Miroslav Tuhársky Posted October 10, 2025 Posted October 10, 2025 AIDA64 is not detecting internal SSDs in section Storage. It might be because internal drives have been moved in Windows Canary built 27965.1 in Device Manager from Disk Drives to Storage disks. Also Samsung Magician and Kingston SSD Manager have this issue. Quote
Fiery Posted October 13, 2025 Posted October 13, 2025 On 10/10/2025 at 6:13 PM, Miroslav Tuhársky said: AIDA64 is not detecting internal SSDs in section Storage. It might be because internal drives have been moved in Windows Canary built 27965.1 in Device Manager from Disk Drives to Storage disks. Also Samsung Magician and Kingston SSD Manager have this issue. Please create the following 4 dumps using AIDA64: 1) In AIDA64 please press Ctrl+D --> Disk Debug --> ATA Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. 2) Also press Ctrl+D --> Disk Debug --> Disk Controllers Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. 3) Ctrl+D --> Disk Debug --> RAID Dump 4) Ctrl+D --> Disk Debug --> SMART Dump Thanks, Fiery Quote
Miroslav Tuhársky Posted October 25, 2025 Author Posted October 25, 2025 This was obviously a bug in a canary built of Windows and has been already resolved in a newer canary bulit by MS Quote
Squall Leonhart Posted December 18, 2025 Posted December 18, 2025 https://techcommunity.microsoft.com/blog/windowsservernewsandbestpractices/announcing-native-nvme-in-windows-server-2025-ushering-in-a-new-era-of-storage-p/4477353 NVME's will no longer be scsiport devices when this spec is enabled widely. @Fiery Home/Pro can turn it on with reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Policies\Microsoft\FeatureManagement\Overrides /v 1853569164 /t REG_DWORD /d 1 /f reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Policies\Microsoft\FeatureManagement\Overrides /v 156965516 /t REG_DWORD /d 1 /f reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Policies\Microsoft\FeatureManagement\Overrides /v 735209102 /t REG_DWORD /d 1 /f 1 Quote
Benni231990 Posted December 18, 2025 Posted December 18, 2025 I Enable it and all my Drives are gone in AIDA64 on the lastest Version Quote
FatBoyNL Posted December 19, 2025 Posted December 19, 2025 (edited) On 12/18/2025 at 5:46 AM, Squall Leonhart said: https://techcommunity.microsoft.com/blog/windowsservernewsandbestpractices/announcing-native-nvme-in-windows-server-2025-ushering-in-a-new-era-of-storage-p/4477353 NVME's will no longer be scsiport devices when this spec is enabled widely. <etc> Same issue here. This new Native NVMe feature is not supported by AIDA64 yet. CrystalDiskInfo 8.7.2 is still able to check for S.M.A.R.T. values though. EDIT @Fiery: attached several dump files for extra info. atadump.txt diskctrldump.txt raiddump.txt smartdump.txt nvmedump.txt EDIT 2: Added several Native NVMe benchies over at Guru3D.com. Please see https://forums.guru3d.com/threads/windows-server-2025-finally-gains-native-nvme-storage-support.458797/post-6384381 for details. Edited December 19, 2025 by FatBoyNL attached several dump files for info etc Quote
FatBoyNL Posted December 19, 2025 Posted December 19, 2025 8 minutes ago, Squall Leonhart said: Does HwInfo show them? HWInfo64 does seem to show the same (limited) info as before afaik, but it's still showing a SCSI Address as well? Quote
Tomorrow Posted December 28, 2025 Posted December 28, 2025 On 10/25/2025 at 2:26 PM, Miroslav Tuhársky said: This was obviously a bug in a canary built of Windows and has been already resolved in a newer canary bulit by MS Why is this marked as solved? Im using the latest 8.20 build on Win11 24H2, and obviously AIDA64 does not yet support native NVMe disks properly. I have this enabled trough a feature override. This is about AIDA64 supporting the nvmedisk.sys driver in addition to the (future) legacy disk.sys driver. Please dont mark this as solved. Sooner or later AIDA64 needs to add nvmedisk.sys support anyway. Quote
Fiery Posted January 18 Posted January 18 On 12/18/2025 at 5:46 AM, Squall Leonhart said: https://techcommunity.microsoft.com/blog/windowsservernewsandbestpractices/announcing-native-nvme-in-windows-server-2025-ushering-in-a-new-era-of-storage-p/4477353 NVME's will no longer be scsiport devices when this spec is enabled widely. @Benni231990 @FatBoyNL @Tomorrow @Miroslav Tuhársky We've implemented native NVMe support in the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta 1 Quote
