The 4th system fan will not appear under sensor items. Ive updated to the latest beta version. Below is the sensor report
Quote
--------[ AIDA64 Extreme ]----------------------------------------------------------------------------------------------
    Version                                           AIDA64 v7.20.6841 Beta
    Benchmark Module                                  4.6.896.8-x64
    Homepage                                          http://www.aida64.com/
    Report Type                                       Quick Report
    Computer                                          DESKTOP
    Generator                                         simon
    Operating System                                  Microsoft Windows 11 Home 10.0.22631.3593 (Win11 23H2 2023 Update)
    Date                                              2024-06-02
    Time                                              11:44
--------[ Sensor ]------------------------------------------------------------------------------------------------------
    Sensor Properties:
      Sensor Type                                       Nuvoton NCT6687D-M  (ISA A20h)
      GPU Sensor Type                                   PMLog  (ADL2)
      Motherboard Name                                  MSI MS-7E26
    Temperatures:
      Motherboard                                       35 °C
      CPU                                               47 °C
      CPU Diode                                         48 °C
      CCD #1                                            40 °C
      Chipset                                           35 °C
      PCH Diode                                         43 °C
      MOS                                               33 °C
      GPU1: GPU                                         54 °C
      GPU1: GPU Hotspot                                 65 °C
      GPU2: GPU                                         34 °C
      GPU2: GPU SoC                                     37 °C
      DIMM2                                             30 °C
      Samsung SSD 980 PRO 2TB                           36 °C / 44 °C
      ST4000LM024-2AN17V                                31 °C
    Cooling Fans:
      CPU                                               627 RPM
      Chassis #1                                        1156 RPM
      Chassis #2                                        1186 RPM
      Chassis #3                                        752 RPM
      Water Pump                                        673 RPM
      GPU1: GPU                                         0 RPM  (0%)
      GPU1: GPU2                                        0 RPM  (0%)
    Voltage Values:
      CPU Core                                          1.094 V
      CPU VID                                           0.294 V
      +1.8 V                                            1.802 V
      +3.3 V                                            3.308 V
      +5 V                                              5.030 V
      +12 V                                             12.096 V
      Chipset                                           1.039 V
      SoC                                               1.022 V
      VDDIO                                             1.100 V
      VDD Misc                                          1.092 V
      GPU1: GPU Core                                    0.906 V
      GPU1: GPU PCIe                                    12.116 V
      GPU1: GPU 8-pin                                   12.108 V
      GPU2: GPU Core                                    1.145 V
      GPU2: GPU SoC                                     1.015 V
    Current Values:
      GPU1: GPU PCIe                                    0.19 A
      GPU1: GPU 8-pin                                   1.43 A
      GPU2: GPU SoC                                     7.00 A
    Power Values:
      CPU Package                                       26.53 W
      GPU1: GPU                                         19.65 W
      GPU1: GPU TDP%                                    12%
      GPU1: GPU PCIe                                    2.34 W
      GPU1: GPU 8-pin                                   17.29 W
      GPU2: GPU                                         32.00 W
      GPU2: GPU SoC                                     7.00 W
      Debug Info T                                      00 00 00
      Debug Info V                                      FF FF 00 00 FF FF 01 (00)
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
    B00 D00 F00:  AMD K19.6 - Root Complex
      Offset 000:  22 10 D8 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 010:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  62 14 26 7E
      Offset 030:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  00 00 00 00  00 00 00 00  80 00 00 00  00 00 80 00
      Offset 050:  62 14 26 7E  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  04 2C B3 13  00 00 84 40  00 00 00 00  00 00 00 00
      Offset 070:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  00 00 00 00  08 01 00 00  00 00 00 00  00 00 00 00
      Offset 090:  00 00 00 C0  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  5C A3 06 00  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 00 00  00 00 00 00  00 02 05 00  60 09 05 80
      Offset 0C0:  00 00 00 00  40 0A B1 03  52 03 52 03  00 00 00 00
      Offset 0D0:  00 00 00 00  5C A3 06 00  00 00 00 00  00 00 00 00
      Offset 0E0:  6C A8 05 00  12 0F A6 00  00 00 00 00  00 00 00 00
      Offset 0F0:  00 00 00 00  00 80 80 00  00 00 00 00  5C A3 06 00
    B00 D01 F00:  AMD K19.6 - PCIe Dummy Host Bridge
      Offset 000:  22 10 DA 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  80 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  22 10 DA 14  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 090:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D01 F01:  AMD K19.6 - PCIe GPP Bridge [8:0]
      Offset 000:  22 10 DB 14  07 04 10 00  00 00 04 06  10 00 81 00
      Offset 010:  00 00 00 00  00 00 00 00  00 01 01 00  F1 F1 00 20
      Offset 020:  00 F5 00 F6  01 00 F1 01  F8 00 00 00  FC 00 00 00
      Offset 030:  00 00 00 00  50 00 00 00  00 00 00 00  00 00 00 00
      Offset 040:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  01 58 03 C8  00 00 00 00  10 A0 42 01  22 80 00 00
      Offset 060:  30 29 00 00  05 79 73 00  40 00 02 F1  80 25 04 00
      Offset 070:  00 00 40 01  18 00 01 00  00 00 00 00  FF 19 73 00
      Offset 080:  06 14 00 00  3E 00 80 01  45 00 1F 00  00 00 00 00
      Offset 0A0:  05 C0 81 00  04 00 E0 FE  00 00 00 00  00 00 00 00
      Offset 0C0:  0D C8 00 00  62 14 26 7E  08 00 03 A8  00 00 00 00
      Offset 0E0:  00 00 00 00  5C A3 06 00  00 00 00 00  00 00 00 00
    B00 D01 F02:  AMD K19.6 - PCIe GPP Bridge [8:0]
      Offset 000:  22 10 DB 14  06 04 10 00  00 00 04 06  10 00 81 00
      Offset 010:  00 00 00 00  00 00 00 00  00 02 02 00  F1 01 00 20
      Offset 020:  B0 F6 B0 F6  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 060:  30 21 00 00  45 70 73 00  40 00 44 70  80 25 04 00
      Offset 080:  26 14 00 00  3E 00 80 01  45 00 1F 00  00 00 00 00
    B00 D02 F00:  AMD K19.6 - PCIe Dummy Host Bridge
    B00 D02 F01:  AMD K19.6 - PCIe GPP Bridge [8:0]
      Offset 010:  00 00 00 00  00 00 00 00  00 03 0F 00  E1 E1 00 20
      Offset 020:  60 F6 90 F6  31 20 31 20  FC 00 00 00  FC 00 00 00
      Offset 060:  10 21 00 00  45 F8 72 01  40 00 44 F0  80 25 04 00
      Offset 080:  06 04 00 00  3E 00 80 01  44 00 1F 00  00 00 00 00
    B00 D03 F00:  AMD K19.6 - PCIe Dummy Host Bridge
    B00 D04 F00:  AMD K19.6 - PCIe Dummy Host Bridge
    B00 D08 F00:  AMD K19.6 - PCIe Dummy Host Bridge
    B00 D08 F01:  AMD K19.6 - Internal PCIe GPP Bridge [2:0]
      Offset 000:  22 10 DD 14  07 04 10 00  00 00 04 06  10 00 81 00
      Offset 010:  00 00 00 00  00 00 00 00  00 10 10 00  D1 D1 00 00
      Offset 020:  20 F6 50 F6  01 10 11 20  FC 00 00 00  FC 00 00 00
      Offset 030:  00 00 00 00  50 00 00 00  00 00 00 00  00 01 00 00
      Offset 050:  01 58 03 C8  00 00 00 00  10 A0 42 00  22 80 00 00
      Offset 060:  30 21 00 00  04 0D 70 00  41 00 04 71  00 00 00 00
      Offset 070:  00 00 40 00  18 00 01 00  00 00 00 00  40 00 31 00
      Offset 080:  00 00 00 00  1E 00 80 01  44 00 1F 00  00 00 00 00
      Offset 0C0:  0D 00 00 00  26 7E 62 14  00 00 00 00  00 00 00 00
