tistou77 Posted January 16, 2018 Report Share Posted January 16, 2018 Hello is it possible to add the Power value of cores ? Just 1 line, the value of the cores is the same from what I tested with SIVIf SVID is disabled in the bios, the Power value is distorted, but those of the cores are goodSee screen SIV and Aida64 Thanks Quote Link to comment Share on other sites More sharing options...
tistou77 Posted January 24, 2018 Author Report Share Posted January 24, 2018 I guess it's not possible Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 24, 2018 Report Share Posted January 24, 2018 8 hours ago, tistou77 said: I guess it's not possible I'm not sure if it's possible. We'll try an older method that worked on previous Asus ROG motherboards, and we'll see A new AIDA64 beta build should be ready sometime tomorrow. I'll post a message into this topic once the new beta build is available for download. Quote Link to comment Share on other sites More sharing options...
tistou77 Posted January 25, 2018 Author Report Share Posted January 25, 2018 Ok, thanks Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 25, 2018 Report Share Posted January 25, 2018 1 hour ago, tistou77 said: Ok, thanks Here's the above mentioned new AIDA64 beta build: https://www.aida64.com/downloads/latesta64xebeta Quote Link to comment Share on other sites More sharing options...
tistou77 Posted January 25, 2018 Author Report Share Posted January 25, 2018 It's good, the CPU Power value is indicatedAida64 indicates a really weaker value than SIV, but I do not know who is goodAida64Idle : between 17 and 25WLoad : 195W SIVIdle : 50W (do not vary)Load : ~280W7940X at 4600mhz and 1.185v Thanks for your great work Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 25, 2018 Report Share Posted January 25, 2018 16 minutes ago, tistou77 said: It's good, the CPU Power value is indicatedAida64 indicates a really weaker value than SIV, but I do not know who is goodAida64Idle : between 17 and 25WLoad : 195W SIVIdle : 50W (do not vary)Load : ~280W7940X at 4600mhz and 1.185v Thanks for your great work Thank you for your feedback. I'd say the values reported by AIDA64 are closer to the truth than SIV's Quote Link to comment Share on other sites More sharing options...
tistou77 Posted January 25, 2018 Author Report Share Posted January 25, 2018 10 minutes ago, Fiery said: Thank you for your feedback. I'd say the values reported by AIDA64 are closer to the truth than SIV's Thanks for your great work Quote Link to comment Share on other sites More sharing options...
