I just bough this I am getting access violations while I am using this for monitoring with Logitech LCD. An example violation picture is attached.
I tried running as administrator but same results. Also it seems to happen while running BF4.
My details:
Windows 7 Ultimate 64-bit
Aida64 4.60.3100
Logitech G13 LCD
Note that I was using MSI afterburner with Riva for a long time for monitoring without any issues.
Please help as LCD monitoring was the only reason I bought this.
It may not be related to the Logitech LCD module at all, but more the generic hardware monitoring module of AIDA64. Please let me know what motherboard, CPU and video card(s) do you have, and whether you've got any external storage devices connected.
Its a Lenovo Y510p laptop. CPU is i7 4700MQ and video is two GT755M in SLI. No external storage is connected.
Thanks.
Edit: Attached the lglcd file it helps to see what I am monitoring.
Aida64 2014-08-10.zip
Thank you. Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic (or attach it to your post as a TXT file).
Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic (or attach it to your post as a TXT file).
------[ AIDA64 Extreme v4.60.3100 ]------
------[ Microsoft Windows 7 Ultimate 6.1.7601.18409 Service Pack 1 (64-bit) ]------
------[ Video Adapters ]------
nVIDIA GeForce GT 755M (Lenovo) [10DE-0FCD / 17AA-3800]
------[ Video Driver ]------
nvapi.dll: 9.18.13.4052
nvd3dumx||9.18.13.4052|||nvwgf2umx||9.18.13.4052|||nvwgf2umx||9.18.13.4052|||nvd3dum||9.18.13.4052 - nVIDIA ForceWare 340.52|||nvwgf2um||9.18.13.4052|||nvwgf2um||9.18.13.4052
------[ nVIDIA GPU #1 @ mem D3000000 ]------
GPU Clocks   = 953 / 0 / 0 MHz
Memory Clock = 2700 MHz
GPU    Base Clock = 27000 kHz
Shader Base Clock = 27000 kHz
Memory Base Clock = 27000 kHz
nvidia-000000 = 0E70D0A2  [GK107]
nvidia-001218 = 00000000
nvidia-001538 = 800003FF
nvidia-001704 = 8007FFC1
nvidia-001714 = C007FFC2
nvidia-00E114 = 0000021C
nvidia-00E118 = 0000021C
nvidia-00E11C = 00000001
nvidia-00E120 = 03000000
nvidia-00E728 = 00000000
nvidia-00E820 = 01030305
nvidia-00E8A0 = 02010000
nvidia-020008 = 0000372A
nvidia-020014 = 05D903A5
nvidia-0200C4 = 000000D8
nvidia-0200C8 = 00000000
nvidia-0200D8 = 050000D8
nvidia-0200DC = 00000000
nvidia-020340 = 00000060
nvidia-020344 = 00000050
nvidia-020348 = 00000000
nvidia-020400 = 00000038
nvidia-022430 = 00000001
nvidia-022434 = 00000002
nvidia-022438 = 00000002
nvidia-02243C = 00000002
nvidia-022440 = 00000004
nvidia-022540 = 00000000
nvidia-022544 = 00000000
nvidia-022548 = 00000000
nvidia-022550 = 00000000
nvidia-022554 = 00000000
nvidia-088000 = 0FCD10DE  [GK107]
nvidia-08A000 = 0E1B10DE
nvidia-100714 = 00000303
nvidia-101000 = 8F40B494
nvidia-10100C = 8E013010
nvidia-10F290 = 11545A3B
nvidia-10F294 = 3CD50294
nvidia-10F590 = 03000304
nvidia-120070 = 00000001
nvidia-120074 = 00000002
nvidia-120078 = 00000001
nvidia-17E924 = E3000EFF
nvidia-300000 = 00000000
nvidia-310000 = 00000000
nvidia-700000 = 00000000
nvidia-7E0000 = EBBBAA55
------[ nVIDIA GPU #1 / ForceWare Properties ]------
Memory Type          = 8 (GDDR5)
Memory Bank Count    = 1
Memory Bus Width     = 128-bit
GPU / MC / VE Load   = 14 / 2 / 0
VPE Count            = 0
Shader Pipe Count    = 1
Shader SubPipe Count = 2
Total SP Count       = <unknown>
Total TPC Count      = 0
Total SM Count       = <unknown>
Core Count           = 384
Partition Count      = 2 (mask: 00000003)
Fan RPM              = <unknown>
Fan Duty Cycle       = <unknown>
Core Voltage         = 1100 mV
Current Pstate       = 0
Ventura State        = 0 (unsupported)
Physical Frame Buffer Size = 2096832 KB
Virtual  Frame Buffer Size = 2097152 KB
Total / Free Video Memory  = 2097152 KB / 1572220 KB
------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------
Perf. Levels   = 3
Active Profile = 2
curr-core/shader/mem-0 = 405 MHz / 0 MHz / 405 MHz
curr-core/shader/mem-1 = 405 MHz / 0 MHz / 800 MHz
curr-core/shader/mem-2 = 405 MHz / 0 MHz / 2700 MHz [Active]
orig-core/shader/mem-0 = 405 MHz / 0 MHz / 405 MHz
orig-core/shader/mem-1 = 405 MHz / 0 MHz / 800 MHz
orig-core/shader/mem-2 = 405 MHz / 0 MHz / 2700 MHz [Active]
------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
Active Profile = 255
curr-core/mem-0 = 953 MHz / 2700 MHz
orig-core/boost/mem-0 = 980 MHz / 1019 MHz / 2700 MHz
------[ nVIDIA GPU #2 @ mem D2000000 ]------
