semool Posted November 26, 2010 Posted November 26, 2010 With aida64 i hava a Problem with the Fan in my Power Supply. My PS is an Enermax Modu 82+. It has a Fan and an Conector to put it on the Mainboard for reading rpm. Its works fine with the latest everst version. In aida64 he shows the rpm mostly 0 and every ~10seconds it shows the real rpm in osd. In the Mainwindow under computer->sensors in the section fans the ps fan siwtch from visible to invisible every few seconds. What i have found out is when i Start the Computer (Win7x64) and then i start everest all works fine. Then i close everest an start aida and all works fine. When i start the Computer an start directly aida the Problem exist. So i think its an bug in the kerneld driver?! Quote
Fiery Posted November 26, 2010 Posted November 26, 2010 I suppose it may be something to do with how AIDA64 handles the sensor chip of your motherboard. 1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 2) Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic. That data should help us to find out what went wrong since EVEREST Thanks, Fiery Quote
semool Posted November 27, 2010 Author Posted November 27, 2010 OK here are the files. I looks like he allways show 0rpm when the real rmp lower than 508rpm. smbusdump_full.txt isasensordump.txt Quote
Fiery Posted November 28, 2010 Posted November 28, 2010 Thank you for the dumps. We've fine-tuned the fan speeds measurement on your motherboard. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1165vs6mnwy3qxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
semool Posted November 29, 2010 Author Posted November 29, 2010 Thank you, now its working good. No jumps to zero since two-three Hours Quote
DS88579 Posted November 29, 2010 Posted November 29, 2010 In the Mainwindow under computer->sensors in the section fans the ps fan siwtch from visible to invisible every few seconds. +1 Asus P5Q Deluxe Win7x64 AIDA64EE 1.20.1150 Quote
Fiery Posted November 29, 2010 Posted November 29, 2010 +1 Asus P5Q Deluxe Win7x64 AIDA64EE 1.20.1150 Did the latest beta fix it for you too? Quote
MrX1980 Posted November 30, 2010 Posted November 30, 2010 for me too Motherboard Name = Asus M4N82 Deluxe (Bios 2301) Sensor Type = ITE IT8720F (ISA 290h) Aida64 1.20.1165 beta Quote
MrX1980 Posted December 1, 2010 Posted December 1, 2010 Sadly it seams not to be fixed for me. "Chassis #1" is the problem isasensordump.txt smbusdump_full.txt Quote
Fiery Posted December 1, 2010 Posted December 1, 2010 Sadly it seams not to be fixed for me. "Chassis #1" is the problem Thanks for the dumps. This one seems to be a completely different issue to the P5Q fan problem. Please copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic. Thanks, Fiery Quote
MrX1980 Posted December 4, 2010 Posted December 4, 2010 Here is the requested file/information. I think we should move this then as a new thread ? Can you do this? thx sensors.txt Quote
Fiery Posted December 4, 2010 Posted December 4, 2010 Here is the requested file/information. I think we should move this then as a new thread ? Can you do this? thx We can continue this thread. Thanks for the dump, but I cannot see any problem there. What's wrong with the Chassis #1 fan reading? Quote
MrX1980 Posted December 4, 2010 Posted December 4, 2010 "Chassis #1" is visible/unvisible every few seconds. I can make a video if you want. sensors2.txt Quote
Fiery Posted December 4, 2010 Posted December 4, 2010 "Chassis #1" is visible/unvisible every few seconds. I can make a video if you want. Video won't be necessary, thanks. 1) Are you running any Asus monitoring software next to AIDA64? E.g. Asus PC Probe, Asus TurboV? 2) Do you have the option "SMBus access through ACPI (Asus motherboards)" in AIDA64 / main menu / File / Preferences / Stability checked or unchecked? Quote
MrX1980 Posted December 4, 2010 Posted December 4, 2010 (edited) 1) Are you running any Asus monitoring software next to AIDA64? E.g. Asus PC Probe, Asus TurboV? No tools 2) Do you have the option "SMBus access through ACPI (Asus motherboards)" in AIDA64 / main menu / File / Preferences / Stability checked or unchecked? unchecked Update: With "ckecked" the delay between the switches is longer, but the problem still exist. Edited December 4, 2010 by MrX1980 Quote
Fiery Posted December 9, 2010 Posted December 9, 2010 1) Are you running any Asus monitoring software next to AIDA64? E.g. Asus PC Probe, Asus TurboV? No tools 2) Do you have the option "SMBus access through ACPI (Asus motherboards)" in AIDA64 / main menu / File / Preferences / Stability checked or unchecked? unchecked Update: With "ckecked" the delay between the switches is longer, but the problem still exist. Thank you for the info. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1176sdv5ynm2gczip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
MrX1980 Posted December 14, 2010 Posted December 14, 2010 Let me know how it works. Thanks, Fiery Hi this seams to work now. Thanks I will continue to monitor it. MrX1980 Quote
