FoxLaRocks Posted June 13, 2017 Posted June 13, 2017 Hello all, first time poster here. So I run Aida64 mainly for my Logitech G19s Keyboard. Today I upgraded from a Strix Rx480 O8GB to a Zotac Gtx 1070 Amp Extreme. I am finding a few issues off the bat. I am often getting stuck at alt-tab or transition screens some times forced to hard reset. After said hard reset, or even fresh installation prompted resets I am brought to bios. When I type text into Firefox there is some times a delay. My Aida64 LCD monitor time display some times increases by 2sec (lagging) My mobo drivers are up to date. I have DDU the AMD drivers. I installed fresh Nvidia drivers via Geforce Experience. I set my CPU clocks back to default. I am going to remove and reinstall the graphics card right now. Will edit with results. Quote
FoxLaRocks Posted June 13, 2017 Author Posted June 13, 2017 Still having the same issue with the clock skipping after a fresh physical hardware install. Skips by 2 seconds ever 3-4 seconds it seems.https://pcpartpicker.com/list/n8zn4C Quote
Fiery Posted June 13, 2017 Posted June 13, 2017 Do you have issues about your new graphics card when you don't have AIDA64 running in the background? Quote
FoxLaRocks Posted June 13, 2017 Author Posted June 13, 2017 I seem to have solved the direct boot to bios on a restart and hanging black screen by updating my bios(apparently the programs that monitor updates didn't do their job.) So my graphics card issue appear to be solved. Stilling finding a bit of lag with the AIDA64 clock on my keyboards LCD. Quote
Fiery Posted June 15, 2017 Posted June 15, 2017 On 2017. 06. 13. at 9:54 PM, FoxLaRocks said: I seem to have solved the direct boot to bios on a restart and hanging black screen by updating my bios(apparently the programs that monitor updates didn't do their job.) So my graphics card issue appear to be solved. Stilling finding a bit of lag with the AIDA64 clock on my keyboards LCD. If you want to get rid of such delays, try to lower the LCD update frequency to 500 milliseconds or even lower, in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Update Frequency. Quote
FoxLaRocks Posted June 17, 2017 Author Posted June 17, 2017 Thanks, that made it so its at least not skipping numbers. I suppose I had this issue before and never noticed? Again, thank you for the quick response. Quote
