Hurricane28 Posted October 1, 2017 Share Posted October 1, 2017 Hi all, I am hoping that someone can help me with issues with my Asus Ch6 hero. I have 3 Noctua NF-F12 Industrial PPC 3K rpm fans connected to my motherboard 4-pin pwm fan header via 3 way 4-pin splitter. I did this because i want to run my fans at minimal rpm at idle and ramp up under load which is only possible via pwm signal and my fan controller doesn't have 4-pin pwm unfortunately.Now, the problem is that no matter what setting i use, the fans stop spinning or they ramp up to 100% load all of a sudden for no reason at all and sometimes i can't even slow them down and i have to shut down my PC completely in order for them to behave like my preset in BIOS.I tried without monitor software but it didn't help. It appears that whenever i try to monitor from the EC sensor it gets corrupted and i need to restart and reset the EC sensor again otherwise i am not able to monitor my system at all.. I really hope someone here could help me because this problem is present from my previous 990 FX rig and i still don't understand what is causing this. I provided as much info as i have as attachments. Thank you in advanced, Hurricane. Aida64 bug log.txt Link to comment Share on other sites More sharing options...
Fiery Posted October 2, 2017 Share Posted October 2, 2017 If the fan issues are caused by AIDA64 polling the EC (Embedded Controller) chip of your motherboard, then good news is that using the latest AIDA64 beta build you can now disable EC support in AIDA64 / main menu / File / Preferences / Stability: https://www.aida64.com/downloads/latesta64xebeta Link to comment Share on other sites More sharing options...
Hurricane28 Posted October 2, 2017 Author Share Posted October 2, 2017 Thank you for answering. I already have the latest beta installed, So the workaround is just disabling this sensor? Motherboard and CPU temps are that EC sensor related temps? I tried disabling this sensor but the problem persist. I have same problem with hardwareinfo64.. I am trying to understand what is causing these problems so if i reinstall windows i don't get this problem again you see. I was hoping you could provide me some more information about this issue in order to eliminate this problem. Thank you. Link to comment Share on other sites More sharing options...
Hurricane28 Posted October 5, 2017 Author Share Posted October 5, 2017 Bump/ Link to comment Share on other sites More sharing options...
Hurricane28 Posted October 8, 2017 Author Share Posted October 8, 2017 No further support..? I am very disappointed so far... I used to like the program very much but if there is no support than i guess i have to ask for a refund where i bought it from and uninstall it and use something else that does have support.. Link to comment Share on other sites More sharing options...
Fiery Posted October 10, 2017 Share Posted October 10, 2017 I'm sorry for the late reply. Let's continue this discussion in your other topic Link to comment Share on other sites More sharing options...
