tistou77 Posted April 20, 2016 Posted April 20, 2016 HelloIs it be possible for the DIMM to have A1, B1, C1 and D1 instead of 1, 4, 7 and 10 ?It is prettier And in "preferences - System Stability Test", to have a line moreThanks so much Quote
Fiery Posted April 20, 2016 Posted April 20, 2016 DIMM labelling is a big challenge, considering all the various memory controllers out there. Even if we'd switched to using DIMM A1/B1/C1/etc formula, in many cases there would be strange jumps in the numbering. As for the System Stability Test, we'll expand the current 12 slots to 14 in the next AIDA64 beta update due in a few days from now Quote
tistou77 Posted April 20, 2016 Author Posted April 20, 2016 Ok for DIMM, not possible to retrieve information by the bios or other, then ? But why is indicated 1, 4, 7 and 10 for me as I only have 8 memory slots? 1, 3, 5 and 7 have been better, no Ok for System Stability Test Thanks Quote
Fiery Posted April 20, 2016 Posted April 20, 2016 On 4/20/2016 at 3:33 PM, tistou77 said: Ok for DIMM, not possible to retrieve information by the bios or other, then ? But why is indicated 1, 4, 7 and 10 for me as I only have 8 memory slots? 1, 3, 5 and 7 have been better, no The problem is that it's not easy to detect what the motherboard can actually support, out of the capabilities of the memory controller. For example, when an Ivy Bridge-E/EP CPU has got 2 memory controllers, each supporting 4 memory channels, and each memory channel supports 3 DIMM slots, the CPU in theory can handle up to 24 memory modules. And when walking through the memory channels and DIMM slots, numbering must follow the capabilities of the CPU (more specifically, the CPU integrated memory controller), and not the capabilities of the motherboard. AIDA64 cannot know for sure what slots can it skip when enumerating DIMM slots. That's why you have gaps of 2 DIMMs between memory channels, and not just 1 DIMM. Quote
tistou77 Posted April 20, 2016 Author Posted April 20, 2016 Ok, thank you for the explanationThe simplest would be to "personalize" the names of the DIMM, sensors, etc ... in "Sensor" but I know it's not conceivable Quote
Fiery Posted April 20, 2016 Posted April 20, 2016 The data displayed on the Sensor page is not meant to be customizable at all. If you need to rename the sensor readings, and/or hide some of them, then it's best to use the OSD Panel, Desktop Gadget or SensorPanel modules. With them you can completely customize the layout to your preference. Quote
Fiery Posted April 20, 2016 Posted April 20, 2016 On 4/20/2016 at 6:03 PM, tistou77 said: Thank you but I do not use it You should It's a bit tricky and somewhat time-consuming to build a proper SensorPanel layout, but when it's done, it works and looks great Quote
tistou77 Posted April 21, 2016 Author Posted April 21, 2016 For DIMM, I can say a silliness, but it is not possible to retrieve the information by the SPD? Quote
Fiery Posted April 21, 2016 Posted April 21, 2016 On 4/21/2016 at 7:05 AM, tistou77 said: For DIMM, I can say a silliness, but it is not possible to retrieve the information by the SPD? Capture.PNG SPD is enumerated in a completely different way in AIDA64. But yes, it may be possible to use that numbering scheme to make the labels look slightly better. It would still not be perfect in all configurations, but it may work better in most configurations. Quote
Fiery Posted April 21, 2016 Posted April 21, 2016 On 4/21/2016 at 10:08 AM, tistou77 said: Ok I can test if you want Thanks Alright We'll do the necessary adjustments in the next AIDA64 beta update. Quote
Fiery Posted April 26, 2016 Posted April 26, 2016 The mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta Please let me know how it works Quote
tistou77 Posted April 26, 2016 Author Posted April 26, 2016 It's good Thanks so much for your great work Quote
tistou77 Posted November 25, 2016 Author Posted November 25, 2016 Hello Is possible to have lines more in "preferences - System Stability Test" ? With 6950X (10 cores) The lines are used quickly Thanks Quote
Fiery Posted November 28, 2016 Posted November 28, 2016 There are a few issues with that: 1) Too many lines make the graph very crowded 2) We don't really have more colours to assign to new lines 3) Core temperatures aren't that far from each other, so it's usually fine to use the temperature of a few cores only. Core #1 and Core #2 should be enough to monitor, along with CPU Package temperature Quote
tistou77 Posted February 10, 2017 Author Posted February 10, 2017 Hello I thought about the problem of colors and lines in the graph It will not be possible to add 2 lines, eg (for temperatures) in the "Statistics" tab but not to add them in the "Temperatures" tab ?Me, I never look at this tab, the lines are really too tight And all the screens that I can see on the forums, there are never tabs "Temperatures", etc ... Only "Statistics" Quote
Fiery Posted February 13, 2017 Posted February 13, 2017 You can switch off (hide) individual graph lines by removing the tick from their respective checkbox Quote
