rwky Posted November 7, 2016 Posted November 7, 2016 Hi there, Using Aida64 Extreme, latest version and it doesn't see the Chassis Fan. The MSI Control Center sees it without a problem (bios as well, of course). Anything I can do to help in solving this? Cheers! Quote
Fiery Posted November 7, 2016 Posted November 7, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
rwky Posted November 9, 2016 Author Posted November 9, 2016 Sensor Properties Sensor Type Fintek F71889ED (ISA 480h) GPU Sensor Type Diode, ON NCP81022 (ATI-Diode, 20h) Temperatures Motherboard 28 °C (82 °F) CPU 48 °C (118 °F) CPU #1 / Core #1 45 °C (114 °F) CPU #1 / Core #2 45 °C (114 °F) CPU #1 / Core #3 45 °C (114 °F) CPU #1 / Core #4 45 °C (114 °F) CPU #1 / Core #5 45 °C (114 °F) CPU #1 / Core #6 45 °C (114 °F) CPU #1 / Core #7 45 °C (114 °F) CPU #1 / Core #8 45 °C (114 °F) Aux 77 °C (171 °F) GPU Diode 34 °C (93 °F) KINGSTON SV300S37A120G 27 °C (81 °F) SAMSUNG HD753LJ 23 °C (73 °F) Cooling Fans CPU 900 RPM Power Supply 939 RPM GPU 2020 RPM (40%) Voltage Values CPU Core 1.416 V +3.3 V 3.264 V +5 V 3.114 V +12 V 13.992 V +3.3 V Standby 3.280 V VBAT Battery 3.168 V GPU VRM 0.850 V Current Values GPU VRM 1.95 A Power Values GPU 9.69 W GPU VRM 2.00 W Debug Info F 0681 0FFF 063D Debug Info T 48 77 28 Debug Info V CC B1 89 6D 4A 9F C1 CD C6 Debug Info I 03 04 10 19 34 (0909) ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-041312-Chipset$1APEF037_BIOS DATE: 12/17/15 14:18:10 VER: 04.06.05 Motherboard Model : MSI 970A-G43 Plus (MS-7974) Motherboard Chipset : AMD 970, AMD K15 DMI MB Manufacturer : MSI DMI MB Product : 970A-G43 PLUS (MS-7974) DMI MB Version : 1.0 DMI MB Serial : To be filled by O.E.M. DMI SYS Manufacturer: MSI DMI SYS Product : MS-7974 DMI SYS Version : 1.0 DMI SYS Serial : To be filled by O.E.M. DMI BIOS Version : V1.0 ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h) ITE SuperIO Device ID = 0000h (0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = 0909h (0000h / 0909h) Fintek SuperIO Port = 4Eh Fintek SuperIO HWMonitor Port = 0480h (0000h / 0480h) Fintek SuperIO Device ID = 0909h (0000h / 0909h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ LM78 ISA Sensor Device at 0480 ]------ 0000 FF A3 00 00 01 FF FF 00 FF FF 01 00 55 4C 00 30 0010 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF 0020 CC B0 89 6D 4A 9F C2 CD C6 FF FF FF FF 56 7F A9 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 44 FF FF 00 00 00 00 FF FF FF FF FF FF FF FF FF 0050 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF 0060 00 04 00 00 FF FF 04 75 00 00 FF 0A 40 28 FF 00 0070 FF FF 30 FF 4D FF 1B FF 00 00 00 00 00 2F 00 00 0080 FF FF 50 55 7D 55 55 46 FF FF FF FF FF FF A8 FF 0090 00 03 02 00 14 FF 1D FF 45 05 FF 15 55 05 99 1A 00A0 06 61 00 56 03 95 41 38 30 28 FF C6 8E 56 1E 1D 00B0 0F FF 00 7F 03 FF 3C 32 28 1E FF D9 B2 99 80 0D 00C0 06 15 00 A9 03 FF 3C 34 2E 28 FF DB BC 9E 7F 1D 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 00 00F0 00 00 00 00 00 00 35 FF 00 B0 FF 00 FF 00 FF FF 0070 0072 0074 0076 0078 0079 007A 007B 007C 007D 007E 007F T: 255 48 77 27 0 0 0 0 0 47 0 0 T: 255 48 77 27 0 0 0 0 0 47 0 0 T: 255 48 77 27 0 0 0 0 0 48 0 0 T: 255 48 77 27 0 0 0 0 0 47 0 0 T: 255 48 77 27 0 0 0 0 0 47 0 0 T: 255 48 77 28 0 0 0 0 0 48 0 0 T: 255 48 77 27 0 0 0 0 0 46 0 0 T: 255 48 77 27 0 0 0 0 0 49 0 0 T: 255 48 77 27 0 0 0 0 0 47 0 0 T: 255 48 77 27 0 0 0 0 0 47 0 0 0020 0021 0022 0023 0024 0025 0026 0027 0028 V: CB B0 89 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CB B0 89 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CB B0 89 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CB B0 88 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CB B1 89 6D 4A 9D C2 CD C6 [ VID = 1.41250 V ] V: CB B1 89 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CB B1 89 6D 4A 9D C1 CE C6 [ VID = 1.41250 V ] V: CB B1 89 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CC B1 89 6D 4A 9D C1 CD C6 [ VID = 1.41250 V ] V: CC B1 89 6D 4A 9F C2 CD C6 [ VID = 1.41250 V ] ------[ SB7xx/8xx/9xx PM2 at 0CD0 ]------ 0000 