OJ287 Posted November 18, 2017 Posted November 18, 2017 I recently updated my motherboard to an ROG X370-F Strix. Even the current version and beta 5.92.4391 shows abnormal Temperatures, Cooling Fans and Voltage Values (BOLD) Temperatures Motherboard -1 °C (30 °F) CPU -18 °C (-0 °F) CPU Diode 28 °C (82 °F) Chipset 58 °C (136 °F) GPU Diode 39 °C (102 °F) HGST HTS725050A7E630 27 °C (81 °F) Cooling Fans CPU 2836 RPM Chassis #1 11 RPM Chassis #2 10 RPM GPU 0 RPM (0%) Voltage Values CPU Core 0.875 V CPU VID 0.875 V CPU VDD 1.119 V CPU VDDNB 1.050 V+3.3 V 4.186 V +5 V 5.232 V +12 V 16.677 V GPU Core 0.650 V The same time - HWMonitor & HWinfo - shows normal values, except PSU rails, which are not monitored. isasensordump.txt ecdump.txt Quote
Fiery Posted November 19, 2017 Posted November 19, 2017 There seems to be a MMIO communication issue affecting your motherboard. We've contacted Asus to find out what shall we do in order to fix this up on our end -- or whether this is due to a BIOS bug that Asus will fix soon. I'll let you know in this topic once we have an update to this. 1 Quote
OJ287 Posted November 19, 2017 Author Posted November 19, 2017 Thank you very much! I already thought to RMA the motherboard. Quote
OJ287 Posted November 20, 2017 Author Posted November 20, 2017 SOLVED The reason is the problem caught in the rush of many system owners on AMD Ryzen + Creative X-Fi sondcards. And as I understand it happened with the release of the Windows 10 Fall Creators Update 1709. More details can be found here - Creative X-Fi Soundcards and Windows 10 Fall Creators Update 1709 = Complete Disaster / Not Working. I also ran into this problem, but did not associate it with the strange values of the sensors in Aida64. So, when I unveil a sound card - all sensors show normal values. Thank you for your responsiveness. Quote
Fiery Posted November 23, 2017 Posted November 23, 2017 Thank you for letting us know about the root cause of that issue. Quote
