Hi. I have a weird issue, i need to monitorate +12v sensor of two psu(Corsair 650w and C3 Tech 500w) and the latest version of AIDA64 isn't showing the voltages.
To be more accurate, in the cpu with the corsair psu the 12v sensor appeared once, but after that i cant even select in the sensors selection.(because is not showing).
What do i do?
I really aprecciate any help!
Thank you.
Please note that AIDA64 can only measure and show +12V for a single PSU. If you have issues about your Corsair PSU, please let us know what exact PSU model is it.
Hey, thank you for feedback.
I'm sorry, the psu is 620w, and the model is HX620.
I have two cpus with two different setups and two different PSU's.
If you mean you have 2 computers with one PSU each, then it should work of course :) In which case on the problemous machine (where the +12V reading is missing) please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
  • 5 years later...
