rognorak Posted December 3, 2017 Posted December 3, 2017 Hi, I have an Asus Z10PED16WS MoBo. Any time I do anything that triggers a sensor scan in AIDA64 my machine locks up. I have the same issue in HWINFO64, so I don't think its an AIDA bug. I want to enable logging so I can see exactly what is happening before the Machine Locks up, but when I select the logging tab in preferences, it initiates the sensor scan locking up the machine before I can enable anything. Is there any way I can enable logging without initiating the sensor scan so I can see whats happening? Thank You - Quote
Fiery Posted December 4, 2017 Posted December 4, 2017 Please navigate to the installation folder of AIDA64, and create the following 2 new files there: ENABLE_SMBUS_LOG.TXT ENABLE_HWMONINIT_LOG.TXT They can be simply 0 byte long (empty) files. Then start AIDA64, go the Computer / Sensor page, wait for your computer to lock up, restart it, and check the 2 files that you've previously created. If they have a content, please attach the files to a forum post, so we can check where the lockup occurs inside the AIDA64 sensor module. After finding the culprit, we can work on fixing the issue or implementing a workaround. Thanks, Fiery Quote
