Hello!
I've downloaded latest version of AIDA64 (4.70.3200) and it doesn't show information about cooling fans on "Sensor" tab and in "System Stability Test" applet.
post-28675-0-60602900-1416089146_thumb.pngpost-28675-0-08700500-1416089153_thumb.pngpost-28675-0-48488300-1416089160_thumb.png
Also on "Chipset" - "North Bridge Properties" - "Supported Memory Types" seems that present wrong information about RDRAM memory types, which this motherboard, as I understand, does not actually support.
In Everest 5.50.2253 Beta all was OK.
post-28675-0-73001300-1416091489_thumb.pngpost-28675-0-43602300-1416091492_thumb.pngpost-28675-0-55121100-1416091498_thumb.pngpost-28675-0-59334100-1416091504_thumb.png
Fix it please!
Also this MB have another 2 fan connectors for North Bridge chip (NB_FAN) and chassis (CHA_FAN).
Add them in your program too please if you can!
Thank you for the bug report. Both issues will be fixed in the next AIDA64 beta update due in a few days from now. I'll drop a message into this topic once the new beta is available for download.
Hello! All works now! No more wrong info. Thanks a lot!
About chassis fan it was my fault because I lowered the speed of this fan with resistor:
And it's detected by the sensor only after updating info on hardware ASUS iPanel device. But seems that speed is detected incorrectly.
Actual speed is twice less.
post-28675-0-14726500-1416576758_thumb.jpg post-28675-0-63181900-1416579741_thumb.png
Or is it because I used the resistor? But power fan has resistor too and its speed detected correctly.
Also strange, that without resistor, speed of chassis fan only a half times more:
Whereas speed of power fan w/o the same resistor more in twice...
And what about North Bridge fan, is it possible to add support? ASUS iPanel and ASUS PC Probe has no info on it...
ISA Sensor Dump:
------[ AIDA64 Engineer v4.70.3237 Beta ]------
------[ Microsoft Windows XP Professional 5.1.2600 Service Pack 3 (32-bit) ]------
Motherboard ID      : 08/20/2002-VT8366A-A7V266-E
Motherboard Model   : Asus A7V266-E
Motherboard Chipset : VIA VT8366A Apollo KT266A
Award BIOS Type     : Award Modular BIOS v6.0
Award BIOS Message  : ASUS A7V266-E ACPI BIOS Rev 1011
DMI MB Manufacturer : ASUSTeK Computer INC.
DMI MB Product      : A7V266-E
DMI MB Version      : REV 1.xx
DMI MB Serial       : xxxxxxxxxxx
DMI SYS Manufacturer: System Manufacturer
DMI SYS Product     : System Name
DMI SYS Version     : System Version
DMI SYS Serial      : SYS-1234567890
DMI BIOS Version    : ASUS A7V266-E ACPI BIOS Rev 1011
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h)
ITE SuperIO Device ID      = 0000h (0000h / 0000h)
ITE SuperIO Version        = 00h   (  00h /   00h)
Winbond SuperIO Port              = 2Eh
Winbond SuperIO Device ID         = 5953h (5953h / 0000h)
Fintek SuperIO Port           = 00h
Fintek SuperIO Device ID      = 0000h (0000h / 0000h)
SMSC SuperIO Port           = 00h
SMSC SuperIO Device ID      = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
Embedded Controller Dump:
------[ Embedded Controller at 0066/0062 via Port I/O / Bank #0 ]------
0000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Time #1 = 260
Time #2 = 0
Debug Info on Chassis Fan:
Sensor Properties
Sensor Type Asus AS99127F (SMBus 2Dh)
Motherboard Name Asus A7V266 Series
Chassis Intrusion Detected No
Temperatures
Motherboard 28 °C (82 °F)
CPU 58 °C (136 °F)
WDC WD2002FAEX-007BA0 39 °C (102 °F)
Cooling Fans
CPU 2700 RPM
Chassis 4141 RPM
Power Supply 3000 RPM
Voltage Values
CPU Core 1.808 V
+3.3 V 3.392 V
+5 V 4.919 V
+12 V 12.950 V
-12 V -12.334 V
-5 V -3.419 V
Debug Info F 7A DE A3
Debug Info T 28 59 224
Debug Info V 71 06 D4 B7 D5 D9 B0 (01)
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.SAMB.TMPC :
_SB_.SAMB.TMPH :
_SB_.STR0._TMP :
_SB_.STR1._TMP :
_SB_.STR2._TMP :
_SB_.STR3._TMP :
_SB_.STR4._TMP :
_SB_.STR5._TMP :
_SB_.STR6._TMP :
_SB_.STR7._TMP :
------[ SMBus #0 ]------
SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port : E800
Can Have SPD: Yes
Scan Type : Full
------[ SMBus Device B00-D2B ]------
0000 FE 4F 4F 4F 06 00 00 00 11 40 84 FF FF FF FF FF .OOO.....@......
00F0 00 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 ................
