ndsspex Posted July 19, 2018 Posted July 19, 2018 Hi, I've met a issue with the FPU stress test, the system would crash instantly when I click the "Start" buttom it was ok to run a solo CPU stress test over 2 hour, but I just dont understand why it went wrong when conducting the FPU test. Any Ideas? many thanks! I've attached a AIDA64 report of my mobo my build CPU:7940x (1.15volt, OC 4.5ghz) MOBO:R6A RAM:Gskill 8G*4 4266mhz c17 (I set the frequency at 2133) PSU:AX1500i Report.txt Quote
Fiery Posted July 19, 2018 Posted July 19, 2018 Try to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it still causes the same issues, then try to update the BIOS to the latest version, and load the optimized values in the BIOS Setup. Quote
ndsspex Posted July 20, 2018 Author Posted July 20, 2018 Tried, the scenario remains : ( I've updated to the latest version for both bios and aida64 guess something wrong with my volt setting? any idea ? Thank you! Quote
Fiery Posted July 20, 2018 Posted July 20, 2018 1 hour ago, ndsspex said: Tried, the scenario remains : ( I've updated to the latest version for both bios and aida64 guess something wrong with my volt setting? any idea ? Thank you! Probably your CPU and/or your RAM is excessively overclocked. Unless of course it crashes with default values loaded in the BIOS. Quote
