It would be so good if you could see the per pin monitoring the 5000 asus rog astral have that you can see in GPU tweek 3.  See the top right
asus-saved-our-bacon-we-had-12vhpwr-12v-
I can only imagine the piece of mind to have all the 6s pins amps showing on the sensorpanel i would be so happy if you could implement this.
Can this be implemented to the sensorpanel ?
In AIDA64 please press Ctrl+D --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Also, in AIDA64 please press Ctrl+D --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
I haven't had the luck of getting my hands on this card yet so cant post the result sorry  :(
We'll then need to wait for a lucky guy to post such dumps :)
  • Sad 1
  • 3 weeks later...
14 hours ago, tigerstyle said:
Hi, I was lucky enough to buy a 5090 Astral OC Edition last week. As I would also like to have the values in my sensor panel, I have attached the text files. ☺️
Thank you very much!
nvidiagpureg.txt 4.73 kB · 1 download nvidiasmbusdump.txt 10 kB · 2 downloads
OMG THANK YOU TIGER :D
 @Fiery please take a look at his logs and will support you forever if you get this to work :D
On 3/9/2025 at 6:25 AM, tigerstyle said:
@Fiery
nvidiasmbusdump.txt 10 kB · 4 downloads nvidiagpureg.txt 4.74 kB · 3 downloads
Thank you!
We've implemented advanced support for Asus Astral-RTX5000 Series video cards in the latest AIDA64 beta update available at:
Let us know how it works ;)
@BlaKer
9 hours ago, Fiery said:
Thank you for your feedback! :)
Thank you so much for being so fast with the implementation! :)
Any ETA when it will be implemented in to the main release?
The next stable update is not scheduled precisely at this time, but we're planning to roll it out in either April or May.
On 3/11/2025 at 7:51 AM, tigerstyle said:
@Fiery It works! Thank you. ☺️
Can you please post a screenshot (or multiple shots) of the Computer / Sensor page that shows all readings related to your Astral GPU?  We'd like to refine the labels wherever it's appropriate and possible, to clarify the various sensor readings.
  • 3 months later...
10 hours ago, BlaKer said:
@Fiery Hey why is this monitoring gone from the latest release and the latest beta?  :(
It's supposed to still be there.  If you cannot see it listed on the Computer / Sensor page, then in AIDA64 please press Ctrl+D --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Hm the only thing i could think of is that i changed to a amd motherboard.
I have sent you a PM with my log hope you can fix this cause i finally got my hands on the 5090 since i started the thread :D
Thank you!  That's a brand new variant of Asus RTX5090 that we haven't seen before.  Please let me know the full model name of your video card, e.g. ROG-XXXX-RTX5090-YYYY-ZZZZ.
31 minutes ago, Fiery said:
Thank you!  The issue will be fixed in the next AIDA64 beta update due before the end of this week ;)
Much appreciated Firey! ! ! I :D
29 minutes ago, BlaKer said:
Thank you so much =D!!
The Beta build got this bug , im messing around in the sensorpanel and get this message from time to time when trying to add somthing or just browsing the sensors to add. Im using W11.   Not all the time.
Are you configuring the SensorPanel with the configuration window placed on the same monitor as the SensorPanel, or you have multiple monitors and you dedicate one of them for the SensorPanel?
Can you please also create a broader screenshot where we can see from what window (of AIDA64) does that popup comes up from?
Got a beada panel that is connected with USB and only got one monitor connected. I will try to do that when i get the message again.
