Hello
Vcache reading is wrong
By setting to 1.0, 1.05 or 1.1v, Aida64 always reads the same value in load (~ 1.07, 1.08v)
With the Probe It, the voltages are those indicated in the bios
Is it possible to correct this problem or is it related to the Asus bios and only Asus can correct this problem ?
Thanks
Do you have EC bank switching enabled in AIDA64 / main menu / File / Preferences / Stability?  If yes, then please create the following 2 dumps and post them as TXT file attachments to your post at both 1.00V Vcache setting and 1.10V Vcache setting.  We have 2 registers that may hold Vcache, and cannot decide which one is the right one I'm afraid :(
1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump.
2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump.
On ‎2018‎. ‎03‎. ‎20‎. at 12:29 PM, tistou77 said:
Seems to be good with 1201 bios
1.05v in bios, 1.05v with Probe It,
And between 1.034v (idle) and 1.044v (load) with Aida64
Thank you for your feedback ;)
