Fiery Posted June 14, 2018 Share Posted June 14, 2018 On 6/8/2018 at 1:11 PM, Enzaki said: same here i have a Aorus gtx 1070ti have add nVIDIA SMBus Dump info hope it helps (: Aorus gtx 1070ti.txt Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. Quote Link to comment Share on other sites More sharing options...
Enzaki Posted June 15, 2018 Share Posted June 15, 2018 17 hours ago, Fiery said: Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. yep that help its all working now Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 15, 2018 Share Posted June 15, 2018 14 minutes ago, Enzaki said: yep that help its all working now Awesome, thank you for the feedback Quote Link to comment Share on other sites More sharing options...
den4ik Posted July 19, 2018 Share Posted July 19, 2018 Hello! My native language is russian, i hope my english is understandable. I'm using latest version is AIDA64 Engineer 5.9.7.4657 beta and latest version is AORUS ENGINE 1.36. For me, the problem with changing LED lighting remains unresolved. I attach the file with the nVIDIA SMBus Dump info, hope it helps. GIGABYTE G1 Gaming GTX 1060 - nVIDIA SMBus Dump.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted July 19, 2018 Share Posted July 19, 2018 17 hours ago, den4ik said: Hello! My native language is russian, i hope my english is understandable. I'm using latest version is AIDA64 Engineer 5.9.7.4657 beta and latest version is AORUS ENGINE 1.36. For me, the problem with changing LED lighting remains unresolved. I attach the file with the nVIDIA SMBus Dump info, hope it helps. GIGABYTE G1 Gaming GTX 1060 - nVIDIA SMBus Dump.txt Thank you for the data! Please upgrade to the latest beta version of AIDA64 available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. 1 Quote Link to comment Share on other sites More sharing options...
den4ik Posted July 20, 2018 Share Posted July 20, 2018 5 hours ago, Fiery said: Thank you for the data! Please upgrade to the latest beta version of AIDA64 available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it helps. OK, it worked! Thank you, very much! :-) Quote Link to comment Share on other sites More sharing options...
Fiery Posted July 20, 2018 Share Posted July 20, 2018 7 hours ago, den4ik said: OK, it worked! Thank you, very much! :-) Thank you for your feedback Quote Link to comment Share on other sites More sharing options...
0v3rl0rd Posted December 3, 2018 Share Posted December 3, 2018 Hi I just got the Gigabyte RX580 Aorus. My setup is: MB: MSI B450M Mortar Titanium CPU: Ryzen 1700 GPU: Gigabyte RX580 Aorus 8G RAM: 2x16GB G.Skill FlareX. When I start AIDA and load OSD (which, amongst others, has GPU temperature displayed), I cannot use RGB Fusion app OR Aorus Engine. With RGB Fusion I get a blank screen in the app window. With Aorus Engine there is no RGB button displayed. I disabled "GPU sensor support" in AIDA settings and now I can control RGB on my graphics card. atismbusdump.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 4, 2018 Share Posted December 4, 2018 13 hours ago, 0v3rl0rd said: Hi I just got the Gigabyte RX580 Aorus. My setup is: MB: MSI B450M Mortar Titanium CPU: Ryzen 1700 GPU: Gigabyte RX580 Aorus 8G RAM: 2x16GB G.Skill FlareX. When I start AIDA and load OSD (which, amongst others, has GPU temperature displayed), I cannot use RGB Fusion app OR Aorus Engine. With RGB Fusion I get a blank screen in the app window. With Aorus Engine there is no RGB button displayed. I disabled "GPU sensor support" in AIDA settings and now I can control RGB on my graphics card. atismbusdump.txt Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote Link to comment Share on other sites More sharing options...
0v3rl0rd Posted December 6, 2018 Share Posted December 6, 2018 On 12/4/2018 at 11:00 AM, Fiery said: Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. It did the trick. Thanks Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 9, 2018 Share Posted December 9, 2018 On 12/6/2018 at 11:40 PM, 0v3rl0rd said: It did the trick. Thanks Thank you for your feedback! Quote Link to comment Share on other sites More sharing options...
