jadevwin Posted October 20, 2015 Report Share Posted October 20, 2015 Hi, it would be great to support JDownloader (http://jdownloader.org/) like remaining time, current download rate,.... Best regards Quote Link to comment Share on other sites More sharing options...
Fiery Posted October 20, 2015 Report Share Posted October 20, 2015 As far as I know, there's no JDownloader API that a 3rd party application could support, and there's no SDK either. If there's one, please let me know where can we check it out Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
jadevwin Posted October 20, 2015 Author Report Share Posted October 20, 2015 Hi, there is an official API: My.JDownloader API That is documented here: https://docs.google.com/document/d/1IGeAwg8bQyaCTeTl_WyjLyBPh4NBOayO0_MAmvP5Mu4/edit?pli=1# To enable this API locally, go to Advanced Settings and enable "RemoteAPi: Deprecated Api". The API is based on HTTP, i tried the following: Get current speed: http://localhost:3128/downloadcontroller/getSpeedInBps Example result: { "data" : 12220 } Get packages: http://localhost:3128/downloadsV2/queryPackages?{%22bytesTotal%22:true,%22enabled%22:true,%22speed%22:true,%22finished%22:true,%22eta%22:true,%22bytesLoaded%22:true,%22running%22:true,%22extractionStatus%22:true} Example result: { "data" : [ { "eta" : 1313, "enabled" : true, "bytesLoaded" : 4183966, "speed" : 5190, "bytesTotal" : 11003942, "name" : "node-v4 2 1-linux-armv7l", "uuid" : 1445344136056, "running" : true }, { "eta" : 692, "enabled" : true, "bytesLoaded" : 5837537, "speed" : 4920, "bytesTotal" : 9244672, "name" : "node-v4 2 1-x86", "uuid" : 1445344136058, "running" : true }, { "eta" : 1347, "enabled" : true, "bytesLoaded" : 4595697, "speed" : 4922, "bytesTotal" : 11231892, "name" : "node-v4 2 1-linux-x86", "uuid" : 1445344136059, "running" : true }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 13552232, "name" : "node", "uuid" : 1445344136060 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 402, "name" : "apple-touch-icon", "uuid" : 1445344136061 }, { "enabled" : true, "bytesLoaded" : 0, "name" : "v4", "uuid" : 1445344136062 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 10158080, "name" : "node-v4 2 1-x64", "uuid" : 1445344136063 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 12954343, "name" : "node-v4 2 1-sunos-x86", "uuid" : 1445344136064 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 13956448, "name" : "node-v4 2 1-sunos-x64", "uuid" : 1445344136065 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 12589250, "name" : "node-v4 2", "uuid" : 1445344136066 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 11674722, "name" : "node-v4 2 1-linux-x64", "uuid" : 1445344136067 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 22505860, "name" : "node-v4 2 1", "uuid" : 1445344136068 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 10992882, "name" : "node-v4 2 1-linux-armv6l", "uuid" : 1445344136069 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 11114971, "name" : "node-v4 2 1-linux-arm64", "uuid" : 1445344136070 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 5526, "name" : "platform-icon-generic", "uuid" : 1445344136071 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 4076, "name" : "platform-icon-osx", "uuid" : 1445344136072 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 6076, "name" : "platform-icon-win", "uuid" : 1445344136073 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 9772442, "name" : "node-v4 2 1-darwin-x64", "uuid" : 1445344136074 }, { "enabled" : true, "bytesLoaded" : 0, "bytesTotal" : 138382, "name" : "trademark-policy", "uuid" : 1445344136075 } ] } Best regards Quote Link to comment Share on other sites More sharing options...
Fiery Posted October 20, 2015 Report Share Posted October 20, 2015 Thank you, but we've got 2 major issues with that. First, you quote the option being named "RemoteAPi: Deprecated Api" -- it doesn't sound like an active development API Second, using a HTTP client for such purposes would be a big overhead and we wouldn't want to go down that path. We would be happy to interface through a DLL API though, if there's one. Quote Link to comment Share on other sites More sharing options...
odospace Posted October 20, 2015 Report Share Posted October 20, 2015 I looked into the JDownloader forum, it seems the API is still maintained because it is the same as for the My.JDownloader API site. But there will never be an official DLL Quote Link to comment Share on other sites More sharing options...
jadevwin Posted October 23, 2015 Author Report Share Posted October 23, 2015 ok Quote Link to comment Share on other sites More sharing options...
jadevwin Posted October 23, 2015 Author Report Share Posted October 23, 2015 Hi, again: examples of the window title JDownloader 2 speed:3.70 KB JDownloader 2 speed:0 B JDownloader 2 speed:1.10 MB Unfortunately it is not possible to suppress the B, KB, MB display Quote Link to comment Share on other sites More sharing options...
