sblantipodi Posted November 7, 2015 Share Posted November 7, 2015 Hi, to monitor avg and max temp I use the "Statistics" tab in the "Stability Test" section. There are two things that I don't love too much of that section:1) it shows minimum, max and avg temp but not current 2) it has a limit of device to monitor, in the preferences section, I can select only 12 devices. is there a solution to this two points ?THANK YOU for this wonderful software. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 9, 2015 Share Posted November 9, 2015 1) We will add the new column to show the current readings in the next AIDA64 beta update due later this week. 2) Yes, there's such a limit, to make sure the graphs don't get unreadable. Truth be told, it also limits the Statistics list, which it shouldn't do. We however do not have a plan to extend the 12 slots we have there, so if you find that too limiting, then I think the real solution would be to use the Logging facility instead of the Statistics tab of the System Stability Test. You can configure Logging in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging. Regards, Tamas Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 11, 2015 Share Posted November 11, 2015 You can download the mentioned new AIDA64 Extreme beta update from: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote Link to comment Share on other sites More sharing options...
sblantipodi Posted November 11, 2015 Author Share Posted November 11, 2015 this are the software where I'm glad to spend money. Quote Link to comment Share on other sites More sharing options...
sblantipodi Posted November 11, 2015 Author Share Posted November 11, 2015 1) We will add the new column to show the current readings in the next AIDA64 beta update due later this week. 2) Yes, there's such a limit, to make sure the graphs don't get unreadable. Truth be told, it also limits the Statistics list, which it shouldn't do. We however do not have a plan to extend the 12 slots we have there, so if you find that too limiting, then I think the real solution would be to use the Logging facility instead of the Statistics tab of the System Stability Test. You can configure Logging in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging. Regards, Tamas I don't love text log functionality but it is ok. IMHO statistics and graphs should be uncoupled, at least there should be an option to uncouple graphs from the statistics list. In any case, congrats for your amazing software and support. Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 11, 2015 Share Posted November 11, 2015 Thank you Quote Link to comment Share on other sites More sharing options...
sblantipodi Posted November 11, 2015 Author Share Posted November 11, 2015 You can download the mentioned new AIDA64 Extreme beta update from: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. a question, is there a way to import the settings from the "old aida" to the new beta? thanks!!! Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 12, 2015 Share Posted November 12, 2015 Yes, you can import all your old settings and your entered license key by backing up and restoring the AIDA64.INI and PKEY.TXT files. But, you can also just take the new beta ZIP package and extract it to your existing AIDA64 installation folder. Let it overwrite any existing files. It will retain your existing settings and license. Quote Link to comment Share on other sites More sharing options...
sblantipodi Posted November 12, 2015 Author Share Posted November 12, 2015 Yes, you can import all your old settings and your entered license key by backing up and restoring the AIDA64.INI and PKEY.TXT files. But, you can also just take the new beta ZIP package and extract it to your existing AIDA64 installation folder. Let it overwrite any existing files. It will retain your existing settings and license. thank you!!! Quote Link to comment Share on other sites More sharing options...
