RikiBit Posted January 29, 2012 Posted January 29, 2012 I use frequently the "great" LOGGING feature of Aidi64 Extreme. But what I'm missing is the ability to enable/disable the logging feature much faster via eg the context menu of the Aida Icon in the system tray. Currently it is only possible via preferences\logging, check the check-box and clicking "apply". That's a bit time wasting and it is also not possible to find out via the context menu of the sys tray icon if Logging is either active or not. Of course if logging is not yet enabled the first time in preferences and there is no file location entered, the enable/disable ability in the sys tray icon context menu should be inactive (eg grey text). thx Quote
Fiery Posted February 2, 2012 Posted February 2, 2012 We'll add the requested menu item soon in a new AIDA64 beta release. Do you log into HTML or CSV file? Thanks, Fiery Quote
Fiery Posted February 15, 2012 Posted February 15, 2012 We've implemented the requested menu item in the System Tray menu in the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1822hfxtpmdk4vzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Thanks, Fiery Quote
RikiBit Posted February 23, 2012 Author Posted February 23, 2012 Great Thx I log using HTML. But I will wait on the stable release, if this is oké for you? Quote
Fiery Posted February 23, 2012 Posted February 23, 2012 It's up to you Our beta releases are usually just as stable as a stable release, so no risk on using a beta. Quote
