Cleanhead Posted June 27, 2014 Share Posted June 27, 2014 Hi Fiery, the pictures explain more than words, so here they are... Screen 1/2 Screen 2/2 oh and would it be possible to add http://www.cloudantivirus.com/ support in the security tab(s) in the upcoming version/beta? of course i just have 1 GTX 780 card installed, just to clarify Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 27, 2014 Share Posted June 27, 2014 The list of video adapters show the adapters in a way that Windows manages them. And Windows itself installs one video adapter for every video outputs of your video card. When you've got a single video card with 4 video outputs, you'll see 4 video adapters installed. As for Cloud Antivirus, as an anti-virus software it is already supported, but maybe you're running a new version that is currently unsupported or where we need to tweak some bits. Please let me know what version you're using. Quote Link to comment Share on other sites More sharing options...
Cleanhead Posted June 27, 2014 Author Share Posted June 27, 2014 1) i understand and it makes sense, the card has 4 outputs as you said. thanks for that 2) I use Panda Cloud Antivirus v3.0.1 Pro I'd like to add that this software also has Anti-Trojan and Anti-Spyware support included. I've seen some popular Antivirus products in the past that were shown in AIDA64 Anti-Virus tab but not shown in the others i mentioned, even though they had support for that aswell. Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 30, 2014 Share Posted June 30, 2014 We've added support for Panda Cloud Antivirus v3 in the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild3029hc0g3swtrpzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Please note that since most security software nowadays tend to integrate anti-virus + anti-spyware + anti-trojan + parental locking features, with AIDA64 we've stopped adding more software on the Anti-Spyware and Anti-Trojan pages. Now only the Anti-Virus and Firewall pages are updated to list the latest security software. Quote Link to comment Share on other sites More sharing options...
Cleanhead Posted June 30, 2014 Author Share Posted June 30, 2014 Thanks for the update! It seems that AIDA has a problem determining the status of the firewall. Screenshot: Even though it is activated the status ? is shown. I guess that's not intended... Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 30, 2014 Share Posted June 30, 2014 Thank you for the feedback. For most firewall software, another (3rd party) software cannot detect or alter firewall status. So the "?" status is normal. Quote Link to comment Share on other sites More sharing options...
Cleanhead Posted July 1, 2014 Author Share Posted July 1, 2014 alright, you may close this thread then :-) Quote Link to comment Share on other sites More sharing options...
