aapje Posted January 8, 2011 Posted January 8, 2011 Whenever the logitech LCD panel is activated it will keep focus retained to that applet. When I switch to another LCD program on my keyboard AIDA64 will set the focus to it's own LCD program within 2 seconds or so. This way it's impossible to keep another program active. Quote
Fiery Posted January 8, 2011 Posted January 8, 2011 We've never had such issues on our G15 and G19 keyboards. Can you please let us know which keyboard do you have, and what version of Logitech drivers do you have installed? BTW, have you tried to alter the option "Allow Program to Force Itself to Foreground on Display" in Logitech LCD Manager? That may be a solution for your issue. Thanks, Fiery Quote
aapje Posted January 9, 2011 Author Posted January 9, 2011 We've never had such issues on our G15 and G19 keyboards. Can you please let us know which keyboard do you have, and what version of Logitech drivers do you have installed? BTW, have you tried to alter the option "Allow Program to Force Itself to Foreground on Display" in Logitech LCD Manager? That may be a solution for your issue. Thanks, Fiery Hi, thanks for your reply. I tried your suggestion about the "Allow Program to Force Itself to Foreground on Display" switch, but that didn't help. I got a Logitech G15(v2) keyboard, some friends got the same problem. The FRAPS display runs for about 8 seconds and then it's forced back to AIDA. Quote
Fiery Posted January 9, 2011 Posted January 9, 2011 What version of Logitech drivers do you have installed? Quote
aapje Posted January 9, 2011 Author Posted January 9, 2011 What version of Logitech drivers do you have installed? 3.06.109 Quote
Fiery Posted January 10, 2011 Posted January 10, 2011 Thank you. We've checked it with v3.06 drivers, and disabling the "Allow Program to Force Itself to Foreground on Display" option in the Logitech LCD Manager doesn't work at all. It must be a bug in the Logitech LCD Manager, so please report it to Logitech, so they can fix it. Quote
aapje Posted January 10, 2011 Author Posted January 10, 2011 Thank you. We've checked it with v3.06 drivers, and disabling the "Allow Program to Force Itself to Foreground on Display" option in the Logitech LCD Manager doesn't work at all. It must be a bug in the Logitech LCD Manager, so please report it to Logitech, so they can fix it. Thanks for testing, I've made a support request at logitech. Will let you know if they fixed it or not. Quote
DocCruncher Posted February 2, 2011 Posted February 2, 2011 I’m having the same exact problem… • Logitech G19 running Gaming software 3.06.109x64 for Win 7 which Logitech is now recommending over version 7 software due to other version 7 bugs. • I can no longer get into Preferences at all; Aida64 simply locks up in a hard freeze anytime I try to access Preferences. What is that all about? • When I was running version 7.00.291x64 Logitech Gaming software I could get into Aida64 Preferences and make changes but due to known version 7 keyboard lockups I had to return to version 3 software. Thanks; Doc Quote
Fiery Posted February 2, 2011 Posted February 2, 2011 I’m having the same exact problem… • Logitech G19 running Gaming software 3.06.109x64 for Win 7 which Logitech is now recommending over version 7 software due to other version 7 bugs. • I can no longer get into Preferences at all; Aida64 simply locks up in a hard freeze anytime I try to access Preferences. What is that all about? • When I was running version 7.00.291x64 Logitech Gaming software I could get into Aida64 Preferences and make changes but due to known version 7 keyboard lockups I had to return to version 3 software. Thanks; Doc Are you using AIDA64 latest beta release? http://www.aida64.com/downloads/aida64extremebuild1241ow5ief2yskzip Quote
DocCruncher Posted February 3, 2011 Posted February 3, 2011 Are you using AIDA64 latest beta release? http://www.aida64.com/downloads/aida64extremebuild1241ow5ief2yskzip No, version 1.50.1200 which 1.50.1241 may fix. However, I ran into another problem; I completely uninstalled 1.50.1200 and tried to install 1.50.1241 but it would not install. The only real difference is that 1200 was a single exe file while 1241 is a ZIP file. Double clicking on the exe file inside the ZIP does not install Aida64 but only runs it. When I close Aida64 there are no shortcuts to run it again. Am I missing something? Thanks; Doc Quote
DocCruncher Posted February 4, 2011 Posted February 4, 2011 No, version 1.50.1200 which 1.50.1241 may fix. However, I ran into another problem; I completely uninstalled 1.50.1200 and tried to install 1.50.1241 but it would not install. The only real difference is that 1200 was a single exe file while 1241 is a ZIP file. Double clicking on the exe file inside the ZIP does not install Aida64 but only runs it. When I close Aida64 there are no shortcuts to run it again. Am I missing something? Thanks; Doc I finally got Aida64 running (sort of). I extracted all the files to C:\Program Files. It does run but now I have lost all my previous settings for my Logitech G19 LCD screen. I have a complete backup of drive C but can not locate the correct LCD settings in Aida64. I really do not want to re-creates all four screens again. Thnaks; Doc Quote
Fiery Posted February 4, 2011 Posted February 4, 2011 Existing Logitech LCD settings can be found in AIDA64.INI file in \Program Files\FinalWire\AIDA64 folder. Quote
DocCruncher Posted February 4, 2011 Posted February 4, 2011 Existing Logitech LCD settings can be found in AIDA64.INI file in \Program Files\FinalWire\AIDA64 folder. Thanks; Fiery. Was I correct in just extracting the beta files into C:\Program files? Wonder why there was no installer? Doc Quote
Fiery Posted February 4, 2011 Posted February 4, 2011 Was I correct in just extracting the beta files into C:\Program files? Wonder why there was no installer? You can basically extract the files to any folder. If you have an older AIDA64 already installed, you can overwrite its files. If you have no AIDA64 installed, you can extract the ZIP content to any folder, even if you place that folder on a USB flash drive Quote
DocCruncher Posted February 6, 2011 Posted February 6, 2011 You can basically extract the files to any folder. If you have an older AIDA64 already installed, you can overwrite its files. If you have no AIDA64 installed, you can extract the ZIP content to any folder, even if you place that folder on a USB flash drive So Aida64 is a "Portable" program. NICE, really nice. No pesky installers or uninstallers needed. I wish ALL Windows program were like that. Thanks; Doc Quote