    B00 D08 F03:  AMD K19.6 - Internal PCIe GPP Bridge [2:0]
      Offset 000:  22 10 DD 14  06 04 10 00  00 00 04 06  10 00 81 00
      Offset 010:  00 00 00 00  00 00 00 00  00 11 11 00  F1 01 00 00
      Offset 020:  A0 F6 A0 F6  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 070:  00 00 40 00  18 00 01 00  00 00 00 00  00 00 01 00
    B00 D14 F00:  AMD K19.6 FCH - SMBus Controller
      Offset 000:  22 10 0B 79  03 04 20 02  71 00 05 0C  00 00 80 00
      Offset 050:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0F0:  DA DB 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D14 F03:  AMD K19.6 FCH - LPC Bridge
      Offset 000:  22 10 0E 79  0F 00 20 02  51 00 01 06  00 00 80 00
      Offset 040:  1C 00 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 050:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 060:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 070:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 080:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 090:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0A0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0B0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0C0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0D0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0E0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 0F0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
    B00 D18 F00:  AMD K19.6 - Data Fabric: Device 18h; Function 0
      Offset 000:  22 10 E0 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 040:  10 00 01 04  77 12 95 03  0F 0F 0F 0F  0F 00 00 00
      Offset 050:  0F 0F 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 090:  01 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B00 D18 F01:  AMD K19.6 - Data Fabric: Device 18h; Function 1
      Offset 000:  22 10 E1 14  00 00 00 00  00 00 00 06  00 00 80 00
    B00 D18 F02:  AMD K19.6 - Data Fabric: Device 18h; Function 2
      Offset 000:  22 10 E2 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 040:  00 00 90 08  1A 00 20 F0  F0 89 01 80  88 40 0B C2
      Offset 050:  00 00 71 01  01 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 00 00 00  10 B4 0F 00  3F 00 00 80  00 00 00 00
      Offset 070:  0F 00 CF 08  18 2B 65 01  00 00 00 00  00 00 00 00
      Offset 0B0:  00 00 00 00  19 06 06 14  18 50 06 00  00 00 00 00
    B00 D18 F03:  AMD K19.6 - Data Fabric: Device 18h; Function 3
      Offset 000:  22 10 E3 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 040:  10 01 00 00  00 65 06 60  00 00 00 00  00 00 00 00
    B00 D18 F04:  AMD K19.6 - Data Fabric: Device 18h; Function 4
      Offset 000:  22 10 E4 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 040:  02 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  9D 3E 09 00  43 0D 02 00  00 00 00 00  07 3F 09 00
      Offset 090:  00 00 00 00  85 00 0A 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 00 00 00  18 18 10 00  18 18 10 00
      Offset 0B0:  22 10 E0 14  22 10 E0 14  00 00 00 00  00 00 00 00
      Offset 0C0:  22 10 E0 14  22 10 E0 14  00 00 00 00  00 00 00 00
    B00 D18 F05:  AMD K19.6 - Data Fabric: Device 18h; Function 5
      Offset 000:  22 10 E5 14  00 00 00 00  00 00 00 06  00 00 80 00
      Offset 090:  00 00 00 00  01 00 00 00  01 00 00 00  01 00 00 00
    B00 D18 F06:  AMD K19.6 - Data Fabric: Device 18h; Function 6
      Offset 000:  22 10 E6 14  00 00 00 00  00 00 00 06  00 00 80 00
    B00 D18 F07:  AMD K19.6 - Data Fabric: Device 18h; Function 7
      Offset 000:  22 10 E7 14  00 00 00 00  00 00 00 06  00 00 80 00
    B01 D00 F00:  MSI RTX 3060 Ventus 2X OC LHR (MS-V397) Video Adapter
      Offset 000:  DE 10 04 25  07 04 10 00  A1 00 00 03  10 00 80 00
      Offset 010:  00 00 00 F5  0C 00 00 00  F8 00 00 00  0C 00 00 00
      Offset 020:  FC 00 00 00  01 F0 00 00  00 00 00 00  62 14 7D 39
      Offset 030:  00 00 00 00  60 00 00 00  00 00 00 00  00 01 00 00
      Offset 040:  62 14 7D 39  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  00 00 00 00  01 00 00 00  CE D6 23 00  00 00 00 00
      Offset 060:  01 68 03 48  08 00 00 00  05 78 81 00  04 00 E0 FE
      Offset 070:  00 00 00 00  00 00 00 00  10 B4 12 00  E1 8D 2C 11
      Offset 080:  37 29 09 00  04 3D 45 00  40 00 02 11  00 00 00 00
      Offset 090:  00 00 00 00  00 00 00 00  00 00 00 00  13 08 07 00
      Offset 0A0:  00 14 00 00  1E 00 80 01  04 00 1F 00  00 00 00 00
      Offset 0B0:  00 00 00 00  09 00 14 01  00 00 00 00  00 00 00 00
      Offset 0C0:  00 00 00 00  00 00 00 00  11 00 05 00  00 00 B9 00
      Offset 0D0:  00 00 BA 00  00 00 00 00  00 00 00 00  00 00 00 00
    B01 D00 F01:  nVIDIA GA106 - High Definition Audio Controller
      Offset 000:  DE 10 8E 22  06 00 10 00  A1 00 03 04  10 00 80 00
      Offset 010:  00 C0 0F F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  62 14 7D 39
      Offset 030:  00 00 00 00  60 00 00 00  00 00 00 00  19 02 00 00
      Offset 050:  00 00 00 00  00 00 00 00  CE D6 23 00  00 00 00 00
      Offset 060:  01 68 03 00  08 00 00 00  05 78 80 00  00 00 00 00
      Offset 070:  00 00 00 00  00 00 00 00  10 00 02 00  E1 8D 2C 01
      Offset 080:  37 21 09 00  04 3D 45 00  40 00 02 11  00 00 00 00
      Offset 0A0:  00 10 00 00  1E 00 80 01  00 00 01 00  00 00 00 00
    B02 D00 F00:  Samsung NVMe SSD Controller
      Offset 000:  4D 14 0A A8  06 04 10 00  00 02 08 01  10 00 00 00
      Offset 010:  04 00 B0 F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  4D 14 01 A8
      Offset 030:  00 00 00 00  40 00 00 00  00 00 00 00  00 01 00 00
      Offset 040:  01 50 03 00  08 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  05 70 8A 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  10 B0 02 00  E1 8F 2C 11  37 21 09 00  44 78 47 00
      Offset 080:  40 00 44 10  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 090:  00 00 00 00  1F 08 01 00  00 04 00 00  1E 00 80 01
      Offset 0A0:  04 00 1F 01  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  11 00 81 80  00 30 00 00  00 20 00 00  00 00 00 00
      Offset 0D0:  03 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B03 D00 F00:  AMD 600-Series Chipset - Switch Upstream Port
      Offset 000:  22 10 F4 43  07 04 10 00  01 00 04 06  10 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  03 04 0F 00  E1 E1 00 00
      Offset 030:  00 00 00 00  50 00 00 00  00 00 00 00  FF 01 00 00
      Offset 040:  04 00 C4 FE  00 00 00 00  01 00 00 00  00 00 00 00
      Offset 050:  05 70 80 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  01 80 23 C8  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  10 C0 52 00  22 80 2C 01  17 21 09 00  44 E8 42 00
      Offset 090:  40 00 44 10  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 08 01 00  00 04 00 00  1E 1E 8F 01
      Offset 0B0:  04 00 1F 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  0D 00 00 00  21 1B 28 33  00 00 00 00  00 00 00 00
      Offset 0E0:  5E BF 63 AB  5D 7A 33 2E  3D F9 A6 04  2E F3 E0 3E
      Offset 0F0:  9A A4 9A F6  D1 DC 58 2A  52 CD D9 06  03 7F DA F1
    B04 D00 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 000:  22 10 F5 43  04 04 10 00  01 00 04 06  10 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  04 05 05 00  F1 01 00 00
      Offset 020:  F0 FF 00 00  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  44 E8 7A 00
      Offset 090:  00 00 11 10  00 0D 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 08 01 00  00 00 00 00  1E 1E 8F 01
      Offset 0B0:  04 00 01 00  00 00 00 00  00 00 00 00  00 00 00 00
    B04 D04 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 06 06 00  F1 01 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  13 E8 7A 00
      Offset 0A0:  00 00 00 00  00 08 01 00  00 00 00 00  0E 0E 87 01
    B04 D05 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 07 07 00  F1 01 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  13 E8 7A 01
    B04 D06 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 08 08 00  F1 01 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  13 E8 7A 02
    B04 D07 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 09 09 00  F1 01 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  13 E8 7A 03
    B04 D08 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 0A 0A 00  F1 01 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  14 E8 7A 00