0000 FFFE FF4F FF4F FF4F FF06 FF00 FF00 FF00 FF11 FF40 FF84 FFFF FFFF FFFF FFFF FFFF
0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00F0 FF00 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10 FF10
------[ SMBus Device B00-D2D ]------
0000 BA CE D4 53 CD D1 35 CC A7 F7 A4 AB 8C 67 54 F7 ...S..5......gT.
0010 A4 F7 A4 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020 71 06 D4 B7 D5 C1 92 1C 7D E1 A3 81 65 AB 8C E2 q.......}...e...
0030 B9 CC A7 E0 96 E2 97 F9 A6 69 00 FF FF FF 00 00 .........i......
0040 01 02 00 FF 00 C0 00 64 F1 22 01 80 70 80 50 C3 .......d."..p.P.
0050 00 00 00 00 00 00 DF FF 31 8F 8F 00 C0 48 E2 3F ........1....H.?
0060 71 06 D4 B7 D5 D0 A1 1C 7D E1 A3 81 65 AB 8C E2 q.......}...e...
0070 B9 CC A7 E0 96 E2 97 F9 A6 69 00 FF FF FF 00 00 .........i......
0080 BA CE D4 53 CD D1 35 CC A7 F7 A4 AB 8C 67 54 F7 ...S..5......gT.
0090 A4 F7 A4 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 71 06 D4 B7 D5 D0 A1 1C 7D E1 A3 81 65 AB 8C E2 q.......}...e...
00B0 B9 CC A7 E0 96 E2 97 F9 A6 69 00 FF FF FF 00 00 .........i......
00C0 BA CE D4 45 CD D1 35 CC A7 F7 A4 AB 8C 67 54 F7 ...E..5......gT.
00D0 A4 F7 A4 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00E0 71 06 D4 B7 D5 D0 A1 1C 7D E1 A3 81 65 AB 8C E2 q.......}...e...
00F0 B9 CC A7 E0 96 E2 97 F9 A6 69 00 FF FF FF 00 00 .........i......
0000 BABA CECE D4D4 4545 CDCD D1D1 3535 CCCC A7A7 F7F7 A4A4 ABAB 8C8C 6767 5454 F7F7
0010 A4A4 F7F7 A4A4 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0020 7171 0606 D4D4 B7B7 D5D5 D0D0 A1A1 1C1C 7D7D E1E1 A3A3 8181 6565 ABAB 8C8C E2E2
0030 B9B9 CCCC A7A7 E0E0 9696 E2E2 9797 F9F9 A6A6 6969 0000 FFFF FFFF FFFF 0000 0000
0040 0101 0000 0004 FFFF 0000 C0C0 0000 6464 F1F1 2222 0101 8080 7070 8080 5050 C3C3
0050 0000 0000 0000 0000 0000 0000 DFDF FFFF 3131 8F8F 8F8F 0000 C0C0 4848 E2E2 3F3F
0060 0671 D406 B7D4 D5B7 D9D5 B1D9 1CB1 7D1C E17D A3E1 81A3 6581 AB65 8CAB E28C B9E2
0070 CCB9 A7CC E0A7 96E0 E296 97E2 F997 A6F9 69A6 0069 FF00 FFFF FFFF 00FF 0000 BA00
0080 CEBA D4CE 45D4 CD45 D1CD 35D1 CC35 A7CC F7A7 A4F7 ABA4 8CAB 678C 5467 F754 A4F7
0090 F7A4 A4F7 00A4 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00A0 7171 0606 D4D4 B7B7 D5D5 D9D9 B1B1 1C1C 7D7D E1E1 A3A3 8181 6565 ABAB 8C8C E2E2
00B0 B9B9 CCCC A7A7 E0E0 9696 E2E2 9797 F9F9 A6A6 6969 0000 FFFF FFFF FFFF 0000 0000
00C0 BABA CECE D4D4 4040 CDCD D1D1 3535 CCCC A7A7 F7F7 A4A4 ABAB 8C8C 6767 5454 F7F7
00D0 A4A4 F7F7 A4A4 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00E0 7171 0606 D4D4 B7B7 D5D5 D9D9 B1B1 1C1C 7D7D E1E1 A3A3 8181 6565 ABAB 8C8C E2E2
00F0 B9B9 CCCC A7A7 E0E0 9696 E2E2 9797 F9F9 A6A6 6969 0000 FFFF FFFF FFFF 0000 0000
------[ SMBus Device B00-D48 ]------
0000 E0 08 79 7A 00 00 00 00 00 00 00 00 00 00 00 00 ..yz............
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 88 10 03 02 00 1F 00 00 0E 1B 00 00 00 00 00 00 ................
