Hello I have used zadig And have tried the samsung installation None of which works as zadig does something to the drivers but aida64 still says "Cannot Find Libusb0.dll" And the samsung driver Does not work scince windows Does not support the file Or it fails because it thinks its not a based x64 file
This is really Annoying scince i want to use the lcd to monitor my pc
Please try this method:
https://forums.aida64.com/topic/10598-having-troubles-installing-ax206-driver-on-windows-11/?do=findComment&comment=48117
  • 3 months later...
Did this ever get solved? I have been going 3 days now trying different drivers and no matter what I do or try all I get is Error USB device 1908-0102 not found. Sucks I paid $120 for a display and another $60 for aiga64. Tried every YouTube video every forum. Nothing!
On 9/12/2023 at 6:29 PM, eaa said:
I have previously said that the samsung driver one dosent work...
You may have a different display.  Try to use the SmartCool LCD module in AIDA64, instead of the AX206 module.
  • 4 weeks later...
