djg Posted December 2, 2018 Posted December 2, 2018 Hi Fiery, Is there any chance of getting amperage used by volts? All I can see currently is the voltages n my Corsair HX850i. Cheers!. Quote
Fiery Posted December 3, 2018 Posted December 3, 2018 8 hours ago, djg said: Hi Fiery, Is there any chance of getting amperage used by volts? All I can see currently is the voltages n my Corsair HX850i. Cheers!. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Corsair Link Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> USB PSU Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
djg Posted December 3, 2018 Author Posted December 3, 2018 7 hours ago, Fiery said: Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Corsair Link Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> USB PSU Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Thanks Fiery, here you go: corsairlinkdump.txt usbpsudump.txt Quote
Fiery Posted December 3, 2018 Posted December 3, 2018 9 minutes ago, djg said: Thanks Fiery, here you go: corsairlinkdump.txt usbpsudump.txt Thank you. Your HX850i PSU isn't seem to be connected to any of the USB ports of your computer, and it's also not connected to a Corsair Commander unit or another unit that would support Corsair Link. PSU current and power readings, as well as PSU thermal reading can only be measured if you connect your PSU to a USB port or a Corsair Link capable central unit. Quote
djg Posted December 3, 2018 Author Posted December 3, 2018 10 minutes ago, Fiery said: Thank you. Your HX850i PSU isn't seem to be connected to any of the USB ports of your computer, and it's also not connected to a Corsair Commander unit or another unit that would support Corsair Link. PSU current and power readings, as well as PSU thermal reading can only be measured if you connect your PSU to a USB port or a Corsair Link capable central unit. There are two connectors on the PSU. I have their included USB cable connected to the PSU mini-USB connector and a MB USB connector. Maybe one of those is defective. I'll check. I had some weird bad stuff that happened while trying a Thermaltake PSU which is on its way back to Newegg :(. Thanks! Quote
djg Posted December 3, 2018 Author Posted December 3, 2018 30 minutes ago, Fiery said: Thank you. Your HX850i PSU isn't seem to be connected to any of the USB ports of your computer, and it's also not connected to a Corsair Commander unit or another unit that would support Corsair Link. PSU current and power readings, as well as PSU thermal reading can only be measured if you connect your PSU to a USB port or a Corsair Link capable central unit. 19 minutes ago, djg said: There are two connectors on the PSU. I have their included USB cable connected to the PSU mini-USB connector and a MB USB connector. Maybe one of those is defective. I'll check. I had some weird bad stuff that happened while trying a Thermaltake PSU which is on its way back to Newegg :(. Thanks! That was it - I tried a different MB connector and now it all shows. Thanks! Quote
Fiery Posted December 3, 2018 Posted December 3, 2018 20 minutes ago, djg said: That was it - I tried a different MB connector and now it all shows. Thanks! Awesome Quote