0v3rl0rd Posted February 10, 2019 Share Posted February 10, 2019 On 12/9/2018 at 5:09 PM, Fiery said: Thank you for your feedback! Just a question... AIDA is offering me a update now. My version is 5.99.4909 beta and it offers to update to version 5.99.4944. If I upgrade, will it continue to work properly, or will I get that "RGB fusion + AIDA" problem (GPU sensor) again? Thanks Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 11, 2019 Share Posted February 11, 2019 12 hours ago, 0v3rl0rd said: Just a question... AIDA is offering me a update now. My version is 5.99.4909 beta and it offers to update to version 5.99.4944. If I upgrade, will it continue to work properly, or will I get that "RGB fusion + AIDA" problem (GPU sensor) again? Thanks That RGB fusion issue is fixed already, and the fix is inherited by the newer and newer beta updates, as well as the stable updates in the future. 1 Quote Link to comment Share on other sites More sharing options...
0v3rl0rd Posted February 11, 2019 Share Posted February 11, 2019 6 hours ago, Fiery said: That RGB fusion issue is fixed already, and the fix is inherited by the newer and newer beta updates, as well as the stable updates in the future. I wasn't sure if I should upgrade or stay on the version that works. I'll update it asap than. Thank You very much for clearing that up Quote Link to comment Share on other sites More sharing options...
fluffi444 Posted December 22, 2020 Share Posted December 22, 2020 @Fiery Sorry to push this old thread... But I have exact the same problem as the users reported already. The use of latest official AIDA64 6.32.5600 with Gigabyte's RGB Fusion Software (no matter which Version) to control the LEDs of my Gigabyte AORUS GTX 1080 Ti Extreme is not working. Deactivation the GPU Senors (in AIDAs Stability settings) followed by reboot helps but I need them both running together... According to the posts here this looks like to be solved but - as I wrote - this came back with latest version. Or this problem is related my specific card? - For me it looks like you were bugfixing this for each specifig user setup?! Enclosed my nVIDIA SMBus Dump with the hope that you can help me as well... Please let my know if you need any futher information/data. GA-GTX1080Ti_F20.txt Quote Link to comment Share on other sites More sharing options...
fluffi444 Posted December 31, 2020 Share Posted December 31, 2020 On 12/22/2020 at 12:19 PM, fluffi444 said: The use of latest official AIDA64 6.32.5600 with Gigabyte's RGB Fusion Software (no matter which Version) to control the LEDs of my Gigabyte AORUS GTX 1080 Ti Extreme is not working. Deactivation the GPU Senors (in AIDAs Stability settings) followed by reboot helps but I need them both running together... May I ask if there is an update for this topic? I don't want to appear impatient... I can well imagine that capacities are limited due to vacation time. I'll accept any answer :-) Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 13, 2021 Share Posted January 13, 2021 On 12/31/2020 at 1:36 PM, fluffi444 said: May I ask if there is an update for this topic? I don't want to appear impatient... I can well imagine that capacities are limited due to vacation time. I'll accept any answer :-) Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works 1 Quote Link to comment Share on other sites More sharing options...
fluffi444 Posted January 13, 2021 Share Posted January 13, 2021 3 hours ago, Fiery said: Let me know how it works Works! Thank you so much! Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 13, 2021 Share Posted January 13, 2021 21 minutes ago, fluffi444 said: Works! Thank you so much! Thank you for your feedback! Quote Link to comment Share on other sites More sharing options...
PITVIPR Posted January 4, 2022 Share Posted January 4, 2022 @Fiery Hey, Same exact problem as fluffi444, and many others have had even after the fixes. I have a gigabyte 1070ti gaming 8G version and I'm trying to run a sensor panel and rgb fusion at the same time and can't. My dump is attached. nvidiasmbusdump.txt Quote Link to comment Share on other sites More sharing options...
