D. J. Posted December 6, 2010 Share Posted December 6, 2010 I was trying to setup my friend's water cooling computer. He purchased Koolance TMS-200 tempreature controller and use AIDA64 Extreme to monitor the HW. I checked the option within the AIDA64 to support the TMS-200 controller. However I could not see any information as far as the TMS-200 controller is concerned. They both work fine on its own, the AIDA64 just does not report any sensors' readings from the TMS-200 unit. Could someone show me the light on this? Software used: AIDA64 V1.2 1150 Koolance TMS-200 V2.1.28 USB Driver (Prolific V1.30) Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 6, 2010 Share Posted December 6, 2010 The problem is with Koolance's software. It's not designed properly to allow 3rd party software to access the TMS-200 controller while it is running. In other words, you have to close Koolance's software to let AIDA64 open the TMS-200 controller. We've already contacted Koolance, and they seem to be ready to change their software to allow AIDA64 (and other 3rd party software as well) to work while Koolance's own software is running. They couldn't provide a timeframe though, so I'm not sure when can we expect the new software You may also want to refer to the previous thread on the same topic: Regards, Fiery Quote Link to comment Share on other sites More sharing options...
D. J. Posted December 13, 2010 Author Share Posted December 13, 2010 Here is the answer from Koolance Support Center: Re: AIDA64 and TMS-200 Controller by [Koolance] Tim » Mon Dec 06, 2010 10:39 am "Currently, the AIDA64 software maker says it won't work simultaneously while the TMS-200 software is open. Our lead programmer is working with them on that". Quote Link to comment Share on other sites More sharing options...
D. J. Posted December 24, 2010 Author Share Posted December 24, 2010 Koolance has released a new version of their TMS-200 controller. TMS-200 v.2.1.28 *Final* Updates: •Error log file now generated for debugging purposes, named "Req.log" and found in the TMS software install folder. •Added an option to fix the COM port used for TMS-200 so it doesn't need to rescan each time. The option is located at the top of the settings screen. •Added "Share Memory" feature at the bottom of the settings screen. This can be enabled to share TMS output data (pump speed, temperatures, etc.) for compatible 3rd-party programs. Can AIDA64 developer confirm the AIDA64 is one of the compatible 3rd-party programs? Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 27, 2010 Share Posted December 27, 2010 Thank you. We haven't found programming documentation or guidelines on the shared memory feature, so we have to ask Koolance to provide the necessary details so we can implement that in AIDA64. I'll let you know (in this topic) once we got the programming information from them. Quote Link to comment Share on other sites More sharing options...
Malfeitor Posted January 12, 2011 Share Posted January 12, 2011 Udvozletek! Has there been any update to this? I was thinking of buying one of these controllers but will only use AIDA to monitor my rig. I read that TMS Koolance code is a final version. Koszonom! (My Hungarian is rough lol) Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 12, 2011 Share Posted January 12, 2011 We asked Koolance for help about implementing shared memory support in AIDA64 on Dec-27, but got no reply from them yet. We've resent the inquiry email today, and hopefully this time it will go through. (Hungarian is indeed a very tough language, so no need for excuses ) Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 15, 2011 Share Posted January 15, 2011 Koolance provided us the necessary programming documentation, so we could implement shared memory support in the following new beta release of AIDA64 Extreme Edition: http://www.aida64.com/downloads/aida64extremebuild1224q0sln8yrvxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
D. J. Posted January 16, 2011 Author Share Posted January 16, 2011 I have quickly tested your new version that supports share memory for Koolance TMS-200 controller; 1. It does display tempreature sensor1 to 5, OK! 2. It only displays the speed of fan1 and fan2, no fan3! 3. It does not display the pump speed and flow rate at all! Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 26, 2011 Share Posted January 26, 2011 We've fixed the Fan#3 issue, and added Pump#1 and Pump#2 RPM reading in the following new beta version of AIDA64 Extreme Edition: http://www.aida64.com/downloads/aida64extremebuild1236qs6kmn3yrzzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. The flow rate monitoring will have to be implemented in a future version only, since AIDA64 Hardware Monitoring module currently doesn't support such measurements. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
D. J. Posted February 20, 2011 Author Share Posted February 20, 2011 The Flow rate monitoring is not implemented in 1.60 1300. Which future version will support such measurements? Quote Link to comment Share on other sites More sharing options...
Malfeitor Posted February 23, 2011 Share Posted February 23, 2011 Installed a TMS-200 and the EB-200. Running Koolance code 2.1.28 and AIDA 1.50.1236. All 10 sensors reporting correctly All 6 fans reporting correctly No issues to report with AIDA. I wish you would pick up the Koolance source code and rewrite it... Bring it up to the year 2010. All is well. Thank you Fiery. AIDA is a great program. Reading flowrate would be a BIG plus. Quote Link to comment Share on other sites More sharing options...
GoNz0 Posted February 26, 2011 Share Posted February 26, 2011 flowrate would be a very nice addition Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 4, 2016 Share Posted January 4, 2016 We've implemented flow rate measurement for both Koolance and T-Balancer devices in the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta The values are measured as raw values, as they are provided by the sensor device. To make them make a bit more sense, and also to convert them to LPH (Liter Per Hour), you need to use the Correction feature in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction. Quote Link to comment Share on other sites More sharing options...
