I did all my driver updates to my new ASUS G73JW A1.
AIDA64 can only show me 2 cores in the sensor menu, and sidebar gadget.
It showed me 4 core temp readings when I first installed... but now it shows only 2, even after AIDA64 re-install.
cpu : QuadCore Intel Core i7 840QM
Duno if these would help...
Sensor Properties:
Sensor Type CPU, HDD, Asus NB ACPI
GPU Sensor Type Diode (NV-Diode)
Temperatures:
CPU 97 °C (207 °F)
CPU #1 / Core #1 41 °C (106 °F)
CPU #1 / Core #2 37 °C (99 °F)
GPU Diode 37 °C (99 °F)
ST9500420AS (5VJ7M2HZ) 32 °C (90 °F)
ST9500420AS (5VJ7NHPQ) 33 °C (91 °F)
Cooling Fans:
CPU 5100 RPM
GPU 100%
Voltage Values:
GPU Core 0.962 V
CPU Properties:
CPU Type QuadCore Intel Core i7 840QM, 1200 MHz (9 x 133)
CPU Alias Clarksfield
CPU Stepping B1
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2
Original Clock 1866 MHz
Min / Max CPU Multiplier 9x / 14x
Engineering Sample No
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 256 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 8 MB (On-Die, ECC, Full-Speed)
Multi CPU:
Motherboard ID Notebook _ASUS_
CPU #1 Intel® Core i7 CPU Q 840 @ 1.87GHz, 1862 MHz
CPU #2 Intel® Core i7 CPU Q 840 @ 1.87GHz, 1862 MHz
CPU #3 Intel® Core i7 CPU Q 840 @ 1.87GHz, 1862 MHz
CPU #4 Intel® Core i7 CPU Q 840 @ 1.87GHz, 1862 MHz
CPU Physical Info:
Package Type 988 Pin rPGA
Package Size 3.75 cm x 3.75 cm
Transistors 774 million
Process Technology 45 nm, CMOS, Cu, High-K + Metal Gate
Die Size 296 mm2
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
Driver Update http://www.aida64.com/driver-updates
CPU Utilization:
CPU #1 / Core #1 / HTT Unit #1 66 %
CPU #1 / Core #1 / HTT Unit #2 0 %
CPU #1 / Core #2 / HTT Unit #1 0 %
CPU #1 / Core #2 / HTT Unit #2 100 %
It seems your CPU only has 2 cores enabled, out of the total 4 cores it implements. Please check if you have any cores disabled in the BIOS Setup.
Hmm, BIOS setup doesn't show anything about enabling cores, maybe BIOS update eh?
It may worth a try. Although, if the BIOS Setup doesn't offer such an option, then it may well be a hardware failure as well...
Ok I'll try to update the BIOS. When I get into the BIOS settings right now... it doesn't give me enough options, nothing about settings of cores.
So maybe a BIOS update... I hear it's always risky. I'll read on how, and give it a try.
Have you disabled core parking in the windows registry?
Ok yeah I just tried that also, but still no change. AIDA64 still reads two core temps. Weird though, first time use it had 4, but now only 2.
It's a new laptop too, not even a month old.
I’ve been getting “Error sending end of post message to ME†messages at start up.
So I’m thinking that’s why the Date, desktop arrangements, are never saved, and are always changed when rebooting too... I don't know if this could be part of it. Thanks.
Indeed that could be the issue. The BIOS is unable to inform ME of POST end and that can cause several issues.
Possible solution: BIOS upgrade (with ME) or RMA
So I restored using the F9 feature, back to settings. then updated the BIOS from 202 to 203 successfully... booted into windows fine.
Managed to get online and post this, so it's ok. But the Error message is still coming up at boot up.
I guess an RMA? This doesn't really affect my work, but I'm just worred if it will give me problems in the future, or I just don't want no error msges.
Thank you for all of your help.
