11 hours ago, Arctucas said:
Is it possible for AIDA64 to display negative temperatures?
Yes, but it's supported only for specific thermal slots.  Which temperature reading do you need that feature for?
My motherboard (MSI Z790 Ace Max) has two thermal sensor leads. I have one placed outside a window, as I sometimes set my external radiators in the open window to achieve extra cooling, and I need to know the outside air temperature.
We've implemented support for negative temperatures for MSI motherboards with NCT6687D sensor chip in the latest AIDA64 beta update:
Let me know how it works.
  • Fiery changed the title to Negative (C°) display? (MSI MEG Z790 Ace Max)
21 hours ago, Arctucas said:
Outside air temp ~27°F (-2.77°C).
Appears to be working. 'Ambient' sensor:
Thank you.
Thank you for your feedback!
