  • 2 months later...
Hello
Since I have 32GB memory (4x8Gb), sometimes Aida64 does not recognize the 4 sticks for monitoring,
but all the sticks are recognized in "Overclock"
Just close Aida64 and re-launch it and it's good
Thanks
That issue is due to a SPD communication anomaly that affects Haswell-E and Broadwell-E based systems. We haven't been able to reproduce the issue on our own test systems, and when we've tried to fix it up by adjusting SPD protocol timing values, things got even worse :(  We'll keep looking into it, but I cannot promise any quick fix at this time :(
Ok no problem, thanks ;)
It is not possible to have a button "refresh" for example, which will make a re reading of the data (instead of having to close and re launch Aida64) ?
In the next AIDA64 beta update we'll make the Computer / Summary and Motherboard / SPD pages to reset the SPD cache when you press the Refresh toolbar button (or go to main menu / View / Refresh, or press the F5 key).
Hi
I downloaded the latest beta (4056), the new option work ?
Refresh works for the SPD, etc ... But not for the Sensor and I'm still forced to close and re launch Aida64
Thanks
On 2017. 01. 18. at 1:41 PM, tistou77 said:
Hi
Thanks
The refresh will only work for the SPD and Summary pages. We'll need to dig a bit deeper then. A couple of other users also have issues about AIDA64 sometimes not detecting all of the DIMM modules on X99 chipset based systems. But so far we haven't been able to find out what exactly goes wrong, and why it's not happening all the time, but only occasionally.
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Please also let me know at which clock speed are your memory modules running. If your memory is overclocked, let me know if it works more stable (about the Sensor page) at the stock speed of DDR4-2400.
Also let me know if you have any other monitoring software running in the background, including the likes of Aquasuite or AI Suite.
On ‎2017‎. ‎01‎. ‎20‎. at 4:16 PM, tistou77 said:
If you can not solve the problem, maybe the re "Detecting sensor information" will be redone by clicking the Refresh button
We'll do that in the next AIDA64 beta update.  And thank you for the dump.  We'll get a set of Corsair DDR4-3200 memory modules and check it out in our own Broadwell-E test system.
Ok thanks
For information, I never had a problem with a kit 4x4Gb, only with 4x8Gb
10 minutes ago, tistou77 said:
Ok thanks
Thank you. Was the 4x4GB kit also DDR4-3200 and also made by Corsair?
3 hours ago, tistou77 said:
It's better, I was forced to "Refresh" 1 time :)
Same for the SPD
Thank you :) We'll keep working on it in the next few beta updates.