      Offset 090:  00 00 11 50  00 0D 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  03 00 01 00  00 00 00 00  00 00 00 00  00 00 00 00
    B04 D09 F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 0B 0B 00  F1 01 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 09 00  14 E8 7A 01
    B04 D0A F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 000:  22 10 F5 43  07 04 10 00  01 00 04 06  10 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  04 0C 0C 00  E1 E1 00 00
      Offset 020:  90 F6 90 F6  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 00 00  14 E8 7A 02
      Offset 090:  40 00 12 70  00 0D 00 00  00 00 48 01  00 00 00 00
      Offset 0B0:  04 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B04 D0B F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 000:  22 10 F5 43  06 04 10 00  01 00 04 06  10 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  04 0D 0D 00  F1 01 00 00
      Offset 020:  80 F6 80 F6  31 20 31 20  FC 00 00 00  FC 00 00 00
      Offset 080:  10 C0 62 01  22 80 00 00  17 21 00 00  14 E8 7A 03
      Offset 090:  40 00 12 F0  00 0D 00 00  00 00 48 01  00 00 00 00
    B04 D0C F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 010:  00 00 00 00  00 00 00 00  04 0E 0E 00  F0 00 00 00
      Offset 020:  70 F6 70 F6  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 070:  01 80 23 C8  08 00 00 00  00 00 00 00  00 00 00 00
      Offset 080:  10 C0 62 00  22 80 00 00  17 21 00 00  11 0C 40 0C
      Offset 090:  40 00 11 10  00 00 00 00  00 00 40 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 08 01 00  00 04 00 00  02 02 00 00
      Offset 0B0:  01 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    B04 D0D F00:  AMD 600-Series Chipset - GPP-Switch Downstream Port
      Offset 000:  22 10 F5 43  00 04 10 00  01 00 04 06  10 00 01 00
      Offset 010:  00 00 00 00  00 00 00 00  04 0F 0F 00  F0 00 00 00
      Offset 020:  60 F6 60 F6  F1 FF 01 00  00 00 00 00  00 00 00 00
      Offset 070:  01 80 23 C8  0B 01 00 00  00 00 00 00  00 00 00 00
      Offset 080:  10 C0 62 00  22 80 00 00  17 21 00 00  11 0C 40 0D
    B0C D00 F00:  Realtek RTL8125 Gaming 2.5GbE Family Ethernet Controller
      Offset 000:  EC 10 25 81  07 04 10 00  05 00 00 02  10 00 00 00
      Offset 010:  01 EF 00 00  00 00 00 00  04 00 9F F6  00 00 00 00
      Offset 020:  04 C0 9E F6  00 00 00 00  00 00 00 00  62 14 26 7E
      Offset 040:  01 50 C3 FF  08 01 00 00  00 00 00 00  00 00 00 00
      Offset 050:  05 70 80 01  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 070:  10 B0 02 02  C1 8C 68 00  17 40 10 00  12 7C 47 00
      Offset 080:  40 00 12 10  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 090:  00 00 00 00  1F 18 0C 00  00 04 00 00  06 00 00 00
      Offset 0A0:  02 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0B0:  11 D0 1F 80  04 00 00 00  04 08 00 00  00 00 00 00
    B0D D00 F00:  MediaTek MT7922 (RZ616) Wi-Fi 6E 160MHz Wireless Network Adapter
      Offset 000:  C3 14 16 06  06 04 10 00  00 00 80 02  10 00 00 00
      Offset 010:  0C 00 30 20  FC 00 00 00  04 80 8F F6  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  C3 14 16 06
      Offset 030:  00 00 00 00  80 00 00 00  00 00 00 00  00 01 00 00
      Offset 080:  10 E0 02 00  E0 8F 68 10  07 21 00 00  12 DC 41 01
      Offset 090:  40 00 12 10  00 00 00 00  00 00 00 00  00 00 01 00
      Offset 0A0:  00 00 00 00  1F 08 10 00  00 04 00 00  06 00 00 00
      Offset 0B0:  02 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0E0:  05 F8 8B 01  04 00 E0 FE  00 00 00 00  00 00 00 00
      Offset 0F0:  FE FF FF FF  00 00 00 00  01 00 03 C8  08 00 00 00
    B0E D00 F00:  AMD 600-Series Chipset - USB 3.1 xHCI Controller
      Offset 000:  22 10 F7 43  06 04 10 00  01 30 03 0C  10 00 00 00
      Offset 010:  04 00 70 F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  21 1B 42 11
      Offset 050:  05 68 86 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  32 40 00 00  00 00 00 00  11 78 07 80  00 20 00 00
      Offset 070:  80 20 00 00  00 00 00 00  01 80 63 C8  08 80 00 00
      Offset 080:  10 00 12 00  22 80 00 00  17 21 00 00  11 6C 43 00
      Offset 090:  40 00 11 10  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 08 01 00  00 04 00 00  02 02 81 01
      Offset 0B0:  01 00 01 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0E0:  00 00 00 00  85 00 01 A0  00 00 00 00  00 00 00 00
    B0F D00 F00:  AMD 600-Series Chipset - SATA AHCI Controller
      Offset 000:  22 10 F6 43  00 04 10 00  01 01 06 01  10 00 00 00
      Offset 020:  00 00 00 00  00 00 68 F6  00 00 00 00  21 1B 62 10
      Offset 050:  05 70 80 00  04 00 E0 FE  00 00 00 00  00 00 00 00
      Offset 070:  01 80 63 C8  0B 01 00 00  00 00 00 00  00 00 00 00
      Offset 0A0:  00 00 00 00  00 00 01 00  00 00 00 00  02 02 81 01
    B10 D00 F00:  AMD Raphael Video Adapter
      Offset 000:  02 10 4E 16  06 04 10 00  CB 00 00 03  10 00 80 00
      Offset 010:  0C 00 00 10  FC 00 00 00  0C 00 00 20  FC 00 00 00
      Offset 020:  01 DF 00 00  00 00 50 F6  00 00 00 00  62 14 26 7E
      Offset 030:  00 00 00 00  48 00 00 00  00 00 00 00  00 01 00 00
      Offset 040:  00 00 00 00  00 00 00 00  09 50 08 00  62 14 26 7E
      Offset 050:  01 64 03 F0  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 00 00 00  10 A0 12 00  A1 8F 00 00  30 29 0A 00
      Offset 070:  04 0D 40 00  41 00 04 11  00 00 00 00  00 00 00 00
      Offset 080:  00 00 00 00  00 00 00 00  9F 01 71 00  40 00 00 00
      Offset 090:  1E 00 80 01  04 00 1F 00  00 00 00 00  00 00 00 00
      Offset 0A0:  05 C0 84 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  11 00 03 80  05 20 04 00  05 30 04 00  00 00 00 00
    B10 D00 F01:  AMD K19.6 - Display High Definition Audio Controller
      Offset 000:  02 10 40 16  00 04 10 00  00 00 03 04  10 00 80 00
      Offset 010:  00 80 5F F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  48 00 00 00  00 00 00 00  2B 02 00 00
      Offset 050:  01 64 03 F0  03 01 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 00 00 00  10 A0 12 00  A1 8F 00 00  30 21 0A 00
      Offset 080:  00 00 00 00  00 00 00 00  1F 00 71 00  40 00 00 00
      Offset 090:  1E 00 80 01  00 00 01 00  00 00 00 00  00 00 00 00
      Offset 0A0:  05 00 80 00  00 00 00 00  00 00 00 00  00 00 00 00
    B10 D00 F02:  AMD K19.6 - Cryptographic Coprocessor (PSP/CCP)
      Offset 000:  22 10 49 16  00 04 10 00  00 00 80 10  10 00 80 00
      Offset 010:  00 00 00 00  00 00 00 00  00 00 40 F6  00 00 00 00
      Offset 020:  00 00 00 00  00 E0 5F F6  00 00 00 00  62 14 26 7E
      Offset 030:  00 00 00 00  48 00 00 00  00 00 00 00  00 03 00 00
      Offset 050:  01 64 03 00  0B 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  00 00 00 00  10 A0 02 00  A1 8F 00 00  30 21 0A 00
      Offset 080:  00 00 00 00  00 00 00 00  1F 00 71 00  00 00 00 00
      Offset 0A0:  05 C0 82 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  11 00 01 00  05 00 00 00  05 10 00 00  00 00 00 00
    B10 D00 F03:  AMD K19.6 - USB 3.1 xHCI Controller 0
      Offset 000:  22 10 B6 15  00 04 10 00  00 30 03 0C  10 00 80 00
      Offset 010:  04 00 30 F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 030:  00 00 00 00  48 00 00 00  00 00 00 00  00 04 00 00
      Offset 050:  01 64 03 C8  03 01 00 00  00 00 00 00  00 00 00 00
      Offset 060:  31 60 00 00  10 A0 02 00  A1 8F 00 00  30 21 0A 00
      Offset 0A0:  05 C0 86 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  11 00 07 00  00 E0 0F 00  00 F0 0F 00  00 00 00 00
    B10 D00 F04:  AMD K19.6 - USB 3.1 xHCI Controller 1
      Offset 000:  22 10 B7 15  06 04 10 00  00 30 03 0C  10 00 80 00
      Offset 010:  04 00 20 F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 050:  01 64 03 C8  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0C0:  11 00 07 80  00 E0 0F 00  00 F0 0F 00  00 00 00 00
    B10 D00 F06:  AMD K19.6 - Audio Processor - High Definition Audio Controller (Standalone AZ)
      Offset 000:  22 10 E3 15  06 00 10 00  00 00 03 04  10 00 80 00
      Offset 010:  00 00 5F F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 020:  00 00 00 00  00 00 00 00  00 00 00 00  62 14 26 EE
      Offset 030:  00 00 00 00  48 00 00 00  00 00 00 00  28 03 00 00
      Offset 040:  00 00 00 00  00 00 00 00  09 50 08 00  62 14 26 EE
