AIDA64 shows the APC Battery backup I have on the system
But it shows no battery under Power Management
Is this as it should be?
I guess it's because your battery doesn't support standard Windows smart battery interface (API) that AIDA64 uses.
It appears not... a reply from APC:
Thank you for the update. There is no API for any APC Software. All that Business Edition (PSBE) offers is the console portion for the GUI. Using a different SNMP or monitoring interface might cause conflict to our software which is PCBE. PCBE should allow you to monitor the UPS. The ports needed by this software should be free in order to work properly
Oh well, C'est la vie.
I have the exact same problem with my Eaton Protection Station 800VA.
