Dave_OC Posted November 13, 2017 Posted November 13, 2017 I recently updated my PC motherboard to an Asus Z370-A Prime. The current version and beta 5.92.4383 does not detect any motherboard fans and the CPU temp (not core temps) does not update. HWmonitor sees the fans and updates CPU temp. Quote
Fiery Posted November 14, 2017 Posted November 14, 2017 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Dave_OC Posted November 14, 2017 Author Posted November 14, 2017 Enclosed dump files ecdump.txt isasensordump.txt Quote
Fiery Posted November 15, 2017 Posted November 15, 2017 17 hours ago, Dave_OC said: Enclosed dump files ecdump.txt isasensordump.txt Thank you. Are you sure you're using the latest beta build of AIDA64 v5.92.4383, which implements support for Asus Z370 motherboards? I'm just asking because your dumps were done by the latest stable build of v5.92.4300 that has no specific support for your motherboard. Quote
Dave_OC Posted November 15, 2017 Author Posted November 15, 2017 Sorry, updated files included. isasensordump.txt ecdump.txt Quote
Fiery Posted November 17, 2017 Posted November 17, 2017 On 2017. 11. 15. at 1:40 PM, Dave_OC said: Sorry, updated files included. isasensordump.txt ecdump.txt Thank you! The issue will be fixed in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta is available for download. Quote
Fiery Posted November 23, 2017 Posted November 23, 2017 The above mentioned new AIDA64 beta update is now available for download: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. Quote
Fiery Posted December 2, 2017 Posted December 2, 2017 On 2017. 11. 24. at 10:39 PM, Dave_OC said: Works great, thanks !!! Thank you for your feedback Quote