Fiery Posted October 23, 2015 Report Share Posted October 23, 2015 Hi, Fiery is it possible to read values from Shared Memory or from the JDownloaders Window Title? Yes, both is possible, as long as we can easily find the window and read the window title (case #2), or when it's easy to understand/interpret the shared memory content (case #1). With shared memory a documentation would help a lot Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 8, 2015 Author Report Share Posted November 8, 2015 Now JDownloader has a shared memory segment: To activate it open "Advanced settings" and check "GeneralSettings: Shared Memory State". Shared memory name: JDownloaderUpdate interval: 1000 msContent (1024 bytes):version (currently 1) - integer, 4 bytesbps bytes/s - 8 bytestotal bytes - long, 8 bytesloaded bytes - long, 8 bytesremaining bytes - long, 8 byteseta seconds - long, 8 bytesrunning downloads - long, 8 bytesopen connections - long, 8 bytesrunning packages - long, 8 bytes It would be great if it is read by Aida64. Best regards Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 8, 2015 Report Share Posted November 8, 2015 Which values would you like to see in AIDA64? And please don't say all of them Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 8, 2015 Author Report Share Posted November 8, 2015 Are theese possible? bps total bytes remaining bytes eta seconds Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 9, 2015 Report Share Posted November 9, 2015 Yes, they are possible to be implemented. The only problem is that Eset NOD32 (latest version with latest updates) blocks the process of JDownloader 2 Beta installer to download its packages, I suppose because is has malicious or suspicious content. Please ask the author of JDownloader to resolve this. I hope you understand that we do not want to support malicious software in AIDA64 in any ways. Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 10, 2015 Author Report Share Posted November 10, 2015 Please download the "Other" distribution from http://jdownloader.org/download/index Start the JDownloader withith a shell via "java -jar JDownloader.jar" or via the Fileexplorer using Open With -> Java. Best regards Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 11, 2015 Report Share Posted November 11, 2015 Thank you, we've implemented the requested new hardware monitor items in the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 11, 2015 Author Report Share Posted November 11, 2015 Great! It works, but is it possible to display the ETA in the Format DD:HH:MM:SS ? Thank you! Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 11, 2015 Report Share Posted November 11, 2015 Great! It works, but is it possible to display the ETA in the Format DD:HH:MM:SS ? Thank you for the feedback. I'm afraid custom formatting for hardware monitor values is not possible. Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 11, 2015 Author Report Share Posted November 11, 2015 Is it possible to display a string if i extend the shared memory like: Content (1024 bytes):version (currently 2) - integer, 4 bytesbps bytes/s - 8 bytestotal bytes - long, 8 bytesloaded bytes - long, 8 bytesremaining bytes - long, 8 byteseta seconds - long, 8 bytesrunning downloads - long, 8 bytesopen connections - long, 8 bytesrunning packages - long, 8 bytes eta string size - integer, 4 bytes eta string - char, variable bytes (not 0 terminated, ISO-8859-1) The byte order is little endian and all values are unsigned. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 11, 2015 Report Share Posted November 11, 2015 Yes, we can switch from the current ETA seconds to the new ETA string. But make sure to properly specify the string type. Is it Ansi string or Unicode or UTF-8? It would also be great to improve the accuracy of the shared memory fields description by specifying whether they are signed or unsigned values, and also their endianness. Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 12, 2015 Author Report Share Posted November 12, 2015 Hello Fiery, i updated the shared memory description. A new JDownloader version with the version 2 structure is available. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 12, 2015 Report Share Posted November 12, 2015 Thank you, we'll update the ETA reading to show the ETA string in the next AIDA64 beta update due next week. Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 13, 2015 Author Report Share Posted November 13, 2015 Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 20, 2015 Report Share Posted November 20, 2015 The mentioned new AIDA64 beta is available for download at: http://www.aida64.com/downloads/latesta64xebeta Quote Link to comment Share on other sites More sharing options...
jadevwin Posted November 23, 2015 Author Report Share Posted November 23, 2015 It works, Thank you. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 23, 2015 Report Share Posted November 23, 2015 Thank you for the feedback Quote Link to comment Share on other sites More sharing options...
