I have an AIDA64 Extreme error after AMD Crimson ReLive 17.5.2, and there is still no AMD Crimson ReLive 17.9.3, GPU usage is locked at 16%, see a photo.
Note: I use a Gigabyte RX 570 G1 Gaming 4GB, and it looks like the error is on the entire RX 500 line from AMD.
We've checked, and we haven't been able to reproduce this issue with either Crimson 17.5.2 or 17.9.3 WHQL.  Maybe because we use a RX 560 test card, and the issue affects only RX 570 and RX 580?
Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> ATI GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
BTW, have you tried to install the recently released Crimson 17.9.3. WHQL driver?  I wonder if that makes this issue go away or not.
This problem occurred after drive 17.5.2, in that drive a GPU load detection, is in normal state.
Obs: I'm using Crimson 17.9.3 WHQL.
atigpureg.txt
atigpureg.txt
Thank you.  Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know how it works.
Now, yes, I had tested the beta version of the site and continued with the bug, but with this beta version that you passed, it is working perfectly. Thank you.
Note: It's time to update the stable version now on the site.
