reoix Posted August 9, 2015 Share Posted August 9, 2015 Computer can run other stress test normally but if i run cache stress test (alone or with the others) computer freezes in 10 seconds. My specs are ; 5820k with h100i cooler , msi x99 sli , 4x4 kingston 2400 mhz ddr4 , thermaltake tough power 750 watt. What i tried so far; changed ram slots , fresh new OS installation, bios updated Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 9, 2015 Share Posted August 9, 2015 Is your CPU or RAM overclocked, power limit unlocked or otherwise tweaked from their factory default settings? Quote Link to comment Share on other sites More sharing options...
reoix Posted August 9, 2015 Author Share Posted August 9, 2015 No overclock or tweak has been done on motherboard or bios everything works @ stock Edit : Can run cache stress if i remove 1 slots from rams doesnt matter which one Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 10, 2015 Share Posted August 10, 2015 Are you using your Kingston memory modules at DDR4-2133 or DDR4-2400 setting? If you're running at DDR4-2400 -- which is considered overclock with your CPU --, then try to up the command rate (also known as tCR or tCMD) from 1T to 2T. Also verify if the IMC is actually driving your memory modules at the rated voltage, as specified by Kingston. Quote Link to comment Share on other sites More sharing options...
namuk Posted September 3, 2015 Share Posted September 3, 2015 run the mem in XMP , the mb in auto config might be setting up the memory wrong i.e volts,timings ect. Quote Link to comment Share on other sites More sharing options...
patco Posted September 25, 2015 Share Posted September 25, 2015 run the mem in XMP , the mb in auto config might be setting up the memory wrong i.e volts,timings ect. Excuse me, can you please explain this? Quote Link to comment Share on other sites More sharing options...
