damcross Posted March 17, 2022 Posted March 17, 2022 Have you tried to add some items to your LCD layout in AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD / LCD Items? Why not to try technifiser instead. The box informs you about the preview resolution will only disappear when you have at least one item on your LCD layout. Quote
陳司司 Posted June 20, 2022 Posted June 20, 2022 On 10/18/2021 at 3:57 AM, Joey Determan said: Having an odd issue with aida 64 and odospace lcd not sure what exactly is causing the issue but when both aida64 and odospace remote panel start, aida64 and odospace will start binding all available tcp/ip ports. This causes the computer to be unable to establish any new connections. Hoping maybe someone has seen this before. Same problem happened. I change tcp keepalive time to reduce established TCP connect. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\KeepAliveTime Quote
Borille Posted November 10, 2022 Posted November 10, 2022 How can i control 2 identical RemoteSensor LCDs Quote
Arkadiusz Łata Posted February 18, 2023 Posted February 18, 2023 Hello I have old Lenovo Yoga Tab 2 Windows 10. It has nice display, is there any way to use it as sensor monitor ( usb or wireless)? Quote