      Offset 050:  01 64 03 C8  08 00 00 00  00 00 00 00  00 00 00 00
    B11 D00 F00:  AMD K19.6 - USB2 (USB Secure Biometric)
      Offset 000:  22 10 B8 15  00 04 10 00  00 30 03 0C  10 00 00 00
      Offset 010:  04 00 A0 F6  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 060:  31 60 00 00  10 A0 02 00  A1 8F 00 00  30 21 00 00
      Offset 080:  00 00 00 00  00 00 00 00  1F 00 01 00  00 00 00 00
    PCI-1022-14D8:  AMD K17/K18/K19/K1A SMUTHM NBSMNIND
      Offset 00059800:  00 00 7B 60  01 12 7F 01  21 29 01 00  00 00 00 00
      Offset 00059810:  F9 00 00 80  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059820:  00 00 00 00  00 00 00 00  00 00 00 00  78 00 FF 0F
      Offset 00059830:  00 00 00 00  DA 6C 2A 00  D0 2C 29 00  D5 CC 29 00
      Offset 00059840:  D7 0C 2A 00  DC AC 2A 00  DA 6C 2A 00  D3 8C 29 00
      Offset 00059850:  D4 AC 29 00  D4 AC 29 00  CE EC 28 00  00 00 00 00
      Offset 00059860:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059870:  00 00 00 00  D2 6C 29 00  D1 4C 29 00  D2 6C 29 00
      Offset 00059880:  D1 4C 29 00  D1 4C 29 00  D3 8C 29 00  D8 2C 2A 00
      Offset 00059890:  D6 EC 29 00  D6 EC 29 00  00 00 00 00  00 00 00 00
      Offset 000598A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000598B0:  00 00 00 00  00 00 00 00  00 21 00 00  FF 03 FF 01
      Offset 000598C0:  00 00 00 00  D9 AC 2A 00  D0 8C 29 00  D7 6C 2A 00
      Offset 000598D0:  DB EC 2A 00  DE 2C 2B 00  D8 8C 2A 00  D2 CC 29 00
      Offset 000598E0:  CF 6C 29 00  D4 0C 2A 00  E0 6C 2B 00  00 00 00 00
      Offset 000598F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059900:  00 00 00 00  D3 EC 29 00  D1 AC 29 00  D2 CC 29 00
      Offset 00059910:  D0 8C 29 00  D0 8C 29 00  CF 6C 29 00  D1 AC 29 00
      Offset 00059920:  D5 2C 2A 00  D0 8C 29 00  D2 CC 29 00  00 00 00 00
      Offset 00059930:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059940:  00 00 00 00  00 00 00 00  00 21 00 00  FF 03 FF 03
      Offset 00059950:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059960:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059970:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059980:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059990:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000599A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000599B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000599C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000599D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000599E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000599F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A00:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A10:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A20:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A30:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A40:  00 00 00 00  00 00 00 00  01 00 40 08  25 4A 00 00
      Offset 00059A50:  27 00 00 00  05 00 80 A7  0E 68 18 31  00 00 00 00
      Offset 00059A60:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A70:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A80:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059A90:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059AA0:  60 00 00 00  B4 02 00 00  29 00 00 00  8E 02 00 00
      Offset 00059AB0:  11 00 00 00  00 00 00 00  00 00 00 00  A6 02 00 00
      Offset 00059AC0:  05 00 00 00  B4 02 00 00  29 00 00 00  01 00 00 00
      Offset 00059AD0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059AE0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059AF0:  00 00 00 00  00 00 00 00  05 00 01 00  00 00 00 00
      Offset 00059B00:  DD 00 00 80  00 00 00 00  CC 0A 00 00  00 00 00 00
      Offset 00059B10:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059B20:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00059B30:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    PCI-1022-14D8:  AMD K17/K18/K19/K1A SMUSVI NBSMNIND
      Offset 0005A000:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005A010:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005A020:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
    PCI-1022-14D8:  AMD K17/K18/K19/K1A SMUFUSE NBSMNIND
      Offset 0005D200:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D210:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D220:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D230:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D240:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D250:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D260:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D270:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D280:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D290:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D2A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D2B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D2C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D2D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D2E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D2F0:  00 00 00 00  00 00 00 00  DE F2 16 00  2A 6A DC 63
      Offset 0005D300:  4C B9 88 95  00 00 00 00  C2 05 04 00  00 00 00 00
      Offset 0005D310:  68 00 00 00  00 00 00 00  99 09 00 14  99 99 CB 15
      Offset 0005D320:  00 00 00 00  C9 18 00 00  24 00 00 09  39 FA 0E 12
      Offset 0005D330:  30 12 89 08  98 40 60 30  30 21 0C 06  93 C9 20 C3
      Offset 0005D340:  02 00 80 01  00 40 48 00  E8 EA 18 08  00 00 00 00
      Offset 0005D350:  C9 18 00 00  24 00 00 09  39 FA 0E 0C  18 0C 0C 03
      Offset 0005D360:  18 02 81 40  42 20 50 A8  84 C1 20 19  01 00 78 00
      Offset 0005D370:  00 48 C8 01  E8 3B 30 18  00 40 32 00  03 00 78 00
      Offset 0005D380:  00 48 C8 01  E8 3B 30 00  00 40 18 00  03 00 C8 00
      Offset 0005D390:  00 C0 C9 00  E8 3B 30 00  00 00 00 00  00 00 00 00
      Offset 0005D3A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D3B0:  00 00 00 00  00 00 80 8A  1A F7 18 53  2E 62 65 02
      Offset 0005D3C0:  40 00 40 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D3D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D3E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D3F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 30 00 00
      Offset 0005D400:  00 00 00 00  60 02 C0 83  00 00 00 00  27 28 93 15
      Offset 0005D410:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D420:  00 00 C0 86  58 BE 08 00  00 00 00 00  00 00 00 00
      Offset 0005D430:  00 00 00 00  00 00 00 00  00 00 10 97  00 00 00 00
      Offset 0005D440:  00 00 00 50  8A EA 09 00  00 00 00 00  00 00 00 00
      Offset 0005D450:  00 00 00 00  00 70 B6 A9  09 00 00 00  00 00 00 00
      Offset 0005D460:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D470:  C0 26 66 36  06 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D480:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D490:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 0005D4A0:  00 00 00 00  00 00 00 00  00 88 84 00  00 78 02 80
      Offset 0005D4B0:  03 0E 09 C2  3C 00 00 00  00 00 00 00  80 00 00 00
      Offset 0005D4C0:  00 00 00 00  00 00 00 00  00 00 00 00  A8 78 00 00
      Offset 0005D4D0:  08 02 00 C9  79 6F 6F 03  00 00 00 C9  C1 60 90 18
      Offset 0005D4E0:  0C 06 11 83  C1 90 18 0C  06 CC E1 70  60 1C 0E 07
      Offset 0005D4F0:  11 83 C1 60  18 0C 06 86  C1 60 6C D1  E3 C8 11 2A
      Offset 0005D500:  56 40 91 44  59 5B F4 FC  39 74 E9 17  2A 00 40 E1
      Offset 0005D510:  40 14 C6 6D  29 D3 26 10  A7 5F 66 66  A6 0A 82 1E
      Offset 0005D520:  80 10 06 08  61 30 00 82  1E 00 24 E9  01 08 61 80
      Offset 0005D530:  10 06 03 24  E9 01 40 92  1E 80 10 06  C6 60 30 E0
      Offset 0005D540:  79 1E 00 2C  EB 01 4A 61  80 10 06 03  2C EB 01 40
      Offset 0005D550:  92 1E 80 10  06 C6 60 30  40 92 1E 00  34 ED 01 8C
      Offset 0005D560:  61 80 10 06  03 34 ED 01  30 D2 1E 80  18 06 0A 61
      Offset 0005D570:  20 30 D2 1E  00 00 59 51  00 C0 03 0F  3C 68 01 00
      Offset 0005D580:  0F 00 22 00  40 00 50 86  00 00 10 05  00 00 00 00
      Offset 0005D590:  00 60 30 7D  E9 92 A2 58  C0 44 14 76  01 2C D4 43
      Offset 0005D5A0:  D3 52 58 32  85 0B A8 4B  82 D9 DF 61  09 0B 02 40
      Offset 0005D5B0:  CB 96 5F 98  E9 0A 95 F3  1F 20 00 00  00 20 00 00
