gbubrodieman Posted November 26, 2020 Posted November 26, 2020 Playing around with the trial, I don't see support for NZXT's smart device to read case fan speeds. Am I missing it or does AIDA not support it? Quote
Fiery Posted December 2, 2020 Posted December 2, 2020 On 11/26/2020 at 6:20 PM, gbubrodieman said: Playing around with the trial, I don't see support for NZXT's smart device to read case fan speeds. Am I missing it or does AIDA not support it? AIDA64 currently does not support NZXT Smart Device v2. Do you know where can it be purchased? Quote
gbubrodieman Posted December 3, 2020 Author Posted December 3, 2020 It a device in my NZXT 510 elite that controls the case fans. Quote
Fiery Posted January 9, 2021 Posted January 9, 2021 On 12/3/2020 at 11:35 PM, gbubrodieman said: It a device in my NZXT 510 elite that controls the case fans. We've ordered a NZXT RGB & Fan Controller device that should be the retail version of the Smart Device V2 in your PC. Until it arrives, please help us out a little bit by right-clicking on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. That dump will let us verify if your device really compatible with our upcoming NZXT RGB & Fan Controller device. Thank you in advance! Quote
Martin Piotrowski Posted January 20, 2021 Posted January 20, 2021 Happy to help out as I'd like to see this as well. Attached is USB Dump from my PC - also using Smart Device V2 (510i case). usbdump.txt Quote
neg12roni Posted February 11, 2021 Posted February 11, 2021 NZXT Smart Device2 USB dump.txt I've attached by USB dump as well. Quote
Fiery Posted March 3, 2021 Posted March 3, 2021 Thank you guys for the dumps! @gbubrodieman @Martin Piotrowski @neg12roni We've implemented support for NZXT Smart Device v2 as well as NZXT RGB & Fan Controller in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let us know how it works. Quote
