wipe0ut55 Posted January 20, 2025 Posted January 20, 2025 I can't see my HX1200i PSU power value in AIDA64 under Sensors. I can see it fine in HWInfo, and I have tried installing iCUE and uninstalling iCUE and it still doesn't work. Seems as if it's not supported by AIDA64, as it's the newer 2023 model. Please add support. ------[ HID Device Info / HID-compliant vendor-defined device ]------ Manufacturer : CORSAIR Product : HX1200i Power Supply Device ID : 1B1C-1C23 Revision : 0100h Device Instance : HID\VID_1B1C&PID_1C23\9&18939FD7&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 65 Output Report Byte Length : 65 Feature Report Byte Length: 0 Quote
Fiery Posted January 20, 2025 Posted January 20, 2025 9 hours ago, wipe0ut55 said: I can't see my HX1200i PSU power value in AIDA64 under Sensors. I can see it fine in HWInfo, and I have tried installing iCUE and uninstalling iCUE and it still doesn't work. Seems as if it's not supported by AIDA64, as it's the newer 2023 model. Please add support. ------[ HID Device Info / HID-compliant vendor-defined device ]------ Manufacturer : CORSAIR Product : HX1200i Power Supply Device ID : 1B1C-1C23 Revision : 0100h Device Instance : HID\VID_1B1C&PID_1C23\9&18939FD7&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 65 Output Report Byte Length : 65 Feature Report Byte Length: 0 We've implemented support for HX1200i 2023 PSU in the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
wipe0ut55 Posted January 20, 2025 Author Posted January 20, 2025 Works like a charm thank you for the quick fix! Quote
Fiery Posted January 20, 2025 Posted January 20, 2025 17 minutes ago, wipe0ut55 said: Works like a charm thank you for the quick fix! Thank you for your feedback! Quote