      Offset 0005D5C0:  00 20 00 00  00 20 00 00  00 20 00 00  00 20 00 00
      Offset 0005D5D0:  00 20 00 00  00 20 00 00  00 20 80 F3  1F 20 80 F3
      Offset 0005D5E0:  1F 20 00 00  00 20 00 00  00 20 80 F3  1F 20 00 00
      Offset 0005D5F0:  00 20 00 00  00 20 00 00  00 20 80 F3  1F 20 00 00
    PCI-1022-14D8:  AMD K17/K18/K19/K1A CH0 NBSMNIND
      Offset 00050000:  00 00 00 00  00 00 00 00  01 00 00 00  01 04 00 00
      Offset 00050010:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050020:  00 00 00 00  00 00 00 00  FE FB FF 07  FE FB FF 07
      Offset 00050030:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050040:  08 05 15 00  08 05 15 00  0C 06 25 00  0C 06 25 00
      Offset 00050050:  98 BA 0C 07  98 BA 0C 07  65 43 07 07  65 43 07 07
      Offset 00050060:  21 43 65 87  43 65 87 A9  21 43 65 87  43 65 87 A9
      Offset 00050070:  10 32 B5 DC  98 60 87 A9  10 32 B5 DC  98 60 87 A9
      Offset 00050080:  00 00 00 00  00 00 00 00  00 00 01 00  00 00 01 00
      Offset 00050090:  00 00 00 00  00 00 00 00  01 40 08 21  01 80 10 02
      Offset 000500A0:  01 00 21 04  01 00 42 08  01 00 84 10  00 00 00 00
      Offset 000500B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000500C0:  01 C0 FF 3F  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000500D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000500E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000500F0:  00 00 00 00  00 00 00 00  04 00 08 00  00 00 04 08
      Offset 00050100:  01 07 00 80  83 00 80 C0  12 3F 04 C0  98 00 00 06
      Offset 00050110:  2C 81 C0 00  00 20 01 20  47 00 00 00  08 00 00 00
      Offset 00050120:  00 00 00 00  0B 48 80 31  03 00 00 00  48 11 38 15
      Offset 00050130:  00 00 00 00  00 00 00 00  FF FF 08 07  00 00 00 00
      Offset 00050140:  00 00 00 00  FF FF FF FF  FF FF FF FF  00 40 00 00
      Offset 00050150:  00 7E 00 00  00 00 00 00  00 82 10 00  00 00 00 00
      Offset 00050160:  00 00 0A 00  00 00 00 00  00 20 00 20  00 00 00 00
      Offset 00050170:  00 00 00 00  04 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050180:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050190:  00 00 00 00  00 00 00 00  6D 0F 01 1B  00 00 00 00
      Offset 000501A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000501B0:  00 00 00 00  00 00 00 00  08 08 00 00  04 04 00 00
      Offset 000501C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 000501D0:  00 00 00 00  04 00 00 00  00 00 00 00  00 00 00 00
      Offset 000501E0:  43 61 00 00  10 00 11 01  00 00 00 00  00 00 00 00
      Offset 000501F0:  04 20 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050200:  60 09 05 80  28 4D 28 28  75 00 28 00  08 0C 00 12
      Offset 00050210:  20 00 00 00  26 06 18 00  48 00 00 00  02 00 00 00
      Offset 00050220:  09 09 01 05  0C 0C 01 11  07 13 00 00  48 2B 31 00
      Offset 00050230:  83 24 30 00  22 22 20 20  DC 02 00 06  00 20 00 24
      Offset 00050240:  01 0C 22 03  12 FF 60 FE  C5 20 10 00  01 01 00 00
      Offset 00050250:  00 00 07 00  12 0D 0C 00  1C 1A 22 06  2A 2A 00 22
      Offset 00050260:  38 01 C0 00  38 01 C0 00  C4 02 80 01  C4 02 80 01
      Offset 00050270:  00 00 00 00  03 00 00 00  00 00 00 40  00 00 00 40
      Offset 00050280:  00 00 00 00  20 01 00 00  94 03 00 00  80 29 00 18
      Offset 00050D00:  00 00 00 02  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050D10:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050D20:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050D30:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050D40:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050D50:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00050D60:  FF FF FF FF  FF FF FF FF  FF FF FF FF  78 08 00 0B
      Offset 00050D70:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050D80:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050D90:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050DA0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050DB0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050DC0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050DD0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050DE0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00050DF0:  08 FD 01 00  00 00 00 00  FF FF FF FF  FF FF FF FF
    PCI-1022-14D8:  AMD K17/K18/K19/K1A CH1 NBSMNIND
      Offset 00150000:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150010:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150020:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150030:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150040:  08 05 15 00  08 05 15 00  08 05 15 00  08 05 15 00
      Offset 00150050:  98 BA 0C 07  98 BA 0C 07  98 BA 0C 07  98 BA 0C 07
      Offset 00150060:  21 43 65 87  43 65 87 A9  21 43 65 87  43 65 87 A9
      Offset 00150070:  21 43 65 87  43 65 87 A9  21 43 65 87  43 65 87 A9
      Offset 00150080:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150090:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001500A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001500B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001500C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001500D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001500E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001500F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150100:  00 02 00 00  88 00 40 30  12 10 0C 40  30 00 00 00
      Offset 00150110:  00 00 00 00  00 20 18 18  47 00 00 00  00 00 00 00
      Offset 00150120:  00 00 00 00  0B 40 80 10  01 00 00 00  61 0C 18 51
      Offset 00150130:  00 00 00 00  00 00 00 00  60 40 20 07  00 00 00 00
      Offset 00150140:  00 00 00 00  FF FF FF FF  FF FF FF FF  00 40 00 00
      Offset 00150150:  00 7E 00 00  00 00 00 00  00 82 10 00  00 00 00 00
      Offset 00150160:  00 00 0A 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150170:  00 00 00 00  04 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150180:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150190:  00 00 00 00  00 00 00 00  20 08 04 20  00 00 00 00
      Offset 001501A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001501B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001501C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 001501D0:  00 00 00 00  01 00 00 00  00 00 00 00  00 00 00 00
      Offset 001501E0:  42 61 00 00  10 00 11 01  00 00 00 00  00 00 00 00
      Offset 001501F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150200:  00 00 01 80  12 27 12 12  39 00 12 00  04 04 00 09
      Offset 00150210:  1A 00 00 00  0C 03 03 00  12 00 00 00  04 00 00 00
      Offset 00150220:  01 01 01 01  01 01 01 01  01 05 00 00  80 40 00 00
      Offset 00150230:  90 24 00 00  08 18 20 20  44 01 00 03  24 20 00 24
      Offset 00150240:  01 08 08 03  06 FF C0 FC  AC 0D 10 00  01 01 00 00
      Offset 00150250:  00 00 07 00  08 02 04 06  20 04 04 00  2A 2A 00 22
      Offset 00150260:  38 01 C0 00  38 01 C0 00  38 01 C0 00  38 01 C0 00
      Offset 00150270:  00 00 00 00  03 00 00 00  00 00 00 40  00 00 00 40
      Offset 00150280:  00 00 00 00  00 00 00 00  52 05 00 00  80 29 00 18
      Offset 00150D00:  00 00 00 02  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150D10:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150D20:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150D30:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150D40:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150D50:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      Offset 00150D60:  FF FF FF FF  FF FF FF FF  FF FF FF FF  C8 08 00 0A
      Offset 00150D70:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150D80:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150D90:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150DA0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150DB0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150DC0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150DD0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150DE0:  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      Offset 00150DF0:  08 FD 01 00  00 00 00 00  FF FF FF FF  FF FF FF FF
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
    C000:0000  ................................................................
