Neostarchild Posted August 10, 2016 Posted August 10, 2016 Hello, I've recently upgraded my old ADSL 6Mbps connections to our towns new optic 150Mbps (168Mbps measured). On my sensor panel the Connections Speed was measured at 7.8 Mbps when I was on DSL but now it doesn't change to reflect the new connection speed. The Graphs I use to measure upload and download work (wish I could measure in MB/s instead of KB/s but I know that's coded and can't be changed) Not sure if it is something I need to change somewhere or is this just a bug. I'm running version 5.75.3940 beta. Thank you. Quote
Fiery Posted August 10, 2016 Posted August 10, 2016 Have you tried to check whether the correct NIC is used for your graphs? In many cases there are multiple network interfaces/adapters present in the system, and maybe your graph is configured for the wrong interface. BTW, you can switch the NIC download/upload rates to MB/s or Mbps by simply specifying that as the measurement unit for your sensor item. That's a trick that we've introduced a year ago Quote
Neostarchild Posted August 11, 2016 Author Posted August 11, 2016 Hello Neat tricks with the values I have only NIC1 Graphs are no problem. The "NIC1 Connection Speed" stays at 7.8Mbps or if I change to Gbps changes to 1000Gbps. Maybe I'm not getting what this sensor measures or its intended use. I am using an MSI Z170A Gaming M5 Mainboard that has the Killer Ethernet E2200 with up to date drivers. Let me know if you need any other info. Thank You. Quote
Fiery Posted August 15, 2016 Posted August 15, 2016 The "NIC1 Connection Speed" stays at 7.8Mbps or if I change to Gbps changes to 1000Gbps. Maybe I'm not getting what this sensor measures or its intended use. I am using an MSI Z170A Gaming M5 Mainboard that has the Killer Ethernet E2200 with up to date drivers. Let me know if you need any other info. Thank You. Connection speed is fixed. It shows 100 Mbps for a 100 Mbps LAN connection, 1000 Mbps (1 Gbps) for a gigabit LAN connection, etc. Quote
Ghryst Posted June 20, 2020 Posted June 20, 2020 On 8/11/2016 at 3:59 AM, Fiery said: Have you tried to check whether the correct NIC is used for your graphs? In many cases there are multiple network interfaces/adapters present in the system, and maybe your graph is configured for the wrong interface. BTW, you can switch the NIC download/upload rates to KB/s (who the hell would wanna measure KB in this day and age?) or Mbps by simply specifying that as the measurement unit for your sensor item. That's a trick that we've introduced a year ago my observations : 1, NIC identity changes upon system restart, rendering sensor panel defunct, and must be edited to the new NIC. 2, Mbps defaults back to MB upon editing the sensor/graph/gauge in any way. it is very annoying to keep aida64 sensor panel working normally, requires more maintenance than my wife. according to AIDA64, apparently today i dont have an internet connection at all (none of the 4 NICs are responding to network activity) 1 1 Quote
Fiery Posted July 9, 2020 Posted July 9, 2020 On 6/20/2020 at 6:01 AM, Ghryst said: my observations : 1, NIC identity changes upon system restart, rendering sensor panel defunct, and must be edited to the new NIC. 2, Mbps defaults back to MB upon editing the sensor/graph/gauge in any way. it is very annoying to keep aida64 sensor panel working normally, requires more maintenance than my wife. according to AIDA64, apparently today i dont have an internet connection at all (none of the 4 NICs are responding to network activity) I understand that it can be difficult to handle NICs these days, but the whole reason behind that is that Windows 10 itself manages NICs that way. They can appear and disappear, their order can change dynamically, virtual NICs here and there, etc. etc. With such a dynamic scenario anything you configure as a fixed setting can change on-the-fly. I'm not sure how could AIDA64 follow that automatically... 2 Quote
paidcritic Posted October 1, 2021 Posted October 1, 2021 Looking at my network hardware, the Wi-Fi NIC is named WiFi .. but I do not have an option in the sensor panel to select. Is there a way to dynamically select the 'connected' network adapter for the panel? thx Quote
CloudBasedMe Posted January 18, 2022 Posted January 18, 2022 it would be useful if the Windows network page can display which NIC # is a specific connection using. Quote
joebeefhash Posted December 28, 2022 Posted December 28, 2022 You guys could create profiles for each NIC. My computer only connects to NIC2 and NIC3 so I created two different profiles so I don't have to edit anything. No one should be editing the NIC each time they restart their computer, simply create a profile and label it the correct NIC port. You just load each profile until you see you have the right one. It's not a fix, but it's such an easy workaround that I'm fine with it. Say you have a profile named Total Monitor.sensorpanel Check what NIC it's connected to, save the profile with the name Total Monitor NIC2.sensorpanel or whatever NIC port it is. Like I said, I only need two different profiles for each one. Some of you might need 4 but they take up such little space and if you store each profile in a separate folder you can keep things nice and tidy. At the maximum it'll look like this. Total Monitor NIC1.sensorpanel Total Monitor NIC2.sensorpanel Total Monitor NIC3.sensorpanel Total Monitor NIC4.sensorpanel Simply go down the line importing them until you see the network speed is showing, boom, done. No more editing lol. Quote
