tistou77 Posted June 19, 2020 Posted June 19, 2020 Hello Is it possible to have the power value "correctly" like SIV 64 (The highest value) ? Thanks Quote
Fiery Posted June 22, 2020 Posted June 22, 2020 On 6/19/2020 at 2:09 PM, tistou77 said: Hello Is it possible to have the power value "correctly" like SIV 64 (The highest value) ? Thanks I'm not sure what correctly means and why would AIDA64 show the highest measured value. I'm also not sure how one CPU core could possibly draw cca. 250-300 Watts (as shown by SIV64). Quote
tistou77 Posted June 22, 2020 Author Posted June 22, 2020 39 minutes ago, Fiery said: I'm not sure what correctly means and why would AIDA64 show the highest measured value. I'm also not sure how one CPU core could possibly draw cca. 250-300 Watts (as shown by SIV64). It must be the maximum "full" CPU consumption @ 4.6ghz = 300W @ 4.1ghz 250W The other monitoring reports 300W too Just Aida64 which is too low (125W) Quote
Fiery Posted June 23, 2020 Posted June 23, 2020 15 hours ago, tistou77 said: It must be the maximum "full" CPU consumption @ 4.6ghz = 300W @ 4.1ghz 250W The other monitoring reports 300W too Just Aida64 which is too low (125W) Minimum, maximum and average values are shown on the Statistics tab of AIDA64 System Stability Test. You can also use the Logging facility to track minimum, maximum and average values. As for 250W/300W vs. 125W, my point was that I don't think a single core (as shown by SIV64) can draw 250-300W on your CPU -- or any CPU for that matter. And when a reported value seems way off, I tend to completely ignore the values. Quote
tistou77 Posted June 23, 2020 Author Posted June 23, 2020 The 300W is good for 4600ghz It is impossible that an 18 cores "consumes" 125W at 4600ghz Quote
tistou77 Posted June 23, 2020 Author Posted June 23, 2020 Ah I understand, the good value is CPU package CPU value does not match anything Unlike SIV64X or other monitoring, Aida64 does not indicate the correct value (CPU Package) if the SVID option is not enabled Quote
Fiery Posted July 9, 2020 Posted July 9, 2020 On 6/23/2020 at 9:40 AM, tistou77 said: Ah I understand, the good value is CPU package CPU value does not match anything Unlike SIV64X or other monitoring, Aida64 does not indicate the correct value (CPU Package) if the SVID option is not enabled "CPU" power is provided by the sensor chip of certain Asus motherboards. It could be a challenge to puzzle it together what that value actually means We just show it because it is definitely a meaningful value and related to the CPU, but its accuracy has to be researched and evaluated by the user. Quote
tistou77 Posted July 9, 2020 Author Posted July 9, 2020 1 minute ago, Fiery said: "CPU" power is provided by the sensor chip of certain Asus motherboards. It could be a challenge to puzzle it together what that value actually means We just show it because it is definitely a meaningful value and related to the CPU, but its accuracy has to be researched and evaluated by the user. Ok thanks, With the Rampage VI Extreme Encore, I no longer have this value, it's good for me (no real need to have it) Quote