    C000:0040  ................................................................
    C000:0080  ................................................................
    C000:00C0  ................................................................
    C000:0100  ................................................................
    C000:0140  ................................................................
    C000:0180  ................................................................
    C000:01C0  ................................................................
    C000:0200  ................................................................
    C000:0240  ................................................................
    C000:0280  ................................................................
    C000:02C0  ................................................................
    C000:0300  ................................................................
    C000:0340  ................................................................
    C000:0380  ................................................................
    C000:03C0  ................................................................
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
    HDD             Seagate Expansion SCSI Disk Device
    Monitor ID      ACR0A33: Generic Monitor (KG241Y S) [NoDB]
    Monitor Model   KG241Y S
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
  • Fiery changed the title to Missig 4th Chassis Fan (MSI MS-7E26)
In AIDA64 please press Ctrl+Alt+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Quote
Sensor Properties
Temperatures
Motherboard    36 °C
CPU    55 °C
CPU Diode    56 °C
CCD #1    36 °C
Chipset    36 °C
PCH Diode    43 °C
MOS    37 °C
GPU1: GPU    48 °C
GPU1: GPU Hotspot    59 °C
GPU2: GPU    37 °C
GPU2: GPU SoC    40 °C
DIMM2    34 °C
DIMM4    34 °C
Samsung SSD 980 PRO 2TB    37 °C / 45 °C
ST5000LM000-2U8170    33 °C
Cooling Fans
CPU    760 RPM
Chassis #1    1146 RPM
Chassis #2    1169 RPM
Chassis #3    764 RPM
Water Pump    765 RPM
Voltage Values
CPU Core    1.150 V
CPU VID    0.794 V
+1.8 V    1.802 V
+3.3 V    3.308 V
+5 V    5.030 V
+12 V    12.072 V
Chipset    1.039 V
SoC    1.022 V
VDDIO    1.100 V
VDD Misc    1.092 V
GPU1: GPU Core    0.650 V
GPU1: GPU PCIe    12.108 V
GPU1: GPU 8-pin    12.111 V
GPU2: GPU Core    1.130 V
Current Values
GPU1: GPU PCIe    0.22 A
GPU1: GPU 8-pin    1.49 A
Power Values
CPU Package    30.53 W
GPU1: GPU    20.76 W
GPU1: GPU TDP%    12%
GPU1: GPU PCIe    2.68 W
GPU1: GPU 8-pin    18.07 W
GPU2: GPU    22.00 W
Motherboard ID      : <DMI>
Motherboard Model   : MSI B650 Gaming Plus WiFi (MS-7E26)
Motherboard Chipset : AMD B650, AMD K19.6 FCH, AMD K19.6 IMC
DMI MB Manufacturer : Micro-Star International Co., Ltd.
DMI MB Product      : B650 GAMING PLUS WIFI (MS-7E26)
DMI MB Version      : 1.0
DMI MB Serial       : 07E2610_O11E170664
DMI SYS Manufacturer: Micro-Star International Co., Ltd.
DMI SYS Product     : MS-7E26
DMI SYS Version     : 1.0
DMI SYS Serial      : To be filled by O.E.M.
DMI BIOS Version    : 1.D0
------[ PCI Devices ]------
B00-D00-F00 [1022-14D8] [1462-7E26] [CC0600]: AMD K19.6 - Root Complex
B00-D01-F00 [1022-14DA] [0000-0000] [CC0600]: AMD K19.6 - PCIe Dummy Host Bridge
B00-D02-F00 [1022-14DA] [0000-0000] [CC0600]: AMD K19.6 - PCIe Dummy Host Bridge
B00-D03-F00 [1022-14DA] [0000-0000] [CC0600]: AMD K19.6 - PCIe Dummy Host Bridge
B00-D04-F00 [1022-14DA] [0000-0000] [CC0600]: AMD K19.6 - PCIe Dummy Host Bridge
B00-D08-F00 [1022-14DA] [0000-0000] [CC0600]: AMD K19.6 - PCIe Dummy Host Bridge
B00-D18-F00 [1022-14E0] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 0
B00-D18-F01 [1022-14E1] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 1
B00-D18-F02 [1022-14E2] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 2
B00-D18-F03 [1022-14E3] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 3
B00-D18-F04 [1022-14E4] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 4
B00-D18-F05 [1022-14E5] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 5
B00-D18-F06 [1022-14E6] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 6
B00-D18-F07 [1022-14E7] [0000-0000] [CC0600]: AMD K19.6 - Data Fabric: Device 18h; Function 7
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h     (    0000h /     0000h)
ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h)
ITE SuperIO Device ID      = 0000h     (    0000h /     0000h)
ITE SuperIO Version        = 00h       (      00h /       00h)
Winbond SuperIO Port              = 4Eh
Winbond SuperIO HWMonitor Port/60 = 0A20h (0000h / 0A20h)
Winbond SuperIO Device ID         = D592h (0000h / D592h)
Winbond Sensor ID A3/5C/reg$58    = FF / FF / FF
ASpeed SuperIO Port = 00h
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #0 ]------
0000  D5 92 1C 00  00 00 00 03  FF 00 FC 83  01 00 01 F8
0010  3F E6 2F 00  00 00 06 61  FF FF FE FF  FF FF FF FF
0020  FF FF 00 00  FF FF 01 40  FF FF FF FF  FF FF FF FF
0030  C3 01 00 04  00 00 00 00  00 44 0E 03  1E 00 00 00
0040  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0050  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0080  DC EB F5 FE  05 0C 12 19  20 27 2F 39  45 55 73 A7
0090  FF 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  B0 F0 A0 90  70 70 60 70  70 70 80 A0  C0 00 E0 48
00B0  40 00 00 17  00 00 00 00  00 00 00 00  00 00 00 00
00C0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #1 ]------
0000  37 00 24 00  25 80 24 00  21 00 50 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  3E E0 3E E0  3F E0 22 60  46 E0 0F C0  33 80 5F 40
0030  CE C0 00 00  00 00 00 00  00 00 00 00  00 00 25 80
0040  02 F2 02 FD  04 7A 04 64  02 FB 03 33  00 00 00 00
0060  7F 72 7F 7F  7F 7C FF 80  00 00 33 00  00 D4 06 C6
0070  06 00 00 00  00 00 00 00  00 00 FF 01  C0 03 00 07
0080  80 00 08 20  00 05 01 05  2F 02 02 0A  00 00 7A FF
0090  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  46 02 09 0C  0A 0B 00 00  00 00 00 00  00 00 00 00
00B0  66 67 68 69  6A 6B 6C 6D  60 00 00 00  00 00 00 09
00C0  A1 A3 AB AD  AF B1 B3 A6  A7 A9 20 20  20 20 20 20
00D0  A0 A2 AA AC  AE B0 B2 A4  06 06 06 06  06 06 06 06
00E0  06 40 06 40  06 40 06 40  06 40 06 40  06 40 06 40
00F0  80 80 80 80  80 80 80 80  00 03 40 05  20 00 09 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #2 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0080  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 00 00 00  00 00 00 FF  00 00 00 00  00 00 00 00
00B0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 01 00 01  00 00 00 00  00 00 00 00
00F0  00 00 00 03  A4 00 00 00  20 C0 00 24  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #3 ]------
0020  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 06
0040  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 5A
0060  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 7E
00A0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 01 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #4 ]------
0010  91 96 40 00  33 00 00 00  00 00 00 00  00 00 00 00
0060  80 04 03 82  00 20 03 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #5 ]------
0060  41 01 07 07  05 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #6 ]------
0000  D5 92 02 07  17 02 08 00  00 00 00 00  12 05 16 00
0010  C7 31 FF FF  12 05 1E 00  00 00 00 00  00 00 00 00
0020  CE 03 00 19  CB 01 00 00  00 00 00 00  00 00 00 00
0030  00 01 00 00  00 00 00 00  47 10 00 00  00 00 00 00
