The Mac Posted June 4, 2025 Posted June 4, 2025 RazerSwitchblade LCD stopped working. If i cycle the LCD option, it says it cant find RzSwitchladeSDK2.dll The SDK appears installed in the proper Razer directory, and the DLL is present. EDIT: I rolled back to the stable release, and it works again. Appears to be an issue with the newest beta. Quote
Fiery Posted June 5, 2025 Posted June 5, 2025 8 hours ago, The Mac said: RazerSwitchblade LCD stopped working. If i cycle the LCD option, it says it cant find RzSwitchladeSDK2.dll The SDK appears installed in the proper Razer directory, and the DLL is present. EDIT: I rolled back to the stable release, and it works again. Appears to be an issue with the newest beta. The latest AIDA64 beta build is already a preview of the next-generation AIDA64 which is a native 64-bit application and so it requires 64-bit DLL modules. It means, in your particular case the new AIDA64 requires the 64-bit variant of RzSwitchbladeSDK2.dll. We will check it out, maybe there's a new trick to be implemented in AIDA64 to find the right (64-bit) RzSwitchbladeSDK2.dll file automatically. Until then, you can try to copy the 64-bit RzSwitchbladeSDK2.dll into the AIDA64 installation folder to make it work. Also, make sure to check this topic: Quote
Fiery Posted June 5, 2025 Posted June 5, 2025 15 hours ago, The Mac said: RazerSwitchblade LCD stopped working. If i cycle the LCD option, it says it cant find RzSwitchladeSDK2.dll The SDK appears installed in the proper Razer directory, and the DLL is present. EDIT: I rolled back to the stable release, and it works again. Appears to be an issue with the newest beta. BTW, what Razer product do you try to use AIDA64 with? DeathStalker Ultimate keyboard? Do you use any features of the Razer Synapse framework with your Razer hardware? I'm just asking because we haven't found any traces of a 64-bit RzSwitchbladeSDK2.dll 😞 Which means we gotta figure out an alternative method to talk to the Razer LCD. One option may be to sack Razer Synapse 2.0 (which will be deprecated in October this year anyway), install a special driver for the Razer LCD and talk to the device directly. It may work out, but then you'd lose the ability to install and use Razer Synapse. Quote
The Mac Posted June 5, 2025 Author Posted June 5, 2025 yes, the old ass DetahStalker Ultimate..ive rebuilt it twice from ebay purchases... i just cant bear to get rid of it, i love the switchblade with aida on it.... i dont use any of the other features of the framework other than changing the lighting periodically, and occasionally the touchscreen mouse when my main mouse goes wacky (which i believe is a standalone driver anyway by synaptics) Ive done a search of my machine, and there appears to be only one copy of the .dll, so i doubt there is a 64bit version. I actually did try to put a copy in the aid64 program directory when i was troubleshooting but it didnt work. Razer may have one they never released. Quote
Fiery Posted June 6, 2025 Posted June 6, 2025 13 hours ago, The Mac said: yes, the old ass DetahStalker Ultimate..ive rebuilt it twice from ebay purchases... i just cant bear to get rid of it, i love the switchblade with aida on it.... i dont use any of the other features of the framework other than changing the lighting periodically, and occasionally the touchscreen mouse when my main mouse goes wacky (which i believe is a standalone driver anyway by synaptics) Ive done a search of my machine, and there appears to be only one copy of the .dll, so i doubt there is a 64bit version. I actually did try to put a copy in the aid64 program directory when i was troubleshooting but it didnt work. Razer may have one they never released. We'll check if it's possible to develop a 64-bit DLL on ourselves. It'd be much easier to switch to direct USB communication, but then you'd lose the ability of changing the lighting. We'll try to find a middle ground: maybe it's possible to keep the Synapse framework and only take over the handling of the LCD screen by effectively "stealing" access to the LCD from Synapse. That way you could continue changing the lighting. Quote
Fiery Posted June 6, 2025 Posted June 6, 2025 13 hours ago, The Mac said: yes, the old ass DetahStalker Ultimate..ive rebuilt it twice from ebay purchases... i just cant bear to get rid of it, i love the switchblade with aida on it.... i dont use any of the other features of the framework other than changing the lighting periodically, and occasionally the touchscreen mouse when my main mouse goes wacky (which i believe is a standalone driver anyway by synaptics) Ive done a search of my machine, and there appears to be only one copy of the .dll, so i doubt there is a 64bit version. I actually did try to put a copy in the aid64 program directory when i was troubleshooting but it didnt work. Razer may have one they never released. BTW, do you use the dynamic keys with AIDA64, to e.g. configure the LCD layout or to switch between LCD pages? Quote
