWInfo64, Nvidia GeFore Experience). The difference will go up to 5 degrees when the temps go up during gaming.
The GPU memory and hotspot temps are fine \.
AMD Ryzen 9 5950X
MSI X570 Unify
Gainward RTX 4090 Phantom GS
AIDA64 6.80.6200
Windows 11 22H2
On 11/20/2022 at 3:57 PM, Benni231990 said:
no its allways jumps between 3-5 Degrees but average 4 degrees
@mfung1985
We will fix the GPU diode temperature measurement issue in the next AIDA64 beta update.
As for the CPU utilization issue, please refer to this forum topic:
  • Solution
hi :)
Win11 22H2
4090 Temps
About the CPU utilization measurement issue, please upgrade to the latest beta version of AIDA64 Extreme available at:
You need to activate (tick) the last option on the AIDA64 / main menu / Preferences / Stability page called Windows 11 CPU utilization measurement workaround.  Let me know if it helps to obtain more realistic CPU utilization measurements.
  • Fiery changed the title to fixed: GeForce RTX 4090 temperature bug and 12900K core workload bug
