metroidao Posted February 2, 2020 Posted February 2, 2020 Hello my motherboard is a z370 aorus gaming 7, the temperature sensors are losing their reading randomly and setting at -64 and the rpm sensors of the coolers are setting at 14 in reading. After restarting the computer everything goes back to normal, but after some time random again loses the readings desdump.txt ecdump.txt isasensordump.txt sensorprof.txt Quote
Fiery Posted February 3, 2020 Posted February 3, 2020 14 hours ago, metroidao said: Hello my motherboard is a z370 aorus gaming 7, the temperature sensors are losing their reading randomly and setting at -64 and the rpm sensors of the coolers are setting at 14 in reading. After restarting the computer everything goes back to normal, but after some time random again loses the readings When that anomaly occurs, it seems for some reason AIDA64 is unable to communicate with the primary sensor chip of your motherboard. Do you have any other monitoring software running in the background that may interfere with AIDA64? Quote
metroidao Posted February 3, 2020 Author Posted February 3, 2020 no, i already formatted the computer and used only aida64 to see if it solves and the problem continues Quote
metroidao Posted February 10, 2020 Author Posted February 10, 2020 since the last time i posted today it happened again, but this time the sensor reading just disappeared. I'm not using any other reading plugin, just aida64 desdump.txt ecdump.txt isasensordump.txt sensorprof.txt Quote
metroidao Posted January 14, 2021 Author Posted January 14, 2021 1 years later and still has the same problem, now it is at zero as in the image above Quote
Fiery Posted January 18, 2021 Posted January 18, 2021 On 1/14/2021 at 7:20 AM, metroidao said: 1 years later and still has the same problem, now it is at zero as in the image above Since noone else with a Gigabyte motherboard similar to yours reported issues like what you've been experiencing, I have to assume that your motherboard has issues providing sensor readings in a constant and reliable fashion; or there's a software running on your system that interferes with AIDA64. BTW, incidently we have the same motherboard than yours and on our sample we also cannot reproduce your issue. 1 Quote
MrNoSpareTime Posted April 19, 2021 Posted April 19, 2021 I have that issue on my x570 gigabyte MB. runs fine for 5-20 hrs or more and then stops reading most sensors. Next time it happens i am going to check the System Information Viewer that Gigabyte has by default to see if the readings drop there too. Perhaps it is the gigabyte SIV that is the other monitoring program causing the issue. Quote