The Mac Posted June 6, 2025 Author Posted June 6, 2025 I only use a single page for the layout and have never used those buttons and the worthless apps they open. if i have to lose access to the touchpad functionality i suppose i can live with that although like i mentioned, its a separate driver and i'm pretty sure it still works without the framework. the lighting profile i believe is stored on the keyboard hardware (it survives reboot and is active during post/bios) so theoretically i could fire up the framework when i need to change it, then disable it after to allow aida to run the layout if it interferes. Quote
Fiery Posted June 6, 2025 Posted June 6, 2025 7 hours ago, The Mac said: I only use a single page for the layout and have never used those buttons and the worthless apps they open. if i have to lose access to the touchpad functionality i suppose i can live with that although like i mentioned, its a separate driver and i'm pretty sure it still works without the framework. the lighting profile i believe is stored on the keyboard hardware (it survives reboot and is active during post/bios) so theoretically i could fire up the framework when i need to change it, then disable it after to allow aida to run the layout if it interferes. Then I think in your case it should work out Here's a new beta update for AIDA64: https://www.aida64.com/downloads/latesta64xebeta This will support direct USB communication with the LCD device of the venerable Razer DeathStalker Ultimate keyboard. It uses the LibUSB library, and requires you to install the Samsung LCD LibUSB driver for your Razer LCD device using the following trick: 1) Download the Samsung SPF LCD driver digitally signed by us (FinalWire) from: http://download.aida64.com/resources/lcd/samsung_spf_lcd_driver.zip 2) Extract the ZIP package into a folder on your PC, e.g. C:\1 3) Right-click on the Windows button on the Taskbar --> Device Manager 4) In the Device Manager look for the device entry for the Razer LCD. It should be inside the group called Universal Serial Bus Controllers. The device name should be Razer DeathStalker Ultimate 5) Right-click on the Razer LCD device --> Uninstall Device --> tick the Delete the driver software for this device checkbox 6) Right-click on any items in the Device Manager --> Scan for hardware changes 7) In the Device Manager look for the new device entry for the Razer LCD. It should be inside the group called Other devices. The device name should still be Razer DeathStalker Ultimate 8) Right-click on the Razer LCD device --> Update driver --> Browse my computer for drivers 9) Click on the bottom button: Let me pick from a list of available drivers on my computer 10) Select Show All Devices --> click on the bottom Next button --> click on the Have Disk button 11) Navigate to the folder where you've extracted the ZIP package into, go to the subfolder named new driver (2021), and select the .INF file there 12) In the Select the device driver you want to install for this hardware window feel free to choose any of the devices, e.g. the first one called Samsung 1000P Digital Photo Frame 13) Click on the Yes button in the Update Driver Warning message box 14) You're done with driver installation. The only thing now you need is the 64-bit LibUSB DLL, filename: libusb0.dll, can be found in the bin\amd64 folder of the LibUSB Win32 distribution package Simply copy that DLL file to the installation folder of AIDA64. 15) You can now can start using the Razer LCD module with the next-generation AIDA64 Please note that pressing the dynamic keys will do nothing right now, so you cannot use them to change LCD page. Please note that this process of driver installation applies to both Windows 10 and Windows 11. ------ If you want to reverse that process and revert back to the original Razer LCD driver installed by Razer Synapse 2.0, please do the following: 1) Right-click on the Windows button on the Taskbar --> Device Manager 2) In the Device Manager look for the device entry for the Razer LCD. It should be inside the group called libusb-win32 devices. The device name should be e.g. Samsung 1000P Digital Photo Frame 3) Right-click on the device --> Uninstall Device --> tick the Delete the driver software for this device checkbox 4) Right-click on any items in the Device Manager --> Scan for hardware changes 5) In the Device Manager look for the new device entry for the Razer LCD. It should be inside the group called Other devices. The device name should still be Razer DeathStalker Ultimate 6) Right-click on the Razer LCD device --> Update driver --> Browse my computer for drivers 7) Click on the bottom button: Let me pick from a list of available drivers on my computer 8) Select Show All Devices --> click on the bottom Next button --> click on the Have Disk button 9) Navigate to the folder called C:\Program Files (x86)\Razer\Razer_Common_Driver\Drivers\amd64\LowerFilter, and select the .INF file there Let me know how it works out for you Quote
