namuk Posted September 21, 2018 Posted September 21, 2018 have the 5.98 as i was waiting for full support for the cooler, but this issue is the fans speeds are reported higher RPM in AIDA64 ? is there a reason why ? Quote
Fiery Posted September 23, 2018 Posted September 23, 2018 On 9/21/2018 at 8:37 PM, namuk said: have the 5.98 as i was waiting for full support for the cooler, but this issue is the fans speeds are reported higher RPM in AIDA64 ? is there a reason why ? What is the exact difference between the measured values, at various fan speeds? Maybe there's a 0.5x or 0.33x ratio that has to be applied to the readings? Quote
namuk Posted September 23, 2018 Author Posted September 23, 2018 7 hours ago, Fiery said: What is the exact difference between the measured values, at various fan speeds? Maybe there's a 0.5x or 0.33x ratio that has to be applied to the readings? in icue rpm shows say 900rpm at average but in AIDA64 it shows around 1250rpm its always shows around 300% higher than what it shows in icue Quote
Fiery Posted September 25, 2018 Posted September 25, 2018 On 9/24/2018 at 1:49 AM, namuk said: in icue rpm shows say 900rpm at average but in AIDA64 it shows around 1250rpm its always shows around 300% higher than what it shows in icue I suppose when you check AIDA64, iCUE is closed, right? Maybe iCUE changes the fan PWM settings before quitting and/or when you open it. We've checked with default settings on our H150i Pro device, and both fan RPMs and pump RPM are identical across AIDA64 and iCUE. Quote
namuk Posted September 25, 2018 Author Posted September 25, 2018 6 hours ago, Fiery said: I suppose when you check AIDA64, iCUE is closed, right? Maybe iCUE changes the fan PWM settings before quitting and/or when you open it. We've checked with default settings on our H150i Pro device, and both fan RPMs and pump RPM are identical across AIDA64 and iCUE. icue is not closed but i did try it closed and the cooler fan speeds still show higher in AIDA64, is there anything i need to tick or untick in stability , only corsair box that i ticked is the AXI psu box as i have the axi psu Quote
Fiery Posted September 25, 2018 Posted September 25, 2018 30 minutes ago, namuk said: icue is not closed but i did try it closed and the cooler fan speeds still show higher in AIDA64, is there anything i need to tick or untick in stability , only corsair box that i ticked is the AXI psu box as i have the axi psu You only need to have Asetek LC sensor support enabled in order to have H115i Pro readings. Quote
namuk Posted September 25, 2018 Author Posted September 25, 2018 2 hours ago, Fiery said: You only need to have Asetek LC sensor support enabled in order to have H115i Pro readings. yea did that a while ago with my old h100 v2 , all fan speeds show fine across the board its just cooler fan speeds even pump fan speed shows ok, i have got an asus Mb unless thats the issue, but fans show ok in icue Quote
Fiery Posted September 26, 2018 Posted September 26, 2018 8 hours ago, namuk said: yea did that a while ago with my old h100 v2 , all fan speeds show fine across the board its just cooler fan speeds even pump fan speed shows ok, i have got an asus Mb unless thats the issue, but fans show ok in icue It must be something about your fans. Are they 3-wire or 4-wire fans? Quote
namuk Posted October 8, 2018 Author Posted October 8, 2018 On 9/26/2018 at 7:42 AM, Fiery said: It must be something about your fans. Are they 3-wire or 4-wire fans? 4, the ones supplied Quote
namuk Posted November 21, 2018 Author Posted November 21, 2018 fans now are showing correct rpm now in 5.99.4900 as now is showing the fans in cooling,so i am using them instead of the cpu opt and opt3. also seen temp is there now a correct dedicated pump nice one Quote
Fiery Posted November 27, 2018 Posted November 27, 2018 On 11/21/2018 at 8:45 PM, namuk said: fans now are showing correct rpm now in 5.99.4900 as now is showing the fans in cooling,so i am using them instead of the cpu opt and opt3. also seen temp is there now a correct dedicated pump nice one So everything is working properly now? Quote
namuk Posted December 4, 2018 Author Posted December 4, 2018 On 11/27/2018 at 8:57 AM, Fiery said: So everything is working properly now? it is mate, all rpm and temps ect are bang on as i still use the alphalcd and SDC meg linked to AIDA, very happy Quote
Fiery Posted December 4, 2018 Posted December 4, 2018 8 hours ago, namuk said: it is mate, all rpm and temps ect are bang on as i still use the alphalcd and SDC meg linked to AIDA, very happy Awesome Quote
