norti Posted August 23, 2017 Posted August 23, 2017 Hi Fiery! On the latest Windows Insider build from today and with the latest beta of AIDA64 most of the sensors are not recognized. Can you please look into this? Or should I reinstall AIDA64 and see if this solves the problem? Thanks! norti Quote
Trigger2142 Posted August 25, 2017 Posted August 25, 2017 Same here. Should I go back a version? Quote
kpo127 Posted August 25, 2017 Posted August 25, 2017 I don't think it would help. I just uninstalled it and waiting for a fix or even a response. Since it's close to rtm something must have changed. Quote
kpo127 Posted August 25, 2017 Posted August 25, 2017 Another build just released, same issue build 16275 release 3 Quote
kpo127 Posted August 25, 2017 Posted August 25, 2017 There are 6 entries on Windows Insiders Feedback, up vote if you want. Quote
kpo127 Posted August 26, 2017 Posted August 26, 2017 Drag files here to attach, or choose files... Max total size 11.59MB Insert other media Uploaded Images Quote
ViRuS2k Posted August 26, 2017 Posted August 26, 2017 I'm having the same issue, latest beta of aida32 on windows build 16275 RC3 no sensor information is being detected apart from gpu voltages not even motherboard information is being detected or proper cpu detection either or psu detection.... and that's on the latest aida32 build 5.92.4337 this issue has happened because of the last 2 windows 10 insider build updates if you want it working again your going to need to revert back 2 build updates on windows 10 or wait for a aida64 fix with update..... Quote
norti Posted August 26, 2017 Author Posted August 26, 2017 So it seems, it's a Windows 10 bug, hopefully they will fix this until the Fall Update. Quote
Fiery Posted August 28, 2017 Posted August 28, 2017 We wanted to wait to tell final judgement on this issue until we have more info and more input. It's a Windows 10 bug indeed that plagues Windows 10 Insider Build 16273 and 16275, but only the 64-bit editions. It prevents certain software to install and use its otherwise perfectly fine kernel driver. The issue affects several software, not just AIDA64. We're already working on a workaround, but we also expect Microsoft to fix this up soon. I'll post a message into this topic once we have an update. 3 Quote
Fiery Posted August 29, 2017 Posted August 29, 2017 We've implemented a workaround for this issue in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Quote
pbcopter Posted August 29, 2017 Posted August 29, 2017 The work around in the beta, 4341 fixed this problem for me. Quote
kpo127 Posted August 29, 2017 Posted August 29, 2017 (edited) New Windows build 16278 just released, and Aida64 is broken again, same as before latest beta was released. Edited August 29, 2017 by kpo127 add screen shot Quote
norti Posted August 30, 2017 Author Posted August 30, 2017 20 hours ago, Fiery said: We've implemented a workaround for this issue in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works It worked (although temperature updates were a little slow)... until W10 Insider build 16278 dropped in Quote
Fiery Posted August 30, 2017 Posted August 30, 2017 3 hours ago, norti said: It worked (although temperature updates were a little slow)... until W10 Insider build 16278 dropped in You're right, 16278 carries on the issue. We need to release one more AIDA64 hotfix to get around it again. We'll do that tomorrow or worse case Friday. I'll post a message into this topic once the new AIDA64 beta build is available for download. 2 Quote
Fiery Posted August 31, 2017 Posted August 31, 2017 Here's the new AIDA64 beta that implements the previous workaround for Win10 Insider Preview Build 16278 as well: https://www.aida64.com/downloads/latesta64xebeta This time we've made it a bit more future-proof by enabling the workaround between all Win10 builds in the range of 16273 and 16500. 1 Quote
Fiery Posted August 31, 2017 Posted August 31, 2017 1 hour ago, kpo127 said: Thank you Fiery. Works great. Thank you for your feedback. The workaround should work with RS4 Insider Preview Build 16353 as well Quote
kpo127 Posted August 31, 2017 Posted August 31, 2017 You're welcome. I am not on skip ahead ring since who knows what Microsoft does anymore and doesn't tell. Quote
Fiery Posted September 8, 2017 Posted September 8, 2017 On 2017. 09. 02. at 8:08 AM, kpo127 said: Working fine on 16281 also, thanks. Thank you for your feedback Quote
