int0x13 Posted December 26, 2010 Posted December 26, 2010 Hi there, it's my first message into the new Aida64 since the end of Lavalys, I've tried Aid64 and i found the icons were better before! But it's not a big deal. Anyway i have some issues with USB 3.0 Nec PCI-X 1x internal card. When i view USB, into Devices, if i check my external USB3.0 HDD, i can see this: Supported USB Version 3.00 Current Speed Unknown Seems like it cannot detect the current speed , duno why? Also when i go into SMART for my external HDD (USB3.0), it sometimes very long to refresh the display of the smart counters in the right pane. Regards, Quote
Captain Face-Plant Posted December 27, 2010 Posted December 27, 2010 I can help you out with one thing, the icons. Goto File>Preferences>General> . On the right hand pane, in the middle, you can switch between three different icon sets. Quote
int0x13 Posted December 27, 2010 Author Posted December 27, 2010 I can help you out with one thing, the icons. Goto File>Preferences>General> . On the right hand pane, in the middle, you can switch between three different icon sets. Thank you very much, i feel much better with my good old xp icons! One more thing i noticed, sometimes i got a GMCH1 sensor and after some seconds it's disappearing. I had the same issue with Everest. Config: Asus notebook (Chipset NB: Intel Crestline-PM PM965 and SB: Intel 82801HBM ICH8-DO, sensor: CPU, HDD, Asus NB ACPI) Quote
Fiery Posted January 3, 2011 Posted January 3, 2011 About the current USB speed issue, please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1212psk4n0yrvxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Thanks, Fiery Quote
int0x13 Posted March 18, 2011 Author Posted March 18, 2011 Sorry for late answer, the problem is fixed, thanks! Quote
