fixed: AIDA64 Desktop Gadget width issue (4K display with 150% scaling)
sblantipodi
On ‎10‎/‎22‎/‎2018 at 10:04 PM, sblantipodi said:
Hi,
I'm using the AIDA64 gadget on windows 10 on a 4K panel at 150% scaling.
Is it possible to resize the AIDA64 gadget to fit the text without wrapping it to the next line?
Can I increment the width of the widget?
Thanks
We need to reproduce the problem on our own Win10 test systems with a 4K display.  Please let us know what tool/trick you use to be able to use the Vista Desktop Gadgets under Win10.
On ‎10‎/‎27‎/‎2018 at 3:51 AM, sblantipodi said:
Simply use the good old 8gadgetpack
thanks
Thank you!  Make sure to upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know if it helps.
fiery I love your software, your work is excellent.
thank you