0040  50 00 47 10  00 00 00 00  00 00 00 00  00 00 00 00
0050  A7 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 01 00 00  50 00 02 00  00 00 00 00  00 00 00 01
00B0  50 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  12 05 16 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #7 ]------
0010  C0 00 00 00  00 00 80 00  00 00 00 80  00 00 00 00
0020  00 00 00 00  00 00 00 00  80 20 09 01  01 00 00 00
0040  07 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  08 08 00 80  00 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #8 ]------
0000  01 80 11 07  03 00 00 0A  00 83 00 83  00 00 00 00
0010  11 11 11 11  11 11 11 11  11 11 01 01  01 01 01 01
0020  01 01 01 01  01 01 01 01  01 0A 01 01  01 01 00 00
00E0  40 40 00 00  00 00 00 00  66 66 00 00  00 00 00 00
00F0  80 80 00 00  A5 A8 06 06  06 40 06 40  80 80 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #9 ]------
0000  C0 C0 C0 C0  C0 C0 C0 C0  C0 C0 00 00  00 00 00 00
0010  00 00 00 01  00 00 00 01  00 00 00 01  00 00 00 01
0020  00 00 00 01  00 00 00 01  00 00 00 00  00 00 00 00
00A0  65 65 65 65  65 65 00 00  00 00 00 00  00 00 00 00
00D0  03 03 03 03  03 03 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #10 ]------
0000  00 00 00 00  00 00 00 00  40 40 40 40  40 40 40 40
0020  00 00 00 00  00 00 00 00  66 66 66 66  66 66 66 66
0040  00 00 00 00  00 00 00 00  05 DC 09 C4  64 64 64 11
0050  00 00 00 00  00 00 00 00  00 28 41 B0  02 02 00 03
0060  00 80 05 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 00 00 00  00 00 80 17  28 00 00 00  80 00 00 00
0080  01 00 00 00  0A 00 00 00  02 00 00 00  A0 00 00 00
0090  04 00 00 00  00 0A 00 00  08 00 00 00  00 A0 00 00
00A0  10 00 00 00  00 00 0A 00  20 00 00 00  00 00 A0 00
00B0  40 00 00 00  00 00 00 0A  80 00 00 00  00 00 00 A0
00C0  00 01 00 0A  00 00 00 00  00 02 00 A0  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #11 ]------
0000  37 41 46 4B  4B 4B 4B 00  7F 00 A5 00  D8 00 FF 00
0010  FF 00 FF 00  FF 00 00 05  37 41 46 4B  4B 4B 4B 00
0020  72 00 99 00  CC 00 FF 00  FF 00 FF 00  FF 00 00 05
0030  3C 43 49 50  50 50 50 00  7F 00 AA 00  D3 00 FF 00
0040  FF 00 FF 00  FF 00 00 05  3C 43 4A 50  50 50 50 00
0050  7F 00 AD 00  DB 00 FF 00  FF 00 FF 00  FF 00 00 05
0060  3C 44 4A 50  50 50 50 00  7F 00 AF 00  D6 00 FF 00
0070  FF 00 FF 00  FF 00 00 05  3C 41 46 50  50 50 50 00
0080  7C 00 AF 00  E2 00 FF 00  FF 00 FF 00  FF 00 00 05
0090  0A 14 1E 28  32 3C 46 00  66 00 7F 00  99 00 B2 00
00A0  CC 00 E5 00  FF 02 05 05  0A 14 1E 28  32 3C 46 00
00B0  66 00 7F 00  99 00 B2 00  CC 00 E5 00  FF 02 05 05
00C0  0A 14 1E 28  32 3C 46 00  66 00 7F 00  99 00 B2 00
00D0  CC 00 E5 00  FF 02 05 05  0A 14 1E 28  32 3C 46 00
00E0  66 00 7F 00  99 00 B2 00  CC 00 E5 00  FF 02 05 05
00F0  0A 14 1E 28  32 3C 46 00  66 00 7F 00  99 00 B2 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #12 ]------
0000  CC 00 E5 00  FF 02 05 05  0A 14 1E 28  32 3C 46 00
0010  66 00 7F 00  99 00 B2 00  CC 00 E5 00  FF 02 05 05
0020  0A 14 1E 28  32 3C 46 00  66 00 7F 00  99 00 B2 00
0030  CC 00 E5 00  FF 02 05 05  0A 14 1E 28  32 3C 46 00
0040  66 00 7F 00  99 00 B2 00  CC 00 E5 00  FF 02 05 05
0050  0A 14 1E 28  32 3C 46 00  66 00 7F 00  99 00 B2 00
0060  CC 00 E5 00  FF 02 05 05  0A 14 1E 28  32 3C 46 00
0070  66 00 7F 00  99 00 B2 00  CC 00 E5 00  FF 02 05 05
0080  00 7F 00 72  00 7F 00 7F  00 7F 00 7C  00 00 00 00
00A0  37 37 37 37  37 37 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  60 00 00 00  7F 80 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #13 ]------
0000  C8 00 A8 D2  D2 00 00 00  C9 01 00 00  05 00 00 00
0010  21 01 00 05  01 00 01 00  00 25 04 7A  00 7C 00 7E
0020  00 06 00 04  00 02 00 02  21 01 00 05  01 00 01 00
0030  00 24 00 7A  00 7C 00 7E  00 06 00 04  00 02 00 02
0040  21 01 00 05  01 00 01 00  00 21 00 7A  00 7C 00 7E
0050  00 06 00 04  00 02 00 02  21 01 00 05  01 07 01 07
0060  00 37 00 7A  00 7C 00 7E  00 06 00 04  00 02 00 02
0070  22 01 00 05  07 01 07 01  00 00 FF FA  FF FC FF FE
0080  00 06 00 04  00 02 00 64  22 01 00 05  01 07 01 07
0090  0C E0 FF FA  FF FC FF FE  00 06 00 04  00 02 00 64
00A0  22 01 00 05  01 07 01 07  2E 80 FF FA  FF FC FF FE
00B0  00 06 00 04  00 02 00 64  22 01 00 05  01 07 01 07
00C0  03 F0 FF FA  FF FC FF FE  00 06 00 04  00 02 00 64
00D0  22 01 00 05  01 07 01 07  02 20 FF FA  FF FC FF FE
00E0  00 06 00 04  00 02 00 64  22 01 00 05  01 07 01 07
00F0  08 C0 FF FA  FF FC FF FE  00 06 00 04  00 02 00 64
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #14 ]------
0000  22 02 00 05  01 00 01 00  02 F2 FF FA  FF FC FF FE
0010  00 06 00 04  00 02 00 C8  22 02 00 05  01 00 01 00
0020  04 7A FF FA  FF FC FF FE  00 06 00 04  00 02 00 C8
0030  22 02 00 05  01 00 01 00  04 64 FF FA  FF FC FF FE
0040  00 06 00 04  00 02 00 C8  22 02 00 05  01 00 01 00
0050  02 FB FF FA  FF FC FF FE  00 06 00 04  00 02 00 C8
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #15 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #16 ]------
00E0  FF 90 00 76  00 00 00 00  00 00 00 00  00 00 00 00
00F0  10 00 00 00  80 C1 00 00  00 00 00 81  C1 00 00 00
   0100  0102  0104  0106  0108
T:   55    36    37    36    33
T:   54    36    37    36    33
T:   54    36    37    36    33
T:   53    36    37    36    33
T:   53    36    37    36    33
T:   53    36    37    36    33
T:   52    36    37    36    33
T:   51    36    37    36    33
T:   53    36    37    36    33
T:   52    36    37    36    33
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #0 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #1 ]------
0000  37 00 24 80  25 00 24 00  21 00 50 80  00 00 00 00
0020  3F 00 3E E0  3F E0 22 60  47 E0 10 00  33 60 5F 40
0030  CE C0 00 00  00 00 00 00  00 00 00 00  00 00 25 00
0040  02 F8 02 F9  04 79 04 90  02 FB 03 27  00 00 00 00
0060  7F 72 7F 7F  7F 7C FF 80  00 00 53 00  00 29 98 18
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #2 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #3 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #4 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #5 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #6 ]------
0020  D4 03 00 19  CB 01 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #7 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #8 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #9 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #10 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #11 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #12 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #13 ]------
00A0  22 01 00 05  01 07 01 07  2F 40 FF FA  FF FC FF FE
00F0  08 E0 FF FA  FF FC FF FE  00 06 00 04  00 02 00 64
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #14 ]------
0000  22 02 00 05  01 00 01 00  02 F8 FF FA  FF FC FF FE
0020  04 42 FF FA  FF FC FF FE  00 06 00 04  00 02 00 C8
0030  22 02 00 05  01 00 01 00  04 90 FF FA  FF FC FF FE
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #15 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #16 ]------
T:   55    36    37    36    33
T:   55    36    37    36    33
T:   54    36    37    36    33
T:   54    36    37    36    33
T:   53    36    37    36    33
T:   52    36    37    36    33
T:   51    36    37    36    33
T:   51    36    37    36    33
T:   52    36    37    36    33
T:   53    36    37    36    33
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/17.7/K18/K19.2/K19.4/K19.5/K21 PM2 at 0CD0 ]------
