System Stability Test - AIDA64 v7.35.7000 crashing. Bug or not?
Hello,
I have crashing in System Stability Test, see video (crashing starts at 6m20s):
https://streamable.com/g4q1od
I was able to reproduce the errors on three different computers with Windows 7, 10 and 11.
To easily reproduce the errors, you need an additional partition on the same SSD or NVMEdrive:
D:
which should contain about 1GB of data.
Examples of errors:
Faulting application name: aida64.exe, version: 7.35.7000.0, time stamp: 0x2a425e19
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0x00000000
Fault offset: 0x00000000
Faulting process id: 0xcb8
Faulting module name: aida64.exe, version: 7.35.7000.0, time stamp: 0x2a425e19
Exception code: 0xc000001d
Fault offset: 0x00346e7d
Faulting process id: 0xee8
Faulting module name: KERNELBASE.dll, version: 10.0.19041.4522, time stamp: 0x97a06132
Exception code: 0x0eedfade
Fault offset: 0x00140b82
Faulting process id: 0x239c
Exception code: 0xc0000005
Fault offset: 0x00001d8d
Faulting process id: 0x14b8
Is this AIDA64 bug?
