Malcolm1822 Posted June 8, 2023 Posted June 8, 2023 Hi, I am having issues on the above Graphicscard, that the memory temps are not showing up in the sensor tab. Any advice ? Thank you Quote
Malcolm1822 Posted August 18, 2023 Author Posted August 18, 2023 Bump, and news. Also attached the sensor dump for my GPU. atigpureg.txt Quote
Malcolm1822 Posted September 11, 2023 Author Posted September 11, 2023 Bump, can someone please take a look at this ? Quote
Malcolm1822 Posted March 7, 2024 Author Posted March 7, 2024 Hi, I am having issues on the above Graphicscard, that the memory temps are not showing up in the sensor tab. Any advice ? (HWinfo64 has this and more data in sensor mode) Thank you atigpureg.txt atismbusdump.txt Quote
Fiery Posted March 7, 2024 Posted March 7, 2024 2 hours ago, Malcolm1822 said: Hi, I am having issues on the above Graphicscard, that the memory temps are not showing up in the sensor tab. Any advice ? (HWinfo64 has this and more data in sensor mode) Thank you atigpureg.txt 4.79 kB · 0 downloads atismbusdump.txt 806 B · 0 downloads According to the registers dump your video card is not capable of measuring its VRAM temperature. Please post a screenshot of HWiNFO64 where it shows the value you're missing from AIDA64. Quote
Malcolm1822 Posted March 7, 2024 Author Posted March 7, 2024 Hi, I am mainly missing the GPU Memory Junction temp. However, there is a whole lot more info that the HWinfo shows such as individual MCD temps and different power measurements. My card is a reference Sapphire 7900xtx not sure if it helps or not. Thank you Quote
Malcolm1822 Posted March 13, 2024 Author Posted March 13, 2024 On 3/7/2024 at 1:30 PM, Fiery said: According to the registers dump your video card is not capable of measuring its VRAM temperature. Please post a screenshot of HWiNFO64 where it shows the value you're missing from AIDA64. Hi There, Any update on this one ? Thank you! Quote
Fiery Posted March 14, 2024 Posted March 14, 2024 On 3/7/2024 at 2:01 PM, Malcolm1822 said: Hi, I am mainly missing the GPU Memory Junction temp. However, there is a whole lot more info that the HWinfo shows such as individual MCD temps and different power measurements. My card is a reference Sapphire 7900xtx not sure if it helps or not. Thank you Thank you! I've sent you a private message about this. Quote
Fiery Posted March 14, 2024 Posted March 14, 2024 On 6/8/2023 at 8:47 PM, Malcolm1822 said: Hi, I am having issues on the above Graphicscard, that the memory temps are not showing up in the sensor tab. Any advice ? Thank you I've sent you a private message about this. Quote
