Good morning! This is my first post, I found out about this site after researching my options for a front panel. I LOVE what this software can do, but I need to have it on a front panel for my desks, and I can't find a compatible nice full color display that would fit my needs. i'm surprised there isn't a list on here... Anyways, I have developed a new line of computer desks and currently, I have the designed the panel opening to use the Asus ROG Front Panel's guts. And honestly, it looks great, but the problem is that it only works with ASUS motherboards. I would like to find a panel close to the same size (it can be up to 5") . I would love to have a display like the one I posted below. Here is  photo of the desk I am now manufacturing. if someone can recommend a great screen to use and it works out, i will give a big discount to anyone on this forum who orders one ;). I am currently making these in Moscow, Russia, but I ma working on starting production in the United States within the month. I don't need a panel with the mounts for an opening... I just need a panel that I can mount into my own opening (I will redesign the desk to accommodate the proper size).
The desk looks awesome, great job there!  However, your choice on the LCD panel will be a challenging task indeed.  The Matrix Orbital GTT line looks great from a distance, but when you look closely, its protocol is heavily limited and basically useless for quick (ie. real-time) full-frame updates.  The closest panel that might fit your requirements may be the LCDInfo USBD480:
http://www.lcdinfo.com/products/usbd480-lq043.html
It's expensive (just like the GTT), but it supports quick full-frame updates and is 100% compatible with AIDA64.