0090 04 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0000 80E0 0808 0079 007A 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0010 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 8800
0080 1088 0310 0203 0002 1F00 001F 0000 0E00 1B0E 001B 0000 0000 0000 0000 0000 0400
0090 0204 0002 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D49 ]------
0000 3A 08 55 5F 00 00 00 00 00 00 00 00 00 00 00 00 :.U_............
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0000 003A 0808 0055 005F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D50 ]------
0000 80 08 07 0C 0A 02 40 00 04 75 75 00 80 08 00 01 ......@..uu.....
0010 0E 04 0C 01 02 20 00 A0 75 00 00 50 3C 50 2D 20 ..... ..u..P<P-
0020 90 90 50 50 00 00 00 00 00 00 00 00 00 00 00 00 ..PP............
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D ................
0000 80 08 07 0D 0A 02 40 00 04 75 75 00 82 08 00 01 ......@..uu.....
0010 0E 04 0C 01 02 20 C0 A0 75 00 00 50 3C 50 2D 40 ..... ..u..P<P-@
0020 90 90 50 50 00 00 00 00 00 41 4B 30 32 75 00 00 ..PP.....AK02u..
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E3 ................
0040 AD 00 00 00 00 00 00 00 01 48 59 4D 44 32 36 34 .........HYMD264
0050 20 36 34 36 41 38 2D 48 20 20 20 41 41 03 10 0D 646A8-H AA...
0060 05 35 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 .5..............
------[ Chips Found ]------
B00-D51: uPI uP????
Please upgrade to the latest beta version of AIDA64 Extreme available at:
http://www.aida64.com/downloads/aida64extremebuild3242kwn2zf6gyqzip
That should fix the fan RPM calculation issues. Note that the sensor chip of your motherboard is only capable of measuring no more than 3 fans. Hence, the 4th fan (NB fan) is not measured, but only powered.
Big thanks! Now all fine!
I understood about NB fan. Then last question.
I have two memory modules installed. One of them detected on SPD tab as "SK Hynix HYMD264 646A8-H":
The second one has no such info and detected simply as noname module:
Is it bug of program or just this module has no SPD info? But module qualitative. TwinMOS DDR266.
Maybe still there is a way to extract SPD information from it? I can provide you all necessary dumps if required.
Thank you for the feedback. As for SPD, both your memory modules have a working SPD chip. Otherwise, the module would not appear on the Motherboard / SPD page in AIDA64 ;) Your TwinMOS module however has the SPD manufacturer ID field and part number fields both set to zero, so it's basically not filled. It doesn't cause an actual issue, it prevents the proper identification of memory module model name.
Although.. there is another one issue. BSOD on "Multimedia - OpenAL" tab. :mellow: In Everest 5.50.2253 Beta too. Just when trying to open it. As far as I remember, before this problem was not, so maybe I have something wrong with the system, maybe no, AIDA is too complex program to cover all cases and configurations, so all such bugs are normal and inevitable, but can you try to fix it too, if it possible?
Mini dump of memory. If necessary I can make full too. And also benchmarking on "CPU Tweakings" applet does not work:
In Everest 5.50.2253 Beta all was OK. So fix it too, please. )
And I just noticed that HWiNFO32 on its "Sensor Status" applet has two additional sensors for VINR0 and Aux:
Is it just bug of program or these sensors really exists? If so, can you add them in your program too?
Try to reinstall OpenAL, it should fix it. If not, then you can disable the OpenAL page in AIDA64 / main menu / File / Preferences / Layout.
The VINR0 and Aux readings are bogus values. As you can see, none of them makes any sense ;) That's why AIDA64 will not display them.
I found reason of BSOD. It was obsolete Creative driver CT_OAL.DLL 5.12.1.1196 (2.09.00.0016). Actually even official ALCapsViewer tool caused BSOD, not only your program. But after renaming CT_OAL.DLL in CT_OAL.BAK the problem was gone.
About VINR0/Aux I understood. OK. BTW, HWiNFO32 have many bugs too (wrong fan speed data, no SPD/CPU status on Summary tab, jumping values etc), although it's also good program, albeit less advanced.
So what about "CPU Tweakings" applet? Benchmarking does not work on it, although "Cache & Memory Benchmark" working correctly.
Thank you for letting us know about the resolution ;)
That is not an official feature of AIDA64. It is there to help us diagnose various issues during the development.