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0010 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0020 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0030 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0040 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 1F 00 00 00 00 00 01 00 00 FF FF 01 00 00 FF FF 0070 01 00 00 FF FF 01 00 00 FF FF 01 00 00 FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 00 55 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 00B0 00 FF 55 55 FF 00 00 FF 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF 00E0 00 00 00 00 00 00 00 00 00 FF FE 1F 01 00 00 04 00F0 19 0A 02 05 C8 20 80 00 05 06 00 00 08 08 00 42 Reg$59VIN0: r = $FFFF, r*0.000046 = 3.0146 Reg$5DVIN1: r = $FFFF, r*0.000046 = 3.0146 Reg$61VIN2: r = $0000, r*0.000046 = 0.0000 Reg$65VIN3: r = $0100, r*0.000046 = 0.0118 Reg$69VIN4: r = $FFFF, r*0.000046 = 3.0146 Reg$6DVIN5: r = $FF00, r*0.000046 = 3.0029 Reg$71VIN6: r = $0000, r*0.000046 = 0.0000 Reg$75VIN7: r = $0001, r*0.000046 = 0.0000 ------[ SB7xx/8xx/9xx PM at 0CD6 ]------ 0000 0E 00 4F 4A 00 04 00 02 B4 05 04 02 06 21 43 55 0010 FF 0F 00 00 FF 0F 00 00 00 00 00 00 00 00 00 00 0020 00 00 D1 FE 01 00 D8 FE 25 0B 00 00 01 0B 00 00 0030 00 00 00 00 07 00 C0 FE 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 80 F1 00 C0 FE 03 00 00 00 0050 1F 00 D0 FE 90 00 00 97 01 FF 15 44 00 05 00 01 0060 00 08 04 08 08 08 10 08 20 08 B2 00 00 FE BA 00 0070 00 00 00 00 17 00 00 06 FF FF 00 00 85 01 E0 A0 0080 1F 1A 06 20 00 00 00 00 30 10 00 00 9E 00 80 00 0090 02 05 02 0B 05 00 10 00 00 10 00 10 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 0B 05 05 08 00 08 40 02 00 53 00 00C0 F9 0B 58 40 3C 02 00 00 2C 40 28 00 FF FF FF FF 00D0 00 00 30 00 00 00 00 00 1E 00 99 00 01 00 10 03 00E0 D8 0C 00 00 00 00 00 02 00 00 00 01 03 12 00 7F 00F0 9C 03 00 00 00 00 00 21 6C 27 00 00 00 00 00 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : ========================================================================== ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI SMBus Port : 0B00 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D10 ]------ 0000 03 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D10 ]------ 0000 0003 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 00FF 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 00FF 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 00FF 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D20 ]------ 0000 03 00 00 00 00 00 00 00 00 00 00 00 00 00 3E 8B ..............>. 0010 00 00 00 00 00 00 1B 9E C0 00 B3 00 49 00 0C 05 ............I... 0020 09 09 09 09 FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D20 ]------ 0000 0003 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 4300 8B43 008B 0010 0000 0000 0000 0000 0000 1A00 9E19 C09E 00C0 B300 00B3 4900 0049 0C00 050C 0905 0020 FF09 FF09 FF09 FF09 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D50 ]------ 0000 92 13 0B 02 04 21 00 09 03 52 01 08 0A 00 FC 00 .....!...R...... 0010 69 78 69 30 69 11 18 81 20 08 3C 3C 00 F0 82 05 ixi0i... .<<.... 0020 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 85 9B 00 00 00 A7 0A A7 AD F8 0F ................ 0080 43 54 31 30 32 34 36 34 42 41 31 36 30 42 2E 43 CT102464BA160B.C 0090 31 36 01 00 80 2C 34 31 36 33 36 36 31 32 34 FF 16...,416366124. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D51 ]------ 0000 92 13 0B 02 04 21 02 09 03 52 01 08 0A 00 FC 00 .....!...R...... 0010 69 78 69 30 69 11 18 81 20 08 3C 3C 00 F0 82 05 ixi0i... .<<.... 0020 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 85 9B 0F 16 30 13 68 7F 57 53 88 .........0.h�WS. 0080 43 54 31 30 32 34 36 34 42 44 31 36 30 42 2E 43 CT102464BD160B.C 0090 31 36 01 00 80 2C 44 50 41 47 4B 47 31 30 30 35 16...,DPAGKG1005 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ *** SMBus Semaphore Disabled = 0 ------[ Chips Found ]------ B00-D51: SPD is this OK? Quote
Fiery Posted November 18, 2016 Posted November 18, 2016 Thank you. Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works 1 Quote