GPU Clocks   = 135 / 0 / 0 MHz
Memory Clock = 405 MHz
nvidia-00E820 = 01030005
nvidia-020008 = 000035F8
nvidia-020344 = 00000022
nvidia-020400 = 00000026
nvidia-101000 = 8F40B492
nvidia-10100C = 8F013000
nvidia-10F290 = 030E0E0A
nvidia-10F294 = 2C20C28B
nvidia-300000 = EBBBAA55
nvidia-310000 = 9F32E9D2
nvidia-7E0000 = F7FDFFFF
------[ nVIDIA GPU #2 / ForceWare Properties ]------
GPU / MC / VE Load   = 2 / 0 / 0
VPE Count            = 0
Total TPC Count      = 0
Core Count           = 384
Fan RPM              = <unknown>
Core Voltage         = 812 mV
Current Pstate       = 8
------[ nVIDIA GPU #2 / ForceWare Clocks (old) ]------
Perf. Levels   = 3
Active Profile = 0
curr-core/shader/mem-0 = 405 MHz / 0 MHz / 405 MHz [Active]
orig-core/shader/mem-0 = 405 MHz / 0 MHz / 405 MHz [Active]
------[ nVIDIA GPU #2 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
curr-core/mem-0 = 135 MHz / 405 MHz
------[ nVIDIA GPU #2 / BIOS Info ]------
BIOS Version   = 80.07.A8.00.32
Signon Message = GK107 E2044 INT SKU VGA BIOS
Bootup Core Clock   = 2684357 MHz
Bootup Shader Clock = 1095320 MHz
Bootup Mem Clock    =    0 MHz
Ref. Clock 4000 =      0 kHz =   0 MHz *4
Ref. Clock 4008 =      0 kHz =   0 MHz *4 [Memory]
Ref. Clock 4010 =      0 kHz =   0 MHz *4
Ref. Clock 4018 =      0 kHz =   0 MHz *4
Ref. Clock 4020 =      0 kHz =   0 MHz *4 [shader]
Ref. Clock 4028 =      0 kHz =   0 MHz *4 [GPU]
Ref. Clock 4030 =      0 kHz =   0 MHz *4
Ref. Clock 4038 =      0 kHz =   0 MHz *4
Core Clock     =    0 MHz
Shader Clock   =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Core Voltage   = 0.00 V
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Core Clock     =    0 MHz
Mem Clock      =    0 MHz
Geom. Delta    =    0 MHz
Fan Speed      =    0 %
Diode Gain Mul        = 0
Diode Gain Div        = 0
Diode Offset Mul      = 0
Diode Offset Div      = 0
Diode Offset Bin Mul  = 0
Diode Offset Bin Div  = 1
Temp Compensation Mul = 0
Temp Compensation Div = 1
Max Div               = 0
Measured Temp Threshold (Raw)   = 0
Measured Temp Threshold (Int)   = 0 Celsius
Measured Temp Threshold (Float) = 0 Celsius
BIOS Temp Threshold             = 125 Celsius
Measured Diode Temp (Raw)       = 0
Measured Diode Temp (Int)       = 0 Celsius
Measured Diode Temp (Float)     = 0 Celsius
Diode Temp by ForceWare         = 38 Celsius
------[ NVAPI GPU Handles ]------
GPU Count = 2
GPU #1 = 00000100
GPU #2 = 00000700
------[ nVIDIA GPU #1 / Thermal Settings ]------
Sensor Count = 1
Sensor #0 / Controller   = GPU Internal
Sensor #0 / Target       = GPU Core
Sensor #0 / Current Temp = 56 Celsius
------[ nVIDIA GPU #2 / Thermal Settings ]------
Sensor Count = 1
Sensor #0 / Current Temp = 38 Celsius
------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------
------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------
------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------
------[ nVIDIA GPU #2 / B00-CR1F = 00 ]------
------[ nVIDIA GPU #2 / B00-CR49 = 00 ]------
------[ nVIDIA GPU #2 / B01-CR1F = 00 ]------
------[ nVIDIA GPU #2 / B01-CR49 = 00 ]------
------[ nVIDIA GPU #2 / B02-CR1F = 00 ]------
------[ nVIDIA GPU #2 / B02-CR49 = 00 ]------
------[ nVIDIA GPU #2 / B03-CR1F = 00 ]------
------[ nVIDIA GPU #2 / B03-CR49 = 00 ]------
------[ nVIDIA GPU #2 / B04-CR1F = 00 ]------
------[ nVIDIA GPU #2 / B04-CR49 = 00 ]------
Total   :   12.7 sec
GPU1-B00:    2.0 sec
GPU1-B01:    0.7 sec
GPU1-B02:    0.6 sec
GPU1-B03:    1.9 sec
GPU1-B04:    1.2 sec
GPU2-B00:    1.9 sec
GPU2-B01:    0.7 sec
GPU2-B02:    0.6 sec
GPU2-B03:    2.0 sec
GPU2-B04:    1.1 sec
Thank you for the dumps. We've tried to reproduce the issue on our nVIDIA GeForce based test systems, but without luck so far. We'll try to get a mobile GeForce system, in a hope that it would produce the same errors. Meanwhile, please try to update to the latest AIDA64 beta and the latest ForceWare release, maybe the issue will fix itself meanwhile :)
http://www.aida64.com/downloads/aida64extremebuild3114t0h8kqnryfzip
I'll let you know in this topic once we have more information on this issue.
Thanks, I'll try this.
So this one works fine. How do I replace the installed version with this beta? Just copy over?
Thank you for the feedback.
Yes, just copy over, let it replace any existing files. But first, close AIDA64 ;)