The Mac Posted June 6, 2025 Author Posted June 6, 2025 sweet. ill give it a go tomorrow and let you know. Quote
Solution The Mac Posted June 10, 2025 Author Solution Posted June 10, 2025 Works great. Better than you thought actually. Couple things 1. only needed to change the driver. nothing else. 2. Moving a copy of the libusb dll wasn't necessary. Although maybe that's because i havent deleted the driver install directory. Ill keep an eye on that. 3. Synapse software is still fully functional. Lighting changes can be done at any time without changing the driver back. 4. Touchscreen mouse of the switchblade screen still fully functional. 5. Driver and lighting survives reboot. Effectively no change to any functions from before. Actually better: now accidentally hitting one of those dynamic keys doesn't make my LCD layout disappear and have to spend 10 minutes to figure out how to get it back. Quote
Fiery Posted June 11, 2025 Posted June 11, 2025 6 hours ago, The Mac said: Works great. Better than you thought actually. Couple things 1. only needed to change the driver. nothing else. 2. Moving a copy of the libusb dll wasn't necessary. Although maybe that's because i havent deleted the driver install directory. Ill keep an eye on that. 3. Synapse software is still fully functional. Lighting changes can be done at any time without changing the driver back. 4. Touchscreen mouse of the switchblade screen still fully functional. 5. Driver and lighting survives reboot. Effectively no change to any functions from before. Actually better: now accidentally hitting one of those dynamic keys doesn't make my LCD layout disappear and have to spend 10 minutes to figure out how to get it back. Awesome, thank you for your feedback! Quote
The Mac Posted July 20, 2025 Author Posted July 20, 2025 as a side note, its way more stable with the USB drivers. The old razer driver used to crash aida64 fairly often. I haven't had a single aida app crash since using the new usb drivers. Quote
Fiery Posted July 21, 2025 Posted July 21, 2025 On 7/20/2025 at 6:26 PM, The Mac said: as a side note, its way more stable with the USB drivers. The old razer driver used to crash aida64 fairly often. I haven't had a single aida app crash since using the new usb drivers. That's great to hear Quote
ANUBIS Posted October 3, 2025 Posted October 3, 2025 Any update on this ? Still necessary to mess with drivers? I am also using Razer Deathstalker Ultimate. And all the dynamic keys. Quote
Fiery Posted October 4, 2025 Posted October 4, 2025 22 hours ago, ANUBIS said: Any update on this ? Still necessary to mess with drivers? I am also using Razer Deathstalker Ultimate. And all the dynamic keys. There's no 64-bit SwitchBlade UI SDK support from Razer, so we cannot further improve on the solution described above. Quote
ANUBIS Posted October 4, 2025 Posted October 4, 2025 But it's working on older versions, so can't it be made backward compatible ? (Or add compatibility mode?) Quote
Fiery Posted October 4, 2025 Posted October 4, 2025 5 minutes ago, ANUBIS said: But it's working on older versions, so can't it be made backward compatible ? (Or add compatibility mode?) Yes, old versions used a 32-bit main binary (AIDA64.EXE) that could load only 32-bit DLL modules. That fits perfectly well with such SDKs that offer 32-bit DLL modules or both 32-bit and 64-bit modules. AIDA64 v8.00 uses a 64-bit main binary that can only load 64-bit DLL modules. It sadly cannot be made compatible with such SDKs that supports only 32-bit DLL modules (such as the Razer SwitchBlade UI SDK). Quote
ANUBIS Posted 14 hours ago Posted 14 hours ago Is it possible to use two versions of Aida64 together ? (Older one for the Razer Switchblde LCD) Quote
Fiery Posted 2 hours ago Posted 2 hours ago 12 hours ago, ANUBIS said: Is it possible to use two versions of Aida64 together ? (Older one for the Razer Switchblde LCD) Yes, as long as they are different AIDA64 editions. So for example you can use AIDA64 Extreme and AIDA64 Engineer in the same time. But since only one of them would be able to communicate with the AIDA64 kernel driver, you wouldn't be able to use both AIDA64 instances for hardware monitoring. Quote