0000  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/17.7/K18/K19.2/K19.4/K19.5/K21 PM at 0CD6 ]------
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
------[ SMBus #0 ]------
SMBus Type  : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port  : 0B00
Can Have SPD: Yes
DDR5        : Yes
Scan Type   : Full
------[ SMBus Device B00-D49 ]------
  0000  FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0010  00 00 00 00 00 2C 20 00 00 04 00 05 60 00 60 60  ....., .....`.``
  0020  CF 78 63 00 00 78 63 78 63 80 88 42 20 22 04 5E  .xc..xcxc..B ".^
  0030  00 00 80 00 0E 00 00 00 00 00 00 38 0B 10 FF FF  ...........8....
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 FF FF FF FF FF FF 00 00 00 00 00 00 00 FF  ................
  0060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 73 94 0B 10 E0 A0 A0 2C 01 B4 00 00 00  ...s......,.....
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00  ................
  00C0  01 04 00 00 00 00 00 00 00 00 00 00 00 00 D4 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 80 00 00 FF 00 00 00 FF 00 00  ................
  0000  FFFF FFFF FFFF 00FF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0010  0000 0000 0000 0000 2C00 202C 0020 0000 0400 0004 0500 6005 0060 6000 6060 CF60
  0020  78CF 6378 0063 0000 7800 6378 7863 6378 8063 8880 4288 2042 2220 0422 5E04 005E
  0030  0000 8000 0080 0E00 000E 0000 0000 0000 0000 0000 3800 0B38 100B FF10 FFFF 00FF
  0040  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0050  0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 0000 0000 0000 0000 0000 0000 FF00 FFFF
  0060  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00FF
  0070  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0080  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0090  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00A0  0000 0000 7300 9473 0B94 100B E010 A0E0 A0A0 2CA0 012C B401 00B4 0000 0000 0000
  00B0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0204 0000 0100
  00C0  0401 0004 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 D400 00D4 0000
  00D0  0000 0000 0000 0000 0000 0000 0000 0000 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF
  00E0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 8000 0080 0000 FF00 00FF 0000 0000 FF00 00FF 0000 FF00
------[ SMBus Device B00-D4B ]------
------[ SMBus Device B00-D4F ]------
  0000  F5 CF DD E3 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 FF 00 00 2F 01 19 00 FF FF FF FF FF FF FF  ...../..........
  0090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  CFF5 DDCF E3DD 00E3 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0010  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0020  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0030  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0040  0000 0000 0000 0000 0000 0000 0000 0000 0000 DDDD DDDD DDDD DDDD DDDD DDDD DDDD
  0050  DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD
  0060  DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD
  0070  DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD DDDD
  0080  0000 0000 FFFF 0000 0000 2F2F 0101 1919 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00D0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00E0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00F0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0000  30 10 12 02 04 00 20 62 00 00 00 00 60 00 00 00  0..... b....`...
  0010  00 00 00 00 A0 01 E8 03 72 0D 00 00 00 00 1A 41  ........r......A
  0020  1A 41 1A 41 00 7D 1A BE 30 75 27 01 A0 00 82 00  .A.A.}..0u'.....
  0040  00 00 00 00 00 00 88 13 08 88 13 08 20 4E 20 10  ............ N .
  0050  27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00  '..4 .'....L....
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 9B  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  10 00 86 32 80 0A 0B 10 82 38 00 00 00 00 00 00  ...2.....8......
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 15 33 01 85 08 22 00 00 00 00  .......3..."....
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0140  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0150  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0180  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0190  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 F3 44  ...............D
  0200  02 9E 00 24 11 00 00 00 00 43 4D 4B 36 34 47 58  ...$.....CMK64GX
  0210  35 4D 32 42 35 32 30 30 43 34 30 00 00 00 00 00  5M2B5200C40.....
  0220  00 00 00 00 00 00 00 00 80 2C 41 00 00 00 00 00  .........,A.....
  0230  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0240  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0250  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0260  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0270  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0280  0C 4A 30 01 00 0B 10 01 00 12 00 00 00 00 50 72  .J0...........Pr
  0290  6F 66 69 6C 65 20 31 00 00 00 00 00 00 00 00 00  ofile 1.........
  02A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  02B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 35 7A  ..............5z
  02C0  30 25 25 00 24 80 01 7A 2D 00 00 00 00 00 3C 00  0%%.$..z-.....<.
  02D0  3C 00 3C 80 73 80 AF 30 75 27 01 A0 00 82 00 88  <.<.s..0u'......
  02E0  13 08 20 4E 20 10 27 10 10 27 10 C4 09 04 88 13  .. N .'..'......
  02F0  08 4C 1D 0C 13 30 20 00 00 00 00 03 02 00 8A 6E  .L...0 ........n
  0300  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0310  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0320  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0330  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0340  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0350  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0360  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0370  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0380  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0390  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  03A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  03B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  03C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  03D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  03E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  03F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  51 18 0A 86 32 03 32 00 00 00 00 07 FF 3F 00 00  Q...2.2......?..
  0010  00 00 00 00 00 00 00 00 00 00 00 00 70 03 00 00  ............p...
  0020  50 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00  P...............
  0030  00 18 02 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  1851 0A18 860A 3286 0332 3203 0032 0000 0000 0000 0700 FF07 3FFF 003F 0000 0000
  0010  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 7000 0370 0003 0000 5000
  0020  0550 0005 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0030  1800 0218 0002 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0050  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  0060  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00A0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00B0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00C0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00D0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D53 ]------
------[ Chips Found ]------
B00-D51: uPI uP????
B00-D53: uPI uP????
