On ‎01‎/‎09‎/‎2017 at 2:43 PM, Fiery said:
Is phantom throttle different to "classic" throttling of Intel processors, dating back to Pentium II ?
I do not know at all, I do not have this platform yet.
It will be just the frequency that will fall on 1 or more cores and it will not be visible unless we have a monitoring on all the cores at the same time
In case the core frequency of the individual CPU cores fluctuate, then AIDA64 already has got per-core frequency monitoring items for OSD Panel, SensorPanel, etc. ;)
Ok thanks ;)
We must have OSD Panel or SensorPanel to view it
No warning message if frequency of one of the cores drops during stress
2 hours ago, tistou77 said:
Ok thanks ;)
You can also log the readings using the Logging facility, or have a Min/Max/Average of the values collected by the AIDA64 System Stability Test.
Ok thanks
with energy saving, the frequency is lower in idle, difficult to see
But it will seem that there are options in the bios for not having this
phantom throttle
