On ‎11‎/‎24‎/‎2018 at 7:48 PM, Michael O said:
Hello
I bought the new H155i Platinum RGB, very nice cooler! However, no sesnors are detected by A64.
I attached both logs for you to take a look at.
Thank you.
corsairlinkdump.txt
usbdump.txt
Thank you for the files.  We'll need to order a unit to help us investigate this issue.  The new Platinum coolers apparently use a brand new protocol that we need to analyze and implement support for it.  As soon as it becomes available in local stores, we'll order one and start working on it.
  • 2 months later...
Hello
Thank you.
corsairlinkdump.txt
usbdump.txt
We've implemented preliminary support for H115i Platinum sensor monitoring in the latest AIDA64 beta update:
It may not work reliably while Corsair iCUE is running concurrently with AIDA64.  Please let me know how it works on your system.
